Weird Noise When Taking Off In First Gear - Tdm900, 2005
tdm900 noise clutch gear
28 replies to this topic
#21 Studley Ramrod
Posted 18 July 2014 - 10:33 am
Some oil are miscible, like the stuff I use. http://www.chemodex....products_id=325
Means you can mix it with synthetic and mineral based oils. :)
#22 Kalts
Kalts
  • 104 posts
Posted 18 July 2014 - 11:29 am
I would be worried because of the "fuel-efficient multigrade engine oil meeting the latest API classifications." phrase. It could mean anything, but "fuel-efficient" could also mean something in the lines of "energy conserving", meaning the oil contains additives not suitable for usage in wet clutches. But it apparently works for you and that's all what counts.
#23 erdferkel
erdferkel
  • 273 posts
Posted 18 July 2014 - 04:29 pm
Uncle Yamaha-san recommends to use motorcycle specific oils without low friction additives found in car oils because they can cause clutch slippage.
Any JASO MA oil will do. (insert the Dappers howl here) ;)
-putt putt?
-braap?
-braaaaaap!!
#24 devnull
devnull
  • 21 posts
Posted 21 July 2014 - 10:50 am
Ah, OK - I wasn't aware of that JASO MA classification, manual only tells you about type and API grade.
Will certainly take this into account, cheers lads.
Edited by devnull, 21 July 2014 - 10:51 am.
Ad astra per aspera.
#25 erdferkel
erdferkel
  • 273 posts
Posted 21 July 2014 - 02:22 pm
The manual also says:
"Do not put in any chemical additives or use
oils with a grade of CD aor higher.
Be sure not to use oils labeled “ENERGY
CONSERVING II” or higher. Engine oil also
lubricates the clutch and additives could
cause clutch slippage."
So with JASO MA you are on the safe side ;D
-putt putt?
-braap?
-braaaaaap!!
#26 devnull
devnull
  • 21 posts
Posted 09 October 2014 - 11:19 am
Alright, just to wrap up, I finally managed to get this oil/filter changed, and yeah good news is no more annoying squealing.
Well maybe there is a tiny, tiny bit of squealing on cold engine but almost unnoticeable so I'm happy with it.
Thanks to anyone involved in this thread.
Edited by devnull, 10 October 2014 - 12:05 pm.
#27 JBX
Posted 09 October 2014 - 05:20 pm
Oil mixing is evil !
The clutch squealing may also be cured with stronger clutch springs - some owners on the french forum did that mod .
Mine do that once a year during winter, when engine is cold.
I don't pay much attention...
#28 cortez
cortez
  • 213 posts
Posted 14 October 2014 - 02:00 am
In over 90,000ks nary a squeak from the clutch on my Niner.  I use Silkolene comp 4 10w-40.  Oil and filter changed every 6,000ks.
#29 trevini
trevini
  • 1,891 posts
Posted 14 October 2014 - 05:16 am
Normal for niners.  Mine usually does it when cold and coming up due for an oil change - kind of a "change oil alarm"  :rotflmmfao: Been like it since day one in 2005.
Also tagged with one or more of these keywords: tdm900, noise, clutch, gear
