Tdm Fails On Road - Arghghgh
electrics control unit fail help
30 replies to this topic
#21 harvey krumpet
harvey krumpet
  • 2,065 posts
Posted 07 May 2015 - 11:40 am
Go over all the joints cleaning and applying ACF50 to the connectors before you put them back together.
You will have to get the tank up and airbox off which will entail removing side panels. It's easier with a tank prop.
I'm not too far from you so if you have somewhere to work under cover, I could take a trundle over there with a few tools and meters and have a look at what the problem might be.
Bikes are designed to work, men don't 'fiddle' we carry out  repairs using sound engineering principles... or we ought to.
The only few known niggles on the niner are easily sorted.
Now that is what I call a mobile app. Splendid.
#22 Sue
Sue
  • 7 posts
Posted 07 May 2015 - 06:59 pm
Again, thank you all - message sent to leehenty  :good:  :)
#23 dablik
  • 10,893 posts
Posted 08 May 2015 - 12:43 pm
That's your bike on the road to recovery then, nowt gets past Sir Henty  :good:
#24 leehenty
  • 5,321 posts
Posted 10 May 2015 - 02:16 pm
Error 11 which is cam sensor. Multi plugs a bit furry. Cleaned the switches but cam sensor has stayed duff so it needs a new one.
Cleared the faults but this one keeps coming back
Sue was on the ball with tea and biccies.
Several rusty screws got binned. Looks like a return visit when new sensor has been obtained. Bike is in good nick just needs a bit of fettling. There are several wires which need tidying up as well.
#25 dablik
  • 10,893 posts
Posted 10 May 2015 - 03:22 pm
Hate to think what one costs new,I managed to get lucky with a 2nd hand one of ebay when mine went, nice one Lee  :good:
#26 leehenty
  • 5,321 posts
Posted 10 May 2015 - 03:49 pm
£88 😞 new
#27 Studley Ramrod
Posted 10 May 2015 - 03:58 pm
Well done Lee ! :good:
#28 TinTin
TinTin
  • 1,296 posts
Posted 10 May 2015 - 04:36 pm
Is this the one http://www.ebay.co.u...=item1c524fe151
Had stuff from Germany before. No probs.
Edited by TinTin, 10 May 2015 - 04:38 pm.
#29 leehenty
  • 5,321 posts
Posted 10 May 2015 - 05:51 pm
Yes that will do the job,mucho cheaper than here.
Sue was going to ring webbs of Peterborough.
If she gets one I can pop back and sort it.
Edited by leehenty, 10 May 2015 - 05:52 pm.
#30 JBX
Posted 10 May 2015 - 07:59 pm
THe cam position sensor and the speed sensor are the same (both are hall effect sensor aka active sensors).
Swap them to be sure where the problem comes from.
Btw a faulty speed sensor does not prevent the engine from firing.
You may also check them but they need to be plugged in and main switch on.
#31 Sue
Sue
  • 7 posts
Posted 12 May 2015 - 10:00 pm
Gentlemen, thank you all for your help & advice - Lee, I would like to extend a very special thank you to you. Next time, if there is one, I promise cake and I will get to a fettle day!
Sadly I had a new one on order before I saw your message TinTin :( Ah well, I did do a lot of searching & had to give in as I will have to wait 14 days for it to arrive from Yamaha in Japan - next time I need a 'thing' I will wait a day or two longer to hear from one of you! :D
I gives me longer to get the bike clean in places that I can't usually get to .....
Also tagged with one or more of these keywords: electrics, control unit, fail, help
