Mk2 850 4Degree Ignition Advance
72 replies to this topic
#21 fixitsan
  • 4,840 posts
Posted 15 November 2016 - 07:48 pm
have you any pics of the gearbox wire your disconecting fixitsan? i havnt seen this mod before but gona give it a try while im having a sorting of my bike this winter.
this is the top of the ignitor unit, behind the front left side panel.....the white wire has been released from the plug rear side  and tucked up into the harness sleeve for safety (more permanent taping up  will be done)
Attached File  ignitor1.jpg   399.86KB   1 downloads
To release the pin play around with the sprung retainer holding the plated terminal in the socket (yellow arrow)
Attached File  ignitor2.jpg   119.96KB   1 downloads
Edited by fixitsan, 15 November 2016 - 07:49 pm.
#22 tdmpaul
tdmpaul
  • 201 posts
Posted 15 November 2016 - 08:54 pm
cheers i'll give it a go :-)
#23 fixitsan
  • 4,840 posts
Posted 27 November 2016 - 09:16 am
Still got the 1st and 2nd gear wires sending to the ICU from the selector barrel?
While waiting for a new output shaft seal I've looked at the neutral switch some more. I removed the one off my spare 850 engine to compare and it would appear that the wires are actually for gears 2&3, and not 1&2 as previously thought.
I thought something was strange about that because after disconnecting the white wire at the ignitor I was getting noticeably better performance in 3rd gear
#24 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 27 November 2016 - 10:39 am
Got a photo?
Just saying, as I've got a problem with this and I have no spare engine or time to dismantle my Mk2.
Also, having referenced JBX's site, looked at the 4TX photo diagrams (1N4001 diodes) and compared them to what I saw on my motorcycle, IIRC I noticed that
  • The 2/3 wires weren't shown as "common" at the ICU end (which was odd) in JBX's example
  • I thought it seemed strange that 1st gear should be left "open" with only 2nd and 3rd receiving attention
  • IIRC, that my confusion arose from having discovered that my own wiring was wired around the neutral terminal to 1st and 2nd gear terminals, which fitted my own mindset. So what was going on?
IIRC, we all came to the view that there were a couple of minor, anomalous errors (how we all laughed)
I worked around with the assumption that the 1-N-2 scenario was the correct position to take, did the diode thang, kept the wiring to the ICU end intact and it all worked fine thanks
evidenced below
A video showing Mk2 gear indicator functioning perfectly well
and a Mk2 that pulls like crazy without any mods
Edited by TYREDNGRUMPEE, 27 November 2016 - 10:46 am.
#25 fixitsan
  • 4,840 posts
Posted 27 November 2016 - 11:09 am
You'll see it when you pull the switch out....the worn copper pads from the switch contact tell you which ones have been used, and the 1st gear contact pad is definitely empty....not sure how to show this on a photo because I can't photograph both sides at the same time, but I'll see what I can do
#26 Favs
Posted 27 November 2016 - 11:15 am
Mirror?
#27 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 27 November 2016 - 11:16 am
What?
Surely the internal wear, described by the ball bearing on the internal surface, would visit all the contacts, whether or not they're plumbed into the electrics.
All contacts shown present and correct here for a 4TX engine
This is what I have worked with and your description is not reflecting my reality.
My reality is that the 1-N-2 contacts were connected in my case.
I'll use that earlier link to the video as proof of having been down in that area and having already done the head scratching (with a positive outcome to boot)
partial screen grab from JBX's site
http://www.jbx9.16mb.com/
You will also see from the above picture, that the 3-4-5-6 contacts are spaced out with a washer each, whereas the 1-N-2 connectors are not.
Is this because they don't normally carry eye connectors and need to be there to prevent the screws from bottoming out inside the brass fittings?
Later JBX goes on to show (like you, yourself state) that N-2-3 are plumbed in, BUT, IIRC, we did arrive at some other conclusion that I cannot recall and am not in the position to make a definitive call on.
All I have is my common sense and experience to guide me and the background feeling that someone conceded that a diagram had been oversimplified and a error introduced as a consequence.  :dunno:
another partial screen grab from JBX's site
Apologies to JBX if I am misrepresenting him and thanks for the guidance that helped me do this
Edited by TYREDNGRUMPEE, 27 November 2016 - 12:02 pm.
#28 fixitsan
  • 4,840 posts
Posted 27 November 2016 - 12:07 pm
The bottom pic looks identical to my wiring.....1st gear not connected
#29 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 27 November 2016 - 12:23 pm
Photo please.
I'll check when the chain and sprockets come due in about 6K time.
It also begs the following questions
Given that his system is very rudimentary. 1-N-2-3-4-5
If, in fact 1st gear mode is isolated from being identified by the ignition system, how is it that 1st gear mode is treated the same as 4th and 5th gear modes?
Why don't we notice? Does it really matter?
Why are 2nd and 3rd gears special?
Edited by TYREDNGRUMPEE, 27 November 2016 - 12:41 pm.
#30 fixitsan
  • 4,840 posts
Posted 27 November 2016 - 01:55 pm
The switch fitted to my bike
My spare switch
Colour code  - light blue = N, white = 2, Green/white = 3
Edited by fixitsan, 07 January 2017 - 06:23 pm.
#31 Studley Ramrod
Posted 27 November 2016 - 04:47 pm
I'm confused, are we talking 850 or 900 switch thingy ?
#32 fixitsan
  • 4,840 posts
Posted 27 November 2016 - 06:07 pm
It's an 850 titled thread. Are you suggesting i would ever tolerate topic drift ? .......
#33 Studley Ramrod
Posted 27 November 2016 - 07:49 pm
Not at all. :)  It's the neutral plus 6 contacts, suggesting 6 gears, that threw me.
#34 fixitsan
  • 4,840 posts
Posted 27 November 2016 - 07:59 pm
You and  me too. !
#35 drewpy
Posted 27 November 2016 - 08:02 pm
evidenced below
who did that mod, really neat and tidy.
Have a link?
#36 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 27 November 2016 - 08:09 pm
If I compare this to the switch panel shown on JBX's site, I see that your contacts 1-4-5-6 are missing their washers + blanking screws.
My panel was identical to JBX's example and had blanking screws in every hole. eh? What gives sez i?
So that suggests that someone has already been here!?
Therefore inconclusive, raising more questions. Sure you're not channeling wigwamclan?
#37 fixitsan
  • 4,840 posts
Posted 27 November 2016 - 08:11 pm
Absolutely not, I'm a married man !
#38 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 27 November 2016 - 08:12 pm
Have a link?
JBX's site
You will have to register
Look under "Electrical > Gearbox Indicator".
#39 fixitsan
  • 4,840 posts
Posted 27 November 2016 - 08:14 pm
I'ld say conclusive that yours is the odd one out !
#40 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 27 November 2016 - 08:15 pm
Look what I found!  :P
http://www.carpe-tdm...=29672&p=293431
Installed a gear indicator in the rev counter. Looked at JBX's site. One thing to note, it's 1st & 2nd connected on the gear position sensor not 2nd & 3rd.
This is the back story.
RolfieB followed JBX's instructions and fitted a gear indicator.
He had loads of bits left over and offered them to me.
Within two weeks I had done the conversion myself.
We both found and agreed that gears 1 & 2 were connected and NOT 2 & 3.
We were both on the alert.
RolfieB had a Mk2a and I had a Mk2.
There was no room for confusion.
Edited by TYREDNGRUMPEE, 27 November 2016 - 08:30 pm.
