* * * * - 1 votes
Gear Indicator Mod 4Tx
30 replies to this topic
#21 Nog
Nog
  • 527 posts
Posted 10 December 2018 - 12:11 pm
Even cheaper and apparently UK dispatch - https://www.ebay.co....ed/151998917265
Might get one for that price just to mess about with.  You can also get ones with hall sensors to work off the shift lever with a magnet for a tenner, but they are very hit and miss apparently.
#22 fixitsan
  • 4,852 posts
Posted 10 December 2018 - 12:59 pm
Probably impossible to make it yourself for less !
#23 Nog
Nog
  • 527 posts
Posted 10 December 2018 - 02:40 pm
I know it's crazy isn't it.  Even buying all the components from China would still probably come in more expensive.
Not sure what quality will be like, but when you can replace it multiple times over for the cost of a few beers it's certainly worth a punt.
#24 JMC
JMC
  • 265 posts
Posted 17 February 2019 - 09:14 pm
So I've started this mod today and done all the hard work but now run into an issue someone might be able to help me with
With all connections made I'm testing and parts of the display not lighting up on gears 1 and 2
If I disconnect the White wire (original wire) you can see in the pic and test all gears work fine
I remember reading something about that wire on here that it can be disconnected, can anyone confirm ?
Discussion I remember is here http://www.carpe-tdm...ine#entry342315
Your thoughts greatly appreciated especially those who were in that discussion :)
Edited by JMC, 17 February 2019 - 09:38 pm.
Hunter S. Thompson.
#25 TDM911
TDM911
  • 14 posts
Posted 17 February 2019 - 09:54 pm
Nekem ilyen:
#26 JBX
Posted 18 February 2019 - 12:10 am
Just remove the original white and green/white wires.   :)
More infos : http://www.tdm-yamah...t.org/?page=GID
Last trick : in case you have color wires available, use color coding to avoid confusion :
0/neutral-black
1-brown
2-red
3-orange
4-yellow
5-green
6-blue
Update : removing the speed sensor on the 900 will give a dash error code after several minutes riding.
This error will disappear automatically after several minutes in case you reconnect the sensor.
Edited by JBX, 18 February 2019 - 12:20 am.
#27 JMC
JMC
  • 265 posts
Posted 18 February 2019 - 08:58 am
Thanks JBX :)
Hunter S. Thompson.
#28 JMC
JMC
  • 265 posts
Posted 19 February 2019 - 09:41 pm
All done and working nicely :)
Thanks for the help I've loads of pics taken so will upload when I get a chance
Hunter S. Thompson.
#29 JMC
JMC
  • 265 posts
Posted 26 February 2019 - 12:06 pm
The first pic is what I started with, so I removed the green and white wires (on gear 1 & 2 pins) and bought some 7 core wire from a motor factors
As you can see from the wired pic I also connected a wire to the Neutral so my indicator would show 0 when in Neutral
I removed the red switch from the housing of an aux light switch to use it as a housing for the display
Buying the ready made display from ebay made this job really simple it just takes a bit of time to run wires and get everything fitted but overall I'm really happy with it and I recon every bike should have this feature :)
Been using the bike every day for about a week and no issues at all, just remember to solder correctly and fasten wires so they cant move and loosen with vibration and it's an easy job for anyone :D
Edited by JMC, 26 February 2019 - 12:08 pm.
Hunter S. Thompson.
#30 WayneUK
WayneUK
  • 29 posts
Posted 27 February 2019 - 09:25 am
I found this housing for the gear indicator https://www.ebay.co....5.c100008.m2219
#31 JMC
JMC
  • 265 posts
Posted 27 February 2019 - 09:40 am
Yep I saw that a few days ago, a bit too late for me  :lol:
But yes a good way to make it look like more of a professional job, I'll leave mine as it is as it's a good topic of discussion when people ask how it was done ;)
Hunter S. Thompson.
