Headlights On 4Tx
35 replies to this topic
#21 Favs
  • 4,422 posts
Posted 23 September 2019 - 12:22 pm
I bought them from Banggood years ago and split them with another member. The LED units unscrewed (fan separated from body), which was great for fitting - I don't know if they are still available.
HID IIRC was a 55w -  the ballast fitted under the clocks behind the fairing - loads of dry space there.
I'd go LED as they are plug n play, save power for other goodies, start immediately, are whiter/brighter than HID and last well.
The lamps linked below are fitted to my 900 - the metal mounting plate can be positioned to give an accurate focal length - I did have to make some 8mm thick spacers to allow the retaining clip to hold the lamp in place.
https://www.banggood...ur_warehouse=CN
You may be tempted........by the price and limited faff. :good:
EDIT had a looksee and thete's plenty of H1, H3 etc available for less than the price of walletbreakers :P
And then the fighting started......... :lol:
Edited by Favs, 23 September 2019 - 12:31 pm.
#22 the969
the969
  • 28 posts
Posted 24 September 2019 - 03:58 pm
  yup those are cheap.... cheaper than decent halogens,  thing about LEDs is the massive variation in price, you can literally pay 3 figures for certain brands. Whether you get 30x the performance along with the price (vs the cheapest)....
Only reservation was possible lack of room for gubbins (4TX).
#23 JMC
JMC
  • 262 posts
Posted 24 September 2019 - 04:50 pm
I've added a 6 led light bar to supplement the headlight
Quick cheap easy fix for a poor headlight
Hunter S. Thompson.
#24 wicklamulla
Posted 24 September 2019 - 06:29 pm
JMC are those crash bars from yer man in Rafal in Poland?  Did ya fit those black nylon blocks that are bolted around the tubes and if so where'd ya get them please?
#25 JMC
JMC
  • 262 posts
Posted 25 September 2019 - 07:50 am
Yep bars are from Rafal, great quality and fit perfect, the nylon blocks are from china my brother picked up 2 pairs on ebay, same as these https://www.ebay.ie/itm/153449326158
Hunter S. Thompson.
#26 wicklamulla
Posted 27 September 2019 - 01:38 pm
wank yew very crutch JMC,  i have ordered some.  K
#27 MipeTDM
MipeTDM
  • 92 posts
Posted 08 October 2019 - 12:19 pm
How about the standard rubber cap, can it still be mounted? I doubt so with the fan?
Also, if no cap mounted, how about moisture ingress?
#28 Favs
  • 4,422 posts
Posted 08 October 2019 - 02:11 pm
On my '99 4tx, with tghe lamps I installed, I kept the caps fitted with no modifications - not so with the '08 900 (minor repairable modifications reqd).
#29 steve27bha
  • 795 posts
Posted 08 October 2019 - 07:45 pm
... - not so with the '08 900 (minor repairable modifications reqd).
Can you explain and describe, please?
My order is due in a few weeks, and I had to get a packing piece to fit my HID bulb, as explained in this question and answered in the following posts.
Would that mount also fit these LEDs?
I thank you for an answer.
#30 Favs
  • 4,422 posts
Posted 09 October 2019 - 09:19 am
Hi Steve
For the 900.....
This is my solution, which I am happy with - you may wish to do differently for your own bike.
I made 8mm spacers and fitted them behind the mounting ring/plates. I also moved the metal mounting plates to ensure correct focal length (this is when I fitted the spacer). It is a little bit of a faff to get the retaining clip/spring fastened but not onerous.The rubber lamp cap was cut to allow the end of the cooling fan to poke through. I cut mine to allow a superglue reinstatement if I wanted.
8mm thick spacer at red  & I cut the boot to just say allow just the very end of the fan poke through (not right through) at green. I think you may be able to do this differently and maybe better with a little head scratching :) .
HTH
PS Usual rider - what you do to your bike is down to you & I'm not responsible.
Attached File  led lamp h7.jpg   21.21KB   0 downloads
Edited by Favs, 09 October 2019 - 09:20 am.
#31 MipeTDM
MipeTDM
  • 92 posts
Posted 09 October 2019 - 10:56 am
Thanks, good to read that should then be fine for my 4TX2.
I just read also from the specification of the bulb the rubber caps can be placed, still (if they fit of course).
#32 Bjørge
  • 1,855 posts
Posted 09 October 2019 - 11:52 am
Hi Steve
For the 900.....
I have bought the (seemingly!) same lamps and tried to fit them.
I have a few questions for you:
- Why did you put 8mm spacers behind the plates ?
- Did your connectors fit the original plugs (mine didn't....)
Bj
#33 Favs
  • 4,422 posts
Posted 09 October 2019 - 01:05 pm
8mm spacer is to let the clip retain the lamp in place.
I used the Yamaha spacer (number 2 in this image  https://www.fowlersp...060-a/headlight ) to plug the LED lead into - the leads won't fit without the standard spacer. I slipped a small cable tie around this spacer to stop it from separating.
The sequence is
Lamp>homemade 8mm spacer>leads from LED lamp >plugged into Yamaha spacer
Attached File  spacers.jpg   104.31KB   1 downloads
Edited by Favs, 09 October 2019 - 01:06 pm.
#34 steve27bha
  • 795 posts
Posted 09 October 2019 - 03:56 pm
I thank you, Favs, for the details and the effort needed to prepare the diagrams.
I think my skinny arms and hands will come in useful on this install!
#35 Bjørge
  • 1,855 posts
Posted 10 October 2019 - 07:47 am
The sequence is
Yes, that makes sense. I don't believe it - I took out the bulb and didn't realise there was an adaptor fitted to it  :rolleyes: ...even if I have actually replaced one as it fried....
Thanks !!!
#36 Favs
  • 4,422 posts
Posted 10 October 2019 - 02:44 pm
You're welcome Steve27bha & Bjørge - good luck with the installation.
