My Tdm Biggification Project
49 replies to this topic
#21 wicklamulla
Posted 06 April 2020 - 08:41 pm
Will this do ?
Interrupted knurls denotes left handed thread.
well done but what took ya so long!   :rotflmmfao:  :badgerrock:
#22 leehenty
  • 5,306 posts
Posted 06 April 2020 - 08:50 pm
Only took about hour or so. No parts to finish the other job, so I got on with it. Posted already.
#23 wicklamulla
Posted 06 April 2020 - 08:51 pm
good work Number 1.  Fancy doin a video for us to peruse the next time ya make sumtin interesting?  Looks mad interesting.
#24 leehenty
  • 5,306 posts
Posted 07 April 2020 - 08:56 am
Next time I will set up a time lapse camera.
#25 ChrisG
Posted 07 April 2020 - 11:56 am
Looks good (both the bike and Lee's handiwork).
I've also got shortened dogbones and lowered pegs.  It was a while ago I did it but I'm pretty sure I rotated the gear selector one notch and didn't have any issues with it, I guess maybe my drop is a bit less than yours.  My only slight annoyance is I have the brake pedal a fraction higher than I'd like it as if I drop it any lower it hits the exhaust when I try and apply the brake.  Wasn't a problem with the standard exhaust but the Fuel's must sit a little bit higher.  Could be easily overcome with a brake lever in a slightly different shape but I've lived with it for several years now.
I tried handle bar raisers with the standard bars and it didn't really feel much different so I went back to standard.  Not tried Renthals though.  I really should get round to fitting mirror extenders though.
#26 Norwegian
Norwegian
  • 162 posts
Posted 07 April 2020 - 04:25 pm
Thanks. Gear selector can (must) be rotated one notch with lower pegs, as there is not enough adjustment in the link bar. Two notches is no-go, though.
Do get the extenders. New world!
#27 leehenty
  • 5,306 posts
Posted 10 April 2020 - 08:08 pm
If you want a stainless gear rod ChrisG I can make you one too.
#28 Norwegian
Norwegian
  • 162 posts
Posted 13 April 2020 - 11:07 am
I found the sheeps works well for touring together with an air dork. Which is the same combos as your inflatable sheeps I suppose.
What is an air dork, then? Tried googling it. Got every variety of dork except airy ones.
Edited by Norwegian, 13 April 2020 - 11:08 am.
#29 dablik
  • 10,885 posts
Posted 13 April 2020 - 11:24 am
He means an inflatable arse cushion of some description..
#30 dapleb
  • 18,362 posts
Posted 13 April 2020 - 11:30 am
Loike dis N https://airhawk.net/
#31 Norwegian
Norwegian
  • 162 posts
Posted 13 April 2020 - 11:45 am
Ah, thanks.
#32 Norwegian
Norwegian
  • 162 posts
Posted 16 April 2020 - 02:08 pm
Attached File  20200416_160216.jpg   31.48KB   1 downloads
Found this in my mailbox today, courtesy of Mr. Henty. My day certainly picked up immediately!
Attached File  20200416_182253.jpg   262.04KB   1 downloads
Beautiful, and a perfect fit. Gear selector is back to its original spline position, giving the arm more clearance in the middle.
Also I found that the gear pedal pivot was well and truly gummed up. A good cleaning and lubrication later the gear shifts are noticably smoother, and the pedal adjusted perfectly.
Edited by Norwegian, 16 April 2020 - 04:32 pm.
#33 Studley Ramrod
Posted 16 April 2020 - 05:01 pm
Niiiice. :good:
#34 leehenty
  • 5,306 posts
Posted 17 April 2020 - 08:48 pm
Oh good glad it got there. Enjoy.
#35 leehenty
  • 5,306 posts
Posted 20 April 2020 - 09:41 am
These arrived from the gentleman above. Makes tea break a time to look forward to.😍
Tea test passed them as 10/10.
Edited by leehenty, 20 April 2020 - 02:34 pm.
#36 GGPOY
GGPOY
  • 9 posts
Posted 29 March 2023 - 03:03 pm
Bonjour M.Henty. désolé de passer par le forum pour vous poser des questions mais mes messages en MP n'aboutissent pas apparemment 😔...Produisez-vous toujours ces biellettes de selecteur? En effet, je suis un géant français qui a rabaissé ses cales pieds et maintenant le selecteur est trop haut, je dois donc le descendre et je suis déjà au max du réglage...Merci beaucoup pour vos renseignements et à bientôt GG de Bordeaux ✌️
#37 leehenty
  • 5,306 posts
Posted 30 March 2023 - 08:32 am
I have replied to you message Norwegian has a gear rod of 153mm, do you think this will suit you ?
J'ai répondu à votre message Norwegian a une tige d'engrenage de 153 mm, pensez-vous que cela vous conviendra ?
I hope this french makes sense, if not blame Apple
Edited by leehenty, 30 March 2023 - 01:35 pm.
#38 Favs
Posted 30 March 2023 - 12:25 pm
Fnarr :rotflmmfao:
#39 GGPOY
GGPOY
  • 9 posts
Posted 01 April 2023 - 10:50 am
Merci M.Henty, j'ai bien eu votre message et je vous ai répondu en MP, et poir information la traduction est impeccable😉✌️GG
#40 leehenty
  • 5,306 posts
Posted 01 April 2023 - 02:34 pm
A bit of down time due to rain, so I made this for the gentleman above.
Un peu de temps d'avraie à cause de la pluie, alors j'ai fait ceci pour le monsieur ci-dessus.
Edited by leehenty, 01 April 2023 - 02:35 pm.
