Carbs, Probably Not
282 replies to this topic
#21 drewpy
  • 1,788 posts
Posted 11 May 2021 - 09:36 am
another thought, did you balance the carbs?
did a search in this topic and nothing came up.
mine were snuffling a bit till the carbs were balanced
I have a set of carb balancers if you want me to nip over with them
#22 Dickiebig
Dickiebig
  • 180 posts
Posted 11 May 2021 - 02:10 pm
I have a spare CDI unit untested or you could whip the one off my bike to try.
Also a stator should you wish to try. Only in Gloucester, the city it's self
#23 dablik
  • 10,893 posts
Posted 11 May 2021 - 04:04 pm
Keep at it Dabs, you'll get there in the end.
You sooo much need a shed with a good light....
Cheers Dave i'll find the problem, just slower than most, often end up checking twice, or 3 times, or, well you get the drift  :lol:
Set the balancers up drew but struggled to get her running even enough to balance, had to keep fiddling with the idle screw which made adjusting the sync screw problematic, was a bit pissed off at this point and walked away so may well be worth another effort..
Dickie i may well take you up on the offer a bit later on regards the CDI unit if all else fails, appreciate that  :good: Have a spare Stator to hand from a Mk2 but without the pick up coil..
#24 dablik
  • 10,893 posts
Posted 11 May 2021 - 04:09 pm
It would'nt surprise me either to find the problem may end up being summit i've missed during checking things out and another go round may often spot the culprit, my biggest worry is something has gone amiss engine wise after a rebuild but am sitting on the fence with that one and hoping summit has'nt gone awry after 300 miles..
#25 Gdogg
Gdogg
  • 1,204 posts
Posted 11 May 2021 - 04:45 pm
Can’t wait for the book to come out dabbs, what’s the title gonna be ? .......
“Fu*#k sake what next?” The joys of restoring a TDM 850 MK1
LOL !!!
#26 dablik
  • 10,893 posts
Posted 11 May 2021 - 05:02 pm
LOL !!!
:rotflmmfao:  :rotflmmfao:   :rotflmmfao:  it's the no shed/garage just amplifies the problem ya bollocks  :good:
Actually chaps what i've failed to mention is how the problem manifests, can start cold with choke no problem (which i thought should rule out vacuum leak!!) and after only a couple of minutes warming up the antics begin. Oops  :huh:
#27 Studley Ramrod
Posted 11 May 2021 - 05:14 pm
Could be a rich problem if the problem gets worse. Sticky/twisted choke cable ? Or, possibly a faulty coil. Or, some electrical connection worsening when warmed up ?
Yeah, leaky vac pipe shows itself on tickover regardless of choke or no choke.
#28 dablik
  • 10,893 posts
Posted 12 May 2021 - 08:00 am
Think i'll be taking a closer look at the choke, seemed okay, but that would also be on both carbs with the problem so i think unlikely !! will look anyhow..coil is a new replacement, wot ya reckon it's summit stupid i've overlooked  :)
#29 Bjørge
  • 1,894 posts
Posted 12 May 2021 - 08:46 am
I've worked as a repairman for many years, and my experience it that the unlikely happens. Not all the time, but not never
Sometimes you get there by strict cause->effect thinking. But every now and then, forget what you think is the row of events leading to where you are and start analysing as if you had absolutely no idea what started the problem and what has been done to the bike in order to get it going.
Like check / change spark plugs.
When I tried to get my old carbs working and struggling with a leaky tank cap it started skipping one cylinder (also after a warmup period, mind you). Nothing to do with water or debris in fuel, as I first thought. Us humans tend to overthink chains of events, always looking for the reason behind things.
Best of luck!
Edited by Bjørge, 12 May 2021 - 08:47 am.
#30 drewpy
  • 1,788 posts
Posted 12 May 2021 - 03:00 pm
Is this you Cliff at night?  :)
#31 dapleb
  • 18,387 posts
Posted 12 May 2021 - 03:56 pm
Not loikely to be timing or oubt either hey if probs only appear after several minwits
#32 dablik
  • 10,893 posts
Posted 12 May 2021 - 04:19 pm
Best of luck!
Never was a truer word spoken Bjorge and your so right, dunno how my brain works when problem solving these issues which is why as i mentioned it's usually a couple of times around until i find the problem, very easy to overlook something, the good thing about this thread though is i will run through it and compile a list to systematically check through..
Good point Batman, makes sense now you mention it  :good:
NOT if she was in bed with me Drew, be munching through little blue tablets   :lol: .....it sure is me, much worse when i was rebuilding though  :)
Edited by dablik, 12 May 2021 - 04:20 pm.
#33 Studley Ramrod
Posted 12 May 2021 - 07:51 pm
I remember working on Skippy's mk1, it was running roungh on one cyl even after he'd fitted new plugs.  Turned out to be a duff new spark plug.  Doubt he'd ever have found that but as I was new on the job, I checked for a spark and bingobangobongo !  Mechanics allus throwing a curve ball or dishing up a red herring.
#34 dablik
  • 10,893 posts
Posted 13 May 2021 - 07:51 am
Took me multimeter to Halfrauds i did and tested the boogers, was only 2 on the shelf  :)
#35 Studley Ramrod
Posted 13 May 2021 - 07:53 am
:lol:
#36 Matlock
Posted 13 May 2021 - 08:27 am
My God Cliff, you are suffering with that bike  :( . You broke a mirror, or shot any albatrosses recently? For my tuppence worth, if you’ve swapped the carbs and still have exactly the same issue, it’s very unlikely to be the carbs. The choke thing does make it sound fuel related though, bangin' & fartin' is incomplete combustion, does it smell of fuel when it's doing this? Both headers heating up consistently? I’d be checking all the fuel system thoroughly. Those bloody carb rubbers Yamaha use are crap, even when new, they’d be my chief suspects. I bought a pattern set for the Tenere once and they weren’t a good fit. Maybe get some new jubilee clips on them so you’re confident they’re airtight and ain't moving anywhere? Check the inlet stubs on the head too for damage, cracks, etc. too.
Put yer new glasses on and rig up some good lighting and check everything visually. Wheel it in the kitchen while SWMBO is out. She’s a good woman, she’d understand…..
#37 Favs
Posted 13 May 2021 - 10:49 am
You could be up for Heavyweight er umm I mean Middleweight Fettler of the Year Award Cliff.
#38 Snowbird
  • 1,463 posts
Posted 13 May 2021 - 11:23 am
No good checking plugs with a multimeter, a megger might show up problems though.
#39 fixitsan
  • 4,850 posts
Posted 13 May 2021 - 05:22 pm
I thought that too, and a few months ago was reminded that some sparkers have resistors.
Apparently the DPR8ea-9 has a 5kohm resistor in there
https://www.opieoils...-electrode.aspx
What if the plugs were knock-off, maybe have the wrong resistor or none at all
NGK recommend not using the wrong plug, if the spec requires resistor plugs then you need to use them
https://www.ngk.com/...stor-spark-plug
The OEM DPR8EA9 spark plug is a resistor plug
"Use of non-resistor plugs in vehicles that call for a resistor type can result in rough idling, high-rpm misfire, and abnormal combustion."
Edited by fixitsan, 13 May 2021 - 05:28 pm.
#40 dablik
  • 10,893 posts
Posted 13 May 2021 - 05:49 pm
Retribution from the Tdm god for sending a 9r down the road and dumping her in Spain  :huh:
Does'nt smell of fuel funny enough, i mean i have the sniffles but cant smell fuel when i stick me conker near the end of the exhaust, woudl'nt surprise me to find a crack someplace either after the bangs i've had, headers heating up okay and the inlet rubbers are 300 mile old aftermarket jobbies, clips are years old though, Inlet stubs and cracks, okie doke another check on the list, cheers Chris..
Silly fookers need to stop You tubing the idea then....  :rant:
Ta Chris, i'm aware the plugs use resistors and i have the correct plugs ngk plugs fitted, reason i took me multimeter cos i know there are some flakes floating about, actually have about 3 or 4 sets so can swap, aint buying more..
I'm just waiting for the certificate medal to arrive Al  :lol:
