Datatool Alarm
36 replies to this topic
#21 JohnnyW
JohnnyW
  • 313 posts
Posted 03 June 2023 - 07:03 pm
That would be a result JW...fingers crossed fur ewe.
Fingers,toes and anything else I think of to cross.😄
#22 Studley Ramrod
  • 19,334 posts
Posted 04 June 2023 - 09:26 am
:good:
#23 JohnnyW
JohnnyW
  • 313 posts
Posted 04 June 2023 - 08:06 pm
I knew the Gods were just messing with me.🤬🤬🤬 Bypass plug now ordered from fleabay. Thanks for the link Trev.
Although TDM out of action I was still able to able to get out for a ride and enjoy this fine weather. Picked up a 2yr old Royal Enfield Interceptor yesterday and have been having a hoot with it. So much so that when the alarm situation has been resolved there's a good chance Matlock's Big Yeller will be going back on the market.
#24 JohnnyR6
JohnnyR6
  • 17 posts
Posted 18 June 2023 - 08:08 pm
I had this issue a few years ago with my 04 bike. I ripped it out and have never looked back. If your handy with the spanners it's relatively easy to do.
But.. I'm sure there's an easy option. You bridge 2 wires in the box and disconnect it. I'll see if I can find the link.
Maybe worth a wee search.
#25 JohnnyR6
JohnnyR6
  • 17 posts
Posted 18 June 2023 - 08:24 pm
https://youtu.be/EcjBJ4DxB1k
Personally I'd rather remove the whole unit than bridge cables the way he does but at least you can try that and if it works, sorted. If not you've not list anything as you could plug it back in.
Edited by JohnnyR6, 18 June 2023 - 08:26 pm.
#26 JohnnyW
JohnnyW
  • 313 posts
Posted 19 June 2023 - 07:45 am
The alarm has been removed, Trevini gave me a link to a site on ebay which sells a plug you insert into the wiring circuit that bypasses the alarm. Essentially just a neat way to bridge the cables. Bike back to full operation and now sold.
#27 PICARD
  • 1,771 posts
Posted 19 June 2023 - 07:55 am
Aye up...any chance you could post up details or pic of the bypass doohickey please. I've just looked at my alarm, and the only wires available are a bunch of 3 which have been cut and taped. I'm assuming this is where the plug should be??
#28 trevini
trevini
  • 1,863 posts
Posted 19 June 2023 - 08:19 am
https://youtu.be/x98nL3nYcR4
https://youtu.be/AhHj8_Xlh7c
Might help a bit
This is really useful as it describes the internal wiring colours of the unit....http://www.sonicside...otorcycle-alarm
See quote above for links...
#29 PICARD
  • 1,771 posts
Posted 19 June 2023 - 05:33 pm
Thanks Trev, that looks a bit more complex than I had in mind tbh. I just know that one day, probably when I'm miles from home in a blizzard, the immobiliser / alarm will let me down, so I'm just looking for the "plug and play" option for now.
#30 trevini
trevini
  • 1,863 posts
Posted 19 June 2023 - 05:41 pm
The plug and play option still requires the alarm unit to be dismantled, but there are many videos on you tube if you search. It’s dead easy to sort out, unlike full removal which is time consuming and sometimes frustrating. Either way, you’re best rid of it, especially when they’re so easy to bypass.
#31 PICARD
  • 1,771 posts
Posted 19 June 2023 - 06:16 pm
Thanks again Trev...I'll have a crack at it when tim allows. It's getting on for 20 yrs old now....the sounder just meeows, but the immobiliser is fully operational....it just feels like a time bomb!!
#32 dandywarhol
Posted 21 June 2023 - 08:26 am
Was there not a lifetime warranty with the ex Summers bike???  :hide:
#33 JohnnyW
JohnnyW
  • 313 posts
Posted 22 June 2023 - 04:55 pm
A warranty?? That's news to me!Does that mean he owes me £11 for the plug and play item? 🤣
#34 Matlock
Posted 23 June 2023 - 08:49 pm
It was fully warrantied right up until the moment it was loaded on the van by the Bikebus lads   :rotflmmfao:
#35 PICARD
  • 1,771 posts
Posted 27 June 2023 - 11:58 am
I've just recived and fitted the bypass kit to my Datatool S4 red alarm / immobiliser. There is no need to dismantle the alarm whatsoever, just unplug the 10 pin connector, replace with the bypass plug and Robert is indeed your mother's brother. It was a bit confusing, because just about everything on yoootooob shows butchery inside the alarm sounder, as stated by Trev above, whereas in fact, the only thing you need to do with it is dispose of it responsibly as recommended by your local council.
#36 trevini
trevini
  • 1,863 posts
Posted 27 June 2023 - 04:21 pm
Top job then  :good:
mine was an S3, so they’ve obviously improved the design  :rotflmmfao:
#37 PICARD
  • 1,771 posts
Posted 27 June 2023 - 05:53 pm
Yep looks like things have moved on Trev, although from a security point of view, it may be TOO easy to bypass now!!
