I ordered the Healtech IQSE Quickshifter as their products are usually foolproof... and sure enough it was. You run it from an app on your phone, very customisable including increasing / decreasing the time that the ignition cuts out, particularly useful for a big lumpy twin cylinder setup...
Quickshifter And Cruise Control (Sort Of)
#21
Posted 19 February 2025 - 05:27 pm
#22
Posted 20 February 2025 - 09:37 am
#23
Posted 28 February 2025 - 08:43 am
So I'd also mentioned about a cheapo throttle restraint (too much of a stretch to call it cruise control).
I used an enormous cable tie, cut it down to correct size and secured it to the inside end of the twistgrip. You push it down onto the top of the front brake lever & it stays in place until you twist the throttle again. Size-wise, I think it's 12.7mm wide and fairly rigid, so when fitted stays in place and secured tightly doesn't seem to slip. I suppose eventually it'll wear a bit but just buy a six pack of them - they're pretty cheap.
You can then jam a very thin, small screwdriver head into the cable tie's teeth which allows it to loosen and come off, so it's removable and re-usable.
Works pretty well.
Alternatively, you could use a fairly long, thin jubilee clip on the twistgrip. It'll do the same thing, although the metal might be sharper against your hand.
Cut-down cable tie compared to a standard size one.
#24
Posted 04 March 2025 - 09:00 am
I made my own quickshifter. on my 900, using a power commander and re purposed rear brake switch.
no gearbox issues what so ever, despite countless track days.
