My HID Xenon installation (low and high beam)
#21
Posted 28 October 2008 - 09:10 pm
Something to do with it working like a florescent tube rather than an element.
#22
Posted 28 October 2008 - 09:45 pm
I still can't believe the amount of light I now have available since I changed over to HIDS
#23
Posted 28 October 2008 - 11:20 pm
At first it flashes (ignition of gas), then it turns on to about the brightness of halogen while warming up to about three times the brightness of halogen. I had HID on both low and high beam, the HID on high beam does make the "pass" flash effect slightly less. So if I wanted to get noticed, I would just switch high beam on. Within a few seconds the lighthouse would light up their whole interior, so you definitely get noticed. Once the bulb has been warmed up (it's still about three times cooler than halogen in that case), you can use it for flashing off and on to max brightness instantly. I did not see any significant disadvantage of having both bulbs fitted, not significant enough at least to outweigh the huge advantage (a LOT of light all the way to the horizon).
The Pan has two H4 bulbs, so now I have two times low and instant high HID. The high beam in that case works by means of a magnetic switch that uncovers the bottom part of the bulb for high beam. You can see the bottom part of the reflector (for high beam) is blocked in the next pic, as well as the higher aim to the right side of the road:
www.piloot.com
#24
Posted 01 November 2008 - 06:44 pm
#25
Posted 01 November 2008 - 09:57 pm
Light output is equivalent to what you would get from an 80watt Halogen source, but you will lose a lot because reflector is not designed for the longer 'bulb'.
HIDS unit runs cooler, so less power is wasted as heat.
#26
Posted 26 January 2009 - 05:00 pm
I've been studying your pictures as I intend to upgrade to HID lights on my TDM900Abs and you make it all seem pretty straightforward - time will tell!! I have noticed in your pictures that you have crash bars fitted - can you tell me which ones you have as they look fairly effective? They would have saved me over 160 quid when my bike blew off the side stand in the gales back in December and did the left side fairing no good at all. Hoping you can help
Best regards, oldfogey
#27
Posted 26 January 2009 - 11:29 pm
#28
Posted 26 January 2009 - 11:41 pm
Hi Oldfogey, i don't suppose you used to ride a Transalp and wandered round the world fer a year or 2 ???? cheers Wicky
#29
Posted 27 January 2009 - 10:55 am
no, sorry but nothing that adventurous! Been using an XS650 Special that I bought from Roy Anthony in 1980, when he had a workshop on The Quay at Exeter, up until April 2008. It was going to see me out until I draw my wooden overcoat and then my son suggested a trip around the Pyrenees last August and that's when I changed over to my TDM900. I'm still trying to catch up with new technology!! Maybe bump into you at Bridge in Exeter sometime.
Regards, oldfogey.
#30
Posted 29 January 2009 - 02:14 am
#31
Posted 26 February 2009 - 09:09 pm
#32
Posted 26 February 2009 - 09:12 pm
Nope, yep. Plug and play.
www.piloot.com
#33
Posted 27 February 2009 - 06:15 am
cheers,big wash for the beastie tomorrow oilchange and change the lights
#34
Posted 13 August 2009 - 03:06 pm
#35
Posted 03 September 2009 - 09:08 pm
J
John
2012 plated model, Black - with black seat
Mods - Yamaha High Screen, Scott Oiler, Fenda Extender, Givi Top box and panniers, Yamaha Heated Grips, Barkbuster Hand Guards
The Wish List - a decent horn, crash bungs
06 Model in Blue with Silver trim [GONE - But not forgotten
Mods - Yamaha High Screen, Scott Oiler, Fenda Extender, Givi Top Box and Panniers, LED running light. Acerbis Dual Road Hand Guards, HID, Yamaha heated grips
Wish List - Crash Bungs,
#36
Posted 06 July 2011 - 11:57 am
The explanation is excellent but I can't see the pictures maybe because the post is old? Can you upload your pictures of the installation?
Thanks.
And great tutorial!
Regards,
VaDor
#37
Posted 06 July 2011 - 01:34 pm
Hi Vador,
the photos are still there
Try this linkydinkydoodaah http://piloot.smugmu...t/3027130_NTv6o
#38
Posted 19 May 2012 - 07:35 pm
#39
Posted 19 May 2012 - 07:44 pm
He also suggested I raise the beam up a little
Cats
#40
Posted 24 January 2013 - 10:55 pm
