Air Horns on the TDM
34 replies to this topic
#21 E-njoy
E-njoy
  • 570 posts
Posted 17 September 2007 - 09:32 pm
Stebel Nautilus compact airhorn with integrated compressor on my 900, to keep the thread up to date. Cheap, small, simple, clean, very effective:
More here: http://piloot.smugmu...gallery/1871672
Emile
www.piloot.com
#22 catsbum
Posted 17 September 2007 - 09:41 pm
E-njoy, Nice looking horn. Shiny too. Hmmmm. Its also nice to see you too have used nylon ties to secure your audible device.
Any chance of you attaching a WAV file of your horn
#23 TonyDevil
Posted 18 September 2007 - 08:06 am
QUOTE(CatsBum @ Mon 17th Sep 2007, 10:02 PM) <{POST_SNAPBACK}>
Went to work today and found a new use for my airhorns: Just press the button when sitting by a car with a chump on his phone. He gets pissed off as he can't talk, I'm laughing as I'm sure he wet his pants as well.
rotflmmfao.gif lol nice....but are they louder than a blip of trixys throttle?
#24 catsbum
Posted 13 December 2007 - 06:06 pm
Well here we are some months later and this evening the air horns are coming off and the Stebel Nautilus is going on.
Questions.
1) E-njoy. Did you use a relay on your horn?
2) Anyone fitted these to a Mk1. If so how and where?
ta
#25 ChrisG
  • 8,281 posts
Posted 13 December 2007 - 09:10 pm
Stebel Magnum will go on without a relay, the Nautilus will need a relay
#26 tdm850rider
Posted 13 December 2007 - 09:14 pm
QUOTE(CatsBum @ Thu 13th Dec 2007, 12:51 PM) <{POST_SNAPBACK}>
Questions.
ta
Here using an existing bolt under the RH fairing sidepiece.
There are some ties for added security.
#27 catsbum
Posted 13 December 2007 - 10:32 pm
Thanks to Thomas and Chris for the replies
Fitted the horn under the fairing after some umming and arrring. Under the speedo using good Ol nylon ties. Very secure too. The relay will have to wait till next off day as I ran out of time. Still sound pretty damn loud. tongue.gif
edit: Explain to me what function the relay has?
Edited by CatsBum, 13 December 2007 - 10:33 pm.
#28 tdm850rider
Posted 13 December 2007 - 10:55 pm
QUOTE(CatsBum @ Thu 13th Dec 2007, 05:17 PM) <{POST_SNAPBACK}>
I assume you have the Stebel hooked up with the existing horn wires.
As such the Stebel is only as loud as the amount of current the thin guage horn wires can handle.
With a relay the horn wires open a second switch allowing current to pass thru heavy guage wires to the horn.
Makes it louder and more melodious.
#29 ChrisG
  • 8,281 posts
Posted 14 December 2007 - 06:44 pm
...and stops it melting your electrics! blink.gif Nautilus will draw around 18A, which is more than both your headlights draw, so it should be attatched by a similar thickness of wiring as the lights, the standard horn will use a fraction of that so the wiring will be too thin to come with that much power (advantage of the Magnum, it only needs 8A)
Maplin sell a 30A relay for a couple of quid. Connect pin 85 to ground, 86 to the wire from the horn switch, 87 to your shiny new horn (with appropriate guage wire, then earth the other terminal of the horn), and pin 30 to 12V source that can cope the with current, best bet is generally to route it to the +ve battery terminal via a fuse (again, Maplin sell an inline fuse holder that will take a blade fuse).
Edited by ChrisG, 14 December 2007 - 06:46 pm.
#30 Guest_Pantboy_*
Guest_Pantboy_*
Posted 14 December 2007 - 08:47 pm
QUOTE(ChrisG @ Fri 14th Dec 2007, 06:29 PM) <{POST_SNAPBACK}>
Maplin sell a 30A relay for a couple of quid. Connect pin 85 to ground, but you'll keep breaking the wire when you ride off tongue.gif 86 to the wire from the horn switch, 87 to your shiny new horn (with appropriate guage wire, then earth the other terminal of the horn), and pin 30 to 12V source that can cope the with current, best bet is generally to route it to the +ve battery terminal via a fuse (again, Maplin sell an inline fuse holder that will take a blade fuse).
#31 catsbum
Posted 14 December 2007 - 08:50 pm
As always good advise given. Thanks chaps. Have now disconnected the Stebel until mod made. Did come with a relay. Have a look this weekend.....although working ranting.gif
#32 Landy
Landy
  • 1,387 posts
Posted 15 December 2007 - 11:27 am
I use these fuse holders a lot where water may be an issue, they are very good. Fuseholder
#33 Tempest
Tempest
  • 282 posts
Posted 15 December 2007 - 01:26 pm
How about fitting a set of these babies?
http://www.buyautotr...t-express-horn/
Oink & Be Happy.
#34 ChrisG
  • 8,281 posts
Posted 15 December 2007 - 02:27 pm
QUOTE(Tempest @ Sat 15th Dec 2007, 01:11 PM) <{POST_SNAPBACK}>
#35 catsbum
Posted 15 December 2007 - 05:31 pm
QUOTE(ChrisG @ Sat 15th Dec 2007, 02:12 PM) <{POST_SNAPBACK}>
Well, If I have another curry like the one lst night, just find some 1/2" hosing, attach it and job's your uncle.
