Scottoiler
152 replies to this topic
#21 Guest_Emmett_*
Guest_Emmett_*
Posted 13 June 2006 - 07:00 pm
Scotoiler is a great bit of kit, especially if you get the touring resevoir, but I'd prefer a belt drive on me boike. cool.gif
#22 Guest_E.T._*
Guest_E.T._*
Posted 14 June 2006 - 07:43 am
Well you can always buy the BMW TDM...
#23 Guest_nils_*
Guest_nils_*
Posted 14 June 2006 - 10:21 am
QUOTE(E.T. @ Wed 14th Jun 2006, 09:28 AM) <{POST_SNAPBACK}>
Are you referring to F800GS?
NEWS
/Nils
Edited by nils, 14 June 2006 - 10:28 am.
#24 Jandreas
Jandreas
  • 101 posts
Posted 14 June 2006 - 10:59 am
QUOTE(E.T. @ Tue 13th Jun 2006, 05:23 PM) <{POST_SNAPBACK}>
19000 miles from my chain so far and the rear sprocket is hardly worn. I've ridden all year round, though tend to avoid wet days if I can - but it has been subject to winter road crud etc.
Am I happy with the Scotoiler? Yep
Hm....been driving 22000miles with the sprocket/chain set so far....happy without Scotoiler....
#25 wrex
wrex
  • 35 posts
Posted 14 June 2006 - 12:26 pm
QUOTE(E.T. @ Wed 14th Jun 2006, 08:28 AM) <{POST_SNAPBACK}>
#26 Guest_E.T._*
Guest_E.T._*
Posted 14 June 2006 - 02:09 pm
QUOTE(nils @ Wed 14th Jun 2006, 09:06 AM) <{POST_SNAPBACK}>
NEWS
/Nils
Yep...didn't really need much expalining eh!...its interesting to see what the bike media is making of this "revolutionary" motorbike... cool.gif
#27 wicklamulla
Posted 14 June 2006 - 05:54 pm
QUOTE(wrex @ Wed 14th Jun 2006, 01:11 PM) <{POST_SNAPBACK}>
#28 Pict
Posted 23 June 2006 - 10:02 pm
QUOTE(nils @ Mon 12th Jun 2006, 12:26 PM) <{POST_SNAPBACK}>
I am fed up with the messy rear wheel. The different chain lubricants that I have used over the years all leave most of the oil on the rim.
Most of all I would replace the chain for a belt drive, but I cannot find any conversion kit for the 900.
My questions are:
o Will a Scottoiler leave less oil residue on the rim?
o Is it difficult to set up the Scottoiler for rigth amount of oil?
o Do you have to tweek these settings every 100 kms?
o Are you all happy with your Scottoiler?
Thanks for any feedback
/Nils
Found the Scottoiler really makes a difference to chain condition - riding year-round in all weathers. It dd get a bit enthusiastic at one time and mess up the back wheel though. Also created a front-end mess that ran on to the side-stand (Kept it rust-free!), but was easily readjusted. I'd rather over-oil than starve the chain.
P.
#29 Guest_nils_*
Guest_nils_*
Posted 26 June 2006 - 10:20 am
I picked up the Scottoiler Universal kit yesterday. Now I just will try to find the time to install it (using the exellent directions that JBX has provided).
/Nils
#30 stevepsd
stevepsd
  • 71 posts
Posted 27 June 2006 - 12:57 am
Has anyone installed a Scottoiler (standard one) on their Mk1? If so, where did you mount the reservior so it was accessable and how did you run the line o the rear sprocket?
Thanks.
-steve
'92 TDM850 Corbin Seat, Stainless Laser Pro-Stock Exhaust, K&N, Ceramic Coated downpipes, BMW F650
Handguards, MRA TouringScreen Windshield, dual-FIAMM's, Euro city light, YZF-R6 electric fuel
pump & polished rims!
'87 XR600R To many mods to list, but it's street legal (sort-of)!
'82 XJ550 Seca
#31 TonyDevil
Posted 27 June 2006 - 09:04 am
QUOTE(stevepsd @ Tue 27th Jun 2006, 01:42 AM) <{POST_SNAPBACK}>
Thanks.
-steve
yes
under the seat, left hand side, tucked under the tank an ickle bit, cable tied to the bit that holds the oil tank and shock in place, easily accessible with the seat off.
also fitted a lubetube which lives under the seat.
i put mine on front sprocket, couldnt find a way of routing it to the rear where it wouldnt get munched by chain/shock and not be on display.
i get a dribble of oil down the stand every now and then, but other than that no issues at all.
if u going to RTT then i can show you there.....
#32 ripper
ripper
  • 193 posts
Posted 27 June 2006 - 11:43 am
Mine is behind the rear brake piston, made an L shaped braket and replaced standard bolt which holds piston with a longer one then used a lock nut fed pipe round swinging arm to my home made dual injector £3.00 worth of bits + the bracket out of the works first aid kit.
Rob
#33 wicklamulla
Posted 27 June 2006 - 12:12 pm
QUOTE(ripper @ Tue 27th Jun 2006, 12:28 PM) <{POST_SNAPBACK}>
#34 nitram
nitram
  • 272 posts
Posted 27 June 2006 - 01:51 pm
I have a the high capacity reservoir doohicky, it sits behind the number plate. Drip feed tube routes under the seat then down to the front of the swingarm and then under the bottom of the swingarm to a double dripper that drips either side of the rear sprocket smile.gif good.gif
#35 wicklamulla
Posted 27 June 2006 - 01:54 pm
QUOTE(nitram @ Tue 27th Jun 2006, 02:36 PM) <{POST_SNAPBACK}>
hey Nitty i have a single nozzle setup on mine but i have a dual'er which was part of the deal when i bought me scotty from Busters sitting in the shed..............how'd u secure yer dual thing to the swingarm ?? any pics maybe...... good.gif
#36 Guest_Emmett_*
Guest_Emmett_*
Posted 27 June 2006 - 06:04 pm
QUOTE(wicklamulla @ Tue 27th Jun 2006, 02:39 PM) <{POST_SNAPBACK}>
I don't really like the dual nozzle, I have one on one a me bikes, it keeps clogging up and not working, I bought a single nozzle to put on instead, but it's still sitting on a shelf two months later unsure.gif , the dual nozzle is better when it works, but it's not as reliable.
#37 Wevski
Wevski
  • 9 posts
Posted 29 June 2006 - 08:27 am
QUOTE
Of the spray on types I reckon Castrol chain wax is pretty good, doesn't shift much
I'd second that, i race a Ktm200 in enduro's and use Castrol, i know its not the same thing but i can vouch for the fact there is no 'fling' from the lube. Obviously all the mud and crud wipes away and excess from the Ktm chain, but when i took a link out there was plenty around the o rings and pins which is where it is meant to be.
The castrol goes on like liquid but soaks in well and dries to a film after about 5 mins. good.gif
#38 tdm850rider
Posted 29 June 2006 - 10:29 am
QUOTE
QUOTE(Wevski @ Thu 29th Jun 2006, 03:12 AM) <{POST_SNAPBACK}>
Agree with the above except that I use Maxima (chain wax) Still have a 14 year old chain with no kinks or bad spots.
(do need to check for stretch though, been 'scottish weather' here the past week.)
#39 Pict
Posted 29 June 2006 - 10:58 am
QUOTE(tdm850rider @ Thu 29th Jun 2006, 11:14 AM) <{POST_SNAPBACK}>
Hellish how much heat stretches chains...
#40 Guest_trevini_*
Guest_trevini_*
Posted 29 June 2006 - 08:04 pm
Put 17k miles on my TDM over the last 12 months. Had a Scotty put on from approx 500 miles. Still on original chain and it looks as good as new. Wouldn't consider a chain driven bike without one!
