6039 replies to this topic
#3981 madmopedracer
madmopedracer
  • 473 posts
Posted 16 April 2020 - 04:39 pm
fitted new vacuum fuel pump bike wont start leaving till tommorow then took zorst off for a clean thats my after noon done though the stainless looks nice but im definatly a rider not a cleaner so if anyone wants me to get there bike dirty so the can clean it im your man
#3982 dablik
Posted 16 April 2020 - 04:42 pm
Them's a bugger to prime unless your tanks full, i've stuck a 10" long piece of hosepipe in the petrol cap and used a cloth to try make it airttight and blow it through, worked for me...
#3983 pavel79
pavel79
  • 85 posts
Posted 16 April 2020 - 06:00 pm
My TDM was parts donor :-)
#3984 Studley Ramrod
Posted 16 April 2020 - 06:11 pm
Cool. :good:
#3985 Snowbird
  • 1,475 posts
Posted 17 April 2020 - 06:44 am
Like the clock!
#3986 Bjørge
Posted 17 April 2020 - 08:46 am
...but don't youtr 9er have a clock on the dash ? ...or maybe you forgot how to set it ? I would also imagine there would be better locations for seat comfort  :lol:
#3987 pavel79
pavel79
  • 85 posts
Posted 17 April 2020 - 02:43 pm
It will be a cool watch  :lol:
#3988 pavel79
pavel79
  • 85 posts
Posted 17 April 2020 - 02:48 pm
Keychain for TDM  :rotflmmfao:
There are no TDM parts here :-(
Sorry :-)
Edited by pavel79, 17 April 2020 - 02:50 pm.
#3989 drewpy
  • 1,790 posts
Posted 19 April 2020 - 12:44 pm
took the carbs out and had to drill a seized screw out on the carb top
managed to do it by hand and cut the thread, all good again.
Taking the engine out to fit the new cycle head. Also going to paint engine and check bores etc.
should be fun
#3990 Studley Ramrod
Posted 19 April 2020 - 02:46 pm
Good skills Drewpy, a bit tricky drilling them out eh.
#3991 drewpy
  • 1,790 posts
Posted 20 April 2020 - 12:54 pm
certainly tricky. clamped the carbs in my workmate and was very careful.
not as hard as drilling the exhaust studs though. those were heat cycled hardened
#3992 leehenty
  • 5,325 posts
Posted 20 April 2020 - 02:23 pm
Put a nice new MRA touring screen on it. Ready to tour when they let us out to play.
#3993 drewpy
  • 1,790 posts
Posted 20 April 2020 - 03:49 pm
i've taken mine off for now as it funnelled air directly into my helmet. it improved when I raised the whole thing off the fairing by 10mm. makes linear air flow
#3994 chrisbee
chrisbee
  • 413 posts
Posted 20 April 2020 - 04:50 pm
What did you use as spacers??
I keep meaning to lift mine.
Chris
#3995 leehenty
  • 5,325 posts
Posted 20 April 2020 - 05:35 pm
Black 10mm acetal would work, just drill 5mm hole down the rod part off, job done.
#3996 drewpy
  • 1,790 posts
Posted 20 April 2020 - 06:28 pm
Chris
I used some closed cell foam I had laying around and used that in a strip, bottom 2 were 10mm ally tube with washers.
Lee's way would be neater
#3997 Favs
Posted 20 April 2020 - 06:48 pm
Chris
Ready made............
https://www.ebay.co....353.m1438.l2649
#3998 chrisr
Posted 20 April 2020 - 10:43 pm
Am I right in thinking I would need m5 x 10mm spacers and m5 x 25mm bolts to raise the screen as suggested?
#3999 leehenty
  • 5,325 posts
Posted 21 April 2020 - 08:35 am
Yes, just add 10mm to the existing screw length.
#4000 chrisbee
chrisbee
  • 413 posts
Posted 21 April 2020 - 09:39 am
I have just had a thought regarding this 10mm spacer modification...
instead of 10mm in all 6 fasteners,  how about  5mm [bottom] 10mm [middle]  15mm [top]  this would adjust the rake of the screen.
or try it the other way 15mm at the bottom, and 5mm at the top...
this is just a thought....  has anyone tried it?
