6039 replies to this topic
#4081 chrisr
Posted 28 May 2020 - 07:39 pm
Busted! Oh, sorry......
#4082 drewpy
  • 1,790 posts
Posted 28 May 2020 - 08:19 pm
Replaced my rear disc and pads, bled and replaced
brake fluid...Shiny!
Oh, and ordered a new lid, gloves and boots.
on my metmachex, i put the axle nut on the other side same as the original.
Any advantage the other way?
#4083 Favs
Posted 28 May 2020 - 09:07 pm
Filled up - spent 6 hrs in the saddle - covered 248 miles on some very
minor roads. Only 1 gay ted road.
#4084 wicklamulla
Posted 28 May 2020 - 10:10 pm
   3VD rear axle is meant to be installed left to right, 4TX  right to left.
#4085 Studley Ramrod
Posted 29 May 2020 - 07:53 am
Prolly because the 3VD has a castellated nut and the 4TX has a nylock type nut.  I'm assuming that if the axle siezed on the wheel, the nut can't spin itself off.
#4086 butcher650
butcher650
  • 618 posts
Posted 29 May 2020 - 08:02 am
Its always been like that Drewpy, I've not changed it!
#4087 Studley Ramrod
Posted 29 May 2020 - 08:09 am
Is there a hole in the end of your axle for a split pin to go in Butch ?  If there is then ya need a castellated nut, if not then prolly better to fit the axle the other way around.
Straining at the leash eh.  Certainly a nice day for sweating it out on those twisty, stoney roads. :lol:
#4088 butcher650
butcher650
  • 618 posts
Posted 29 May 2020 - 08:12 am
Theres a groove in the axle on left side just before the end, but no hole in the nut side on the right. Without the axle fully home on the left, it wouldnt pertrude enough to get the nut proper done up like. I did it up to FT then torqued it to 105nm as per heinz.
#4089 Studley Ramrod
Posted 29 May 2020 - 08:17 am
Groovy !  Not sure what you mean really, does the axle head slot into a groove ?   Anyhoos sounds like there's not much you can do to change it.
#4090 butcher650
butcher650
  • 618 posts
Posted 29 May 2020 - 08:21 am
Nope, there is a small groove in the axle just in front of the axle head. Tbf, I've just put it back in as it came out! With grease of course.
#4091 Favs
Posted 29 May 2020 - 08:40 am
Yeah  green up the middle in places & still had 2 bars on the fuel gauge when I got back. I reckon that's 6 hrs of entertainment for £14ish :good:
#4092 Studley Ramrod
Posted 29 May 2020 - 08:41 am
Cheaper than Romania. ;)
#4093 wicklamulla
Posted 29 May 2020 - 09:51 am
do ya know if Metmachex  utilised the existing TDM axle?  If they did there may be a hole in the end to accept a P clip or split pin.  I decided to retrofit a 3VD axle, castellated nut and P clip to my 4TX simply because it makes setting up the Scottoiler bracket that is slid onto the axle easier and it makes the boike go faster.
#4094 butcher650
butcher650
  • 618 posts
Posted 29 May 2020 - 10:25 am
Not a clue wicky, it already had the metmachex when I got it too!
#4095 leehenty
  • 5,325 posts
Posted 29 May 2020 - 11:46 am
Took it for its annual tyre kicking session
#4096 drewpy
  • 1,790 posts
Posted 29 May 2020 - 12:15 pm
just swap round the plastic inserts. mine is on the other side and I have scotoiler too
nylon locknut is standard on metmachex
#4097 leehenty
  • 5,325 posts
Posted 29 May 2020 - 12:51 pm
Planning a 120 miles each way ride to meet up with brother and mate for a socially distanced brew up. Honda Crosstour and ST 1300 Pan Euro riders. They keep saying I'm two cylinders missing.
#4098 wicklamulla
Posted 29 May 2020 - 01:44 pm
Crossdresser and a 9er pilot is a love match made in heaven  :wub:
#4099 leehenty
  • 5,325 posts
Posted 29 May 2020 - 03:28 pm
Looking good for 18 years old.
Tomorrow is take her for good run clear out the cobwebs.
Edited by leehenty, 29 May 2020 - 06:33 pm.
#4100 sidestand
Posted 29 May 2020 - 07:20 pm
Nice ! - Is it lowered ? or is it just the angle of the shot?
