6039 replies to this topic
#4141 leehenty
  • 5,325 posts
Posted 06 June 2020 - 02:40 pm
Just a round bit with a 26mm slot milled through. Easy to make. Just need internal dia and I'm set.
#4142 Snowbird
  • 1,475 posts
Posted 06 June 2020 - 03:45 pm
Do it on the end of a 3/8 socket and easy to post too, just need a long extension bar.
I assumed it'd be a hex.
#4143 leehenty
  • 5,325 posts
Posted 06 June 2020 - 04:37 pm
I can do that sure
#4144 dablik
Posted 06 June 2020 - 05:32 pm
Ah I see, didn't realise! I'll bear that in mind next time. Just went out to shed to check the one I can't quite torque, and I'd stood it up in a tub just in case it leaked, and there was prob 3 or 4 drops in there, so better than I'd expected. If this dam rain stops today I'll get it back on bike and hopefully torqued. If not, and anymore oil dribbles, I'll open the top and just pop a few drops in when I can get it back on.
Er scuse, did you read the post up there, trying to help, it's a simple way without special tools.
#4145 Favs
Posted 06 June 2020 - 07:09 pm
Bought it a 3 tooth less rear sprocket (39) as a motorway fuel economy device - cruising speed will be about 400RPM less than 42 tooth and a cruise of 260 minutes (Durham to Farnborough) means a theoretical 260x400 =  104000 less revolutions each way. If you divide by 4 (fuel strokes) that equals about 50000 fuel injections less per return trip = it won't take long to get my £15 investment back.....will be fitting it ASAP and reporting a while dafter.
Please - no comment about having to rev harder to get going etc. This is intended as Mway test.
Edited by Favs, 06 June 2020 - 07:11 pm.
#4146 Kelpie
Kelpie
  • 944 posts
Posted 06 June 2020 - 07:16 pm
Rode the twins to Milford on Sea for fish n chips in a gale.  Yum!
#4147 butcher650
butcher650
  • 618 posts
Posted 06 June 2020 - 08:30 pm
Apologies Dabs, I hadn't seen your post. Must've missed it in the madness. I'd be interested to know what the other end of the broom handle/wood stick looks like!
#4148 dablik
Posted 07 June 2020 - 07:47 am
Dont have a photo but whatever you use you simply need to cut the end into a wedge shape so that it wedges between the flat side of damper rod and the wall of fork lower, this will prevent twisting, if you fit it to a work bench as i did do NOT tighten the bolt through the caliper bolt bracket up tight, just firm as you dont want to snap it, set up like this made tightening those bolts up a doddle..
Edit... i made my wedge approx 2-3" long.
Edited by dablik, 07 June 2020 - 07:48 am.
#4149 Rallyist
Posted 07 June 2020 - 08:01 am
Did that on mine years ago to get the annoying vibration resonance at motorway cruising speed doesn't make any real improvement on fuel consumption. :good:
#4150 Favs
Posted 07 June 2020 - 08:06 am
Ta, on a 9er Graham?
#4151 Catteeclan
  • 2,574 posts
Posted 07 June 2020 - 08:21 am
Did this on my last 2 niners but haven't to this one, don't know why although I don't use it for much distance work now.
Glen, getting them bottom bolt tight is often a bugga, but not with an air gun. I trust you fitted a new copper washer.
#4152 Rallyist
Posted 07 June 2020 - 10:14 am
Yes on my 2003 that my grandsons now got, 'chrisr' road it in France and made some comment as befits a suvener. :good: :hide:  Haven't got round to it on my current one as it is not in need of sprocket kit, maybe next time wheel comes out for a tyre. :good:
#4153 Favs
Posted 07 June 2020 - 10:26 am
Thanks.
#4154 chrisr
Posted 07 June 2020 - 12:01 pm
Racist! I’m sure my comment was very supportive and informative! (No idea what it was though!)
Edited by chrisr, 07 June 2020 - 11:58 am.
#4155 leehenty
  • 5,325 posts
Posted 07 June 2020 - 06:42 pm
Does Brumm count as The North Graham?
#4156 Rallyist
Posted 07 June 2020 - 07:45 pm
Lee anything above watford is the north according to suveners :hide:
#4157 steve27bha
  • 797 posts
Posted 07 June 2020 - 10:28 pm
Howzabout this item - wedge in metal on a 3/8 socket. £16 eBay
https://www.ebay.co....8.c100290.m3507
Edited by steve27bha, 07 June 2020 - 10:28 pm.
#4158 chrisr
Posted 07 June 2020 - 11:42 pm
Too right guvnor!
#4159 PICARD
  • 1,786 posts
Posted 08 June 2020 - 06:15 am
Doh!! That's almost exactly what I used, but mine was fettled from something I found in my old dad's tool box.
I'll try to post up a pic and dimensions when I get home . Thought I'd invented something!
#4160 leehenty
  • 5,325 posts
Posted 08 June 2020 - 07:38 am
Ooh I'm officially a Northerner then.
