#4161
Posted 08 June 2020 - 07:44 am
#4162
Posted 08 June 2020 - 10:25 am
Howzabout this item - wedge in metal on a 3/8 socket. £16 eBay
Just the job that ![]()
Sorted and on the Road Mick
#4163
Posted 08 June 2020 - 01:35 pm
#4164
Posted 08 June 2020 - 04:07 pm
The finished job is brill, crackin job Lee ![]()
#4165
Posted 08 June 2020 - 04:41 pm
To hold a fork damper rod still I just used some 22mm copper pipe and kept squashing the end until it wedged in the rod end,cant remember what fork it was now.It dosent take much to hold the rod still.
#4166
Posted 08 June 2020 - 05:06 pm
#4167
Posted 08 June 2020 - 07:08 pm
made this for me niner,
bit of help from me Back and Decker drill,and polishing mop
this metalwork malarky is easy
#4168
Posted 08 June 2020 - 07:38 pm
installed the pistons tonight.
who's idea was it to use the strongest circlips in the world? ![]()
took me an hour to put two in. lucky i kept the original inside two in.
for reference; clip one end into the piston at quarter past, then pull the other end in as close as poss. this leaves a ring showing. careful push the ring in in increments using a flat bladed screwdriver. stuff rags in the crank too as a few times they pinged off.
haynes just says install circlips
having a brew as my fingers are aching and drew blood too
#4169
Posted 08 June 2020 - 08:08 pm
#4170
Posted 08 June 2020 - 09:24 pm
They usually ping off into the darkest corners of the workshop... Leading to much profanity
The rumour was that Neil Armstrong found one on the surface of the moon.....!
#4171
Posted 09 June 2020 - 06:09 am
plenty of profanity for two little bits of wire
#4172
Posted 09 June 2020 - 06:50 am
The surface of the moon is better than in the crankcase while assuming it's in the corner of the workshop somewhere.
#4173
Posted 09 June 2020 - 10:54 am
The tool I came up with this afternoon.
Fancy rattling off one fer me please when ya get a chance. No rush though. Oil need payment details though. I wonder if ya shud start a thread showing all of the modified TDM parts that you have made and are available?
#4174
Posted 09 June 2020 - 01:00 pm
Posted 09 June 2020 - 04:56 pm
Fitted the adjustable levers I bought last july, had to modify the front brake lever as it was totally wrong for the original master cylinder as well as the 9er one I have fitted now.
£16 off fleabay, I'll see how they go when I get round to riding it next.
20200609_172458.jpg 141.67KB
0 downloads
20200609_172507.jpg 138.86KB
0 downloads
#4176
Posted 09 June 2020 - 07:31 pm
they look very short, hope the leverage is ok on the fingers
#4177
Posted 09 June 2020 - 07:44 pm
#4178
Posted 09 June 2020 - 09:20 pm
They seem ok after a quick run, first attempt was a fail as my modded brake lever wasn't letting the piston back quite far enough and the brake stayed on a bit each time till I had to take the lever off to get back, then found out there wasn't a screwdriver in the toolkit under the seat (doh!), managed to get the pivot bolt out using the edge of a key, very careful ride back with just rear brake.
A quick reshape and another go, this time with screwdriver under the seat, yeah they seem fine leverage wise especially as I found the clutch a bit heavy on standard levers, must be my faggoty small hands struggling with the stretch.
#4179
Posted 10 June 2020 - 05:26 am
#4180
Posted 10 June 2020 - 10:36 am
There are so many reports about certain types of imported short levers locking up front brakes, in a similar fashion to how you've described.
There are a lot of links down this page https://www.gixxer.c...ncement.335452/
1 members, 0 guests, 0 anonymous users
Tor
