6039 replies to this topic
#4201 Snowbird
  • 1,475 posts
Posted 12 June 2020 - 01:23 pm
Went to take the clutch cover off to inspect due to finding it a bit heavy and graunchy to realise just how buggered my clutch cable is, once removed I can barely move the inner, can't belive I didn't just check the cable earlier but it felt not too ba with a lever at each end. :unsure2:
New one ordered from wemoto, cheap slinky glide not oem as I'm far too tight for that.
#4202 leehenty
  • 5,325 posts
Posted 12 June 2020 - 04:39 pm
Took off the chain cover to inspect front sprocket. It's done 32,000 with an oiler for most of that from 3000 onwards.
Surprisingly although showing some wear it's nowhere near replacement, chain is in good condition.
I had already ordered Afam cogs and DID chain thinking they would be near dead, so they will go into the stash.
#4203 PICARD
  • 1,786 posts
Posted 12 June 2020 - 05:18 pm
Not a huge surprise Lee. I did the same at 28k and kept the parts in the garage until 34 when I did the swing arm bearings so put the chain on only because I could. Chain Oilers rule!!
#4204 Bjørge
Posted 13 June 2020 - 02:23 pm
Overhauled rear caliper. Wemoto sent wrong dust seals, but the old ones seemed ok. Just dirty. Left for the night "self bleeding" (locking pedal in down position) after coarse vacuum bleeding.
I do really believe the dry pedal axle was more to blame than crud in caliper seals. Lubed.
Tried to loosen footpeg rubber screws, but being butter steel gave up immediately. Needs to drill out, I guess..
Edited by Bjørge, 13 June 2020 - 02:25 pm.
#4205 leehenty
  • 5,325 posts
Posted 13 June 2020 - 02:30 pm
Fitted headlight protectors from Powerbronze on my steed as I've just replaced a cracked headlight on a Porsche 911 4S. The price was astronomical. Same as Yamaha parts.
#4206 butcher650
butcher650
  • 618 posts
Posted 14 June 2020 - 05:04 pm
Buttoned down the tank, topped up the coolant, and fitted the fairing back on for the first time in 2.5 years - woohoo!@
#4207 madmopedracer
madmopedracer
  • 473 posts
Posted 14 June 2020 - 08:09 pm
replaced the fuel lines bit of a weep from the tap as no fuel in it for best part of 6 months seals have swollen so ok now got a sight overflow from one carb so after expected rain everything off again plastic metaled the threads on the fuel tap so will try to retap them  from memory m5 as they had been retaped m6?
#4208 Bjørge
Posted 15 June 2020 - 04:55 am
Took it for a short spin, and it started spluttering and finally stopped. Would only run idle, but fired off again after some minute.
I suspect water or crud in gasoline. Tank & bowls come off today 😐
Edited by Bjørge, 15 June 2020 - 04:56 am.
#4209 Catteeclan
  • 2,574 posts
Posted 15 June 2020 - 07:34 pm
Drained the tank by riding it. :lol:
#4210 Favs
Posted 15 June 2020 - 08:45 pm
Fitted n wired LED aux dip n hi beams
#4211 PICARD
  • 1,786 posts
Posted 15 June 2020 - 08:59 pm
What's that all about?
I'm assuming to put both front lights on when on dipped beam. Or a meringue?
#4212 Bjørge
Posted 16 June 2020 - 06:12 am
Approx. one tablespoon of water in float bowls.... a little rust in tank, but nowt that would stop it, I guess.
Worse is a rotted inlet tube on muffler. Forgot I had made a patch...which was also rotten. Bought an exhaust tube piece, welding on today.
Managed to loosen footpeg rubber screws with my old impact driver and a hammer👍
#4213 Favs
Posted 16 June 2020 - 08:14 am
HTH Cap'n
My 9er has dip light on when started - no off position
Trashed the table I had here - update soon - here it is....
Attached File  truth.jpg   51.95KB   0 downloads
Edited by Favs, 16 June 2020 - 08:20 am.
#4214 LAURENCEAUX
LAURENCEAUX
  • 233 posts
Posted 16 June 2020 - 09:56 am
Ethanol added to petrol to create a "greener" fuel (e.g. SP-10 in France) is Hydroscopic, meaning it will take up water vapour, which over a prolonged period of time (a Winter layup for example) collects at the bottom of the tank / bowls, to express itself by rough running for a while. Draining down and refilling with fresh fuel should restore smooth running.
#4215 Favs
Posted 16 June 2020 - 04:37 pm
Had  a ride to HD Gateshead with pal Bill to collect his fresh HD. A steady bimble along the coast for chips then home. Some HD £36K - that's a whole street in Hartlepool......
#4216 Studley Ramrod
Posted 16 June 2020 - 05:11 pm
Looking forward to seeing it on Friday, assuming he's saved enough for the petrol to get there. :lol:  £36k !
#4217 chrisbee
chrisbee
  • 413 posts
Posted 16 June 2020 - 05:30 pm
£36k 😮😮😮😮😮 on a HD??
#4218 leehenty
  • 5,325 posts
Posted 16 June 2020 - 05:39 pm
Wheeled it out of garage put under cover, to make room for an old Honda that needs work
#4219 butcher650
butcher650
  • 618 posts
Posted 16 June 2020 - 07:05 pm
Insured it!! Woop!
#4220 Bjørge
Posted 17 June 2020 - 05:31 am
Temporary fitment of new input pipe on exhaust. Ready to tack weld in place. Caught by thunderstorm, so'll have to wait...
