Was it this one? If so it was my mates. I had a ride on this a few years ago . A very nice outfit.
Edited by gautrek, 13 July 2020 - 07:01 pm.
Posted 13 July 2020 - 07:00 pm
Posted 13 July 2020 - 08:08 pm
Posted 14 July 2020 - 07:26 am
sat waiting for the postie to bring my carb seal kit from thailand
Posted 14 July 2020 - 11:49 am
Posted 14 July 2020 - 05:33 pm
Put a chain oiler on:
It seems to distribute the oil well across the chain and does not drip on the floor of the garage (so far).
But, as I was passed fast and bluntly by a car after the 1st application of 75W90 oil, I presume they smelled the odor on the exhaust. I must admit this gearbox oil does not smell very nice. Need to obtain a slighter touch... ![]()
Posted 14 July 2020 - 05:38 pm
So how do you adjust/operate it Mipe ? Also, does it have a makers name ?
Posted 14 July 2020 - 06:02 pm
Posted 14 July 2020 - 06:57 pm
75w/90 oil is EP oil and will have lots of sulphur in it. Hence the smell
Ah, that explains a lot, just looked it up. It was a left over from my previous car's geabox oil: 75W90 GL5.
I read that gear oil in general would be suitable, also it's a bit thicker than engine oil, suppose it sticks better to the chain.
You just turn the complete container 90 degrees clockwise, when driving slowly. There is a tread inside it, which makes the container drop, decreasing the internal volume, so the excess oil is forced down the bottom, inside the hose, to the outlet.
It's the exactly the same oiler as the Cobrra Nemo 2, but found this one at AliExpress:
https://www.aliexpre...0277970633.html
Thought I'd give it a try for that price, and simplicity.
Posted 14 July 2020 - 07:31 pm
Posted 14 July 2020 - 08:03 pm
Cheers for the info. ![]()
Posted 14 July 2020 - 10:03 pm
Posted 15 July 2020 - 12:51 pm
Cheers Steve, does it dump a load of oil on the chain, or is it a slow release jobby ?
Posted 15 July 2020 - 03:40 pm
Posted 15 July 2020 - 04:24 pm
Posted 15 July 2020 - 04:52 pm
The smell of speed indeed...
for a more pleasing smell, also the semi-sweetness of Ballistol oil would work, however you never know what that might attract, maybe a swarm of bees... ![]()
Hoever I found the makeshift smokescreen does indeed serve a purpose, for getting rid of some close followers ![]()
Posted 15 July 2020 - 05:50 pm
Those prices on the oilers are reduced since i bought one last year, grab one now.
Sorted and on the Road Mick
Posted 15 July 2020 - 08:23 pm
Ian slowly,
you just turn it 1/4 turn every 130-150 ish miles, when I get a minute arrange a meet up and you can look see,
pity I couldn't make last Sunday
Posted 16 July 2020 - 01:58 pm
I've already got a scottoiler fitted Steve, just curious as to how it worked. Not sure I'd fancy having another item added to the handlebars.
Posted 16 July 2020 - 03:40 pm
painted my tank, then it fell over, so I have to start again ![]()
Posted 17 July 2020 - 02:05 pm
Noooooo!
