6039 replies to this topic
#421 arthurbikemad
arthurbikemad
  • 573 posts
Posted 15 February 2015 - 10:38 pm
Here :-
http://www.loomies.co.uk
#422 TDMick
Posted 16 February 2015 - 12:52 am
Only an hour or so away  :um:
#423 PassTheBuck
PassTheBuck
  • 539 posts
Posted 16 February 2015 - 07:33 pm
did you not have a slice of bread handy on Friday night then buck ?   :dunno:
Wish I had of done ramo. would have been nice with a bit of topbox fluff !!!
#424 Sidarta
Sidarta
  • 845 posts
Posted 18 February 2015 - 12:32 pm
Hi to all!
The carburetors are dismounted (since 02/12/2015) due to new leak (small) gas. My family traveled and decided to observe the mechanism of external movements of carbs (on 02/17/2015). I always thought the heavy accelerator and now with a tendinitis that bothers me on long trips. Cables and wrist still original and in perfect condition, are new. The idea was to reduce the spring pressure. Only in TDM850 to remove the spring, the carbs should be separated and I found complex for the moment. The easiest, went to work in the spring where he was. With the tip of the screwdriver, I took one of the mounting point of the spring ends. The idea was to get an attachment point below the original. It took hours trying to make an attachment point from a stainless steel wire. After much trial, cuts and folds could manufacture 2. The first, the spring pressure was very close to the original. The second had a little farther pin original fastening point. It was very soft, noting that the carburetors were on a table. I installed the carbs in motocileta only for testing and bingooooooooo. The drive was great. Soft and the return was very good, without compromising security. But the motorcycle was not on, the engine oil was drained and the carbs are not set to work.
  After assembly and test (accelerator) the bike on the highway, I will be posting pictures.
I do not know if it would be correct to post here, or open a topic.
  Still observed:
1) the fluid reservoir hose to the radiator presents dryness.
2) screws of the clips of carbs (admission) should be replaced
3) castings rubbers (right and left) receiving the pins of lateriais fairings are resected.
4) best place to install oil pan (current lubricant) and hose passage leading the oil to the chain.
I have a project (Scottoiler - own manufacture)
Cheers!
Edited by Sidarta, 18 February 2015 - 12:34 pm.
Att
Sidarta
TDM850 ano 2001
 Honda XLX 250 1988
Honda CB350 1972 e 1973
#425 muddy
Posted 18 February 2015 - 02:47 pm
Oiled, filtered, & hopefully assembled correctly(I do dislike piddling about with that filter housing, apart from the cheap filter factor). Too scared to use my new torque wrench as yet, so use feel to tighten the bolts.
#426 arthurbikemad
arthurbikemad
  • 573 posts
Posted 18 February 2015 - 04:23 pm
Defo feel, nip them up is all they need imo, even a quality snap-on torque wrench (not saying that yours in not qual) can easily mislead you into pulling threads, so many people I know think a torque wrench is the end of snapped bolts etc, problem is unlike you they forget to feel whats going on and wait for the click/buzz and ping they snap bolts or strip threads!
Gutted I did not get out today :( And now they say rain is inbound for the rest of the week...
#427 harvey krumpet
harvey krumpet
  • 2,065 posts
Posted 19 February 2015 - 08:50 am
Yeah, a nips a nip. The smaller the bolt the smaller the leverage but when it's in it's in.
#428 muddy
Posted 19 February 2015 - 09:06 am
I probably do a nip and a a bit by going round again, for peace of mind's sake. I came off and smashed up my bike and body as a result of not doing the housing up correctly one time.
#429 Staffy
Staffy
  • 223 posts
Posted 20 February 2015 - 08:00 pm
I usually use that old fashioned torque wrench with a few different settings on it. The settings are: finger tight, tight, very tight, very very tight, bloody tight, really bloody tight, and ferking tight.
#430 harvey krumpet
harvey krumpet
  • 2,065 posts
Posted 20 February 2015 - 09:03 pm
A mate of mine was renowned for snapping spanners........
Was watching Lyndon Poskitt tightening his nuts with one of THESE.
A mere $1540 US.
#431 arthurbikemad
arthurbikemad
  • 573 posts
Posted 20 February 2015 - 09:47 pm
I have three techwrench by SnapOn, love them but Id opt for feel on my oil filter housing :)
Edited by arthurbikemad, 20 February 2015 - 09:48 pm.
#432 Staffy
Staffy
  • 223 posts
Posted 20 February 2015 - 10:52 pm
Yep. I tend to pick and choose when feel suits better than precision.
#433 RolfieB
RolfieB
  • 1,069 posts
Posted 21 February 2015 - 04:15 pm
Oil & filter change.
Swapped my radiator guard for a stainless one I've had for a few months (this required drilling off the heads of the screws).
.http://s1067.photobu...html?sort=3&o=0
Now I just fly everywhere.
Gone to new owner.
Black Mk2a
#434 PassTheBuck
PassTheBuck
  • 539 posts
Posted 21 February 2015 - 04:17 pm
Took her too Asda and filled her up. £19 crackin !!!
#435 Guest_adtone_*
Guest_adtone_*
Posted 21 February 2015 - 07:43 pm
Busy one for me. Would have loved to scoot out for a while but finally got around to fitting the goodies i bought last year ( i picked my bike up last September and haven't ridden much at all since then ).
First up was a dual USB Socket which I picked up from Maplins ( They are on sale again now ) - http://www.maplin.co...CFagfwwodZDYA9Q - solid bit of kit !
I fitted under the seat at the rear section and its mainly for charging a phone on the go or if I ever get the urge I can run a really long extension to it for a sat nav or similar. I wanted it hidden away so that it keeps the externals/dash uncluttered.
I wired it in to a relay and tucked / routed the wiring away all nice and tidy. Its fixed down with the supplied bracket and 3M.
Next up was a pair of Keis Heated Grips ( Another excellent bit of kit ). I have fitted these to all my recent bikes ( even my last 'blade ! lol ). Again, tidied away the wiring and ran these into the same relay as the USB charger to be on the safe side. I just need to sort out some tidier bar ends as the heated grips are around 20mm shorter than the stock grips. They are toasty though !
Nice quick bit of tarting up - an R&G shock tube as the rear spring is in such good nick it would be crazy not to. Really easy install.
And last but not least while I had the fairing off doing the grip wiring install I took the opportunity to do the JBX Air Intake mod by popping out the corresponding actuator/solenoid pin from the ECU plug and sealing it up.
All in a good days work !
Tone
#436 muddy
Posted 21 February 2015 - 08:41 pm
Shouldn't that be shock sock :)
Welcome to the fold.
#437 arthurbikemad
arthurbikemad
  • 573 posts
Posted 21 February 2015 - 08:58 pm
Can he do that? Can he come along and post 1 post with half images of his bike, I mean....lol Where are the full size pictures :D
#438 Guest_adtone_*
Guest_adtone_*
Posted 21 February 2015 - 09:14 pm
Haha, less is more, less is more !
Ive been a member for a wee while but just realised that this was my first post. Ill put some pics up in the show off section.
T
haha, it says Shocktube on it - unless I'm missing a joke ! lol  :lol:
#439 arthurbikemad
arthurbikemad
  • 573 posts
Posted 21 February 2015 - 09:17 pm
Ah cool, then the balance is restored :D
#440 Jole
Jole
  • 26 posts
Posted 22 February 2015 - 03:46 pm
Hi All ,
I have ordered these hanguards , so I am wondering does anyone already put them on TDM 900 ?
1C3F031C-A97F-DE4D-B1BD-1C61A2EE6BFB_thu
(Powered by frubar.net)
