6039 replies to this topic
#4401 Navigator1946
Navigator1946
  • 75 posts
Posted 09 August 2020 - 11:28 am
Social networking at its best! I've just fitted one of Rafals big foot side stand extender and I'm dead chuffed with the result. I'm having the Rafal crash bars fitted on Thursday, to replace the standard (Yamaha?) engine protectors, which will then be sold on here. Lee (Hendy) has fitted Rafals centre stand and big foot, and Steve will get his Rafal big foot shortly. And if anyone thinks they're missing out, I still have one Rafal big foot, in black, for sale at £35. It just shows the value of this site in uniting owners for their mutual benefit.
2008 TDM900 in beautiful black.  Fender extender, after market Bullster touring screen, radiator guard, RM-G crash bars, 12V/USB socket, Oxford heated grips, Bagster tank cover, centre stand, E22 Givi panniers, standard exhausts. Beautiful Acerbis hand guards. <p>2015 Honda Crosstourer Highlander dct. Fabulous bike, but getting heavier as I age. The 9er is its replacement, eventually.
#4402 leehenty
  • 5,325 posts
Posted 09 August 2020 - 02:01 pm
Refurbished rear caliper new stainless piston and seals old ones got overheated. Fitted Rafal's centre stand 60 mm wider in feet than standard which gives good stability. Then fitted his very nicely engineered big foot. Then just cleaning and oil and filter change.
#4403 Bjørge
Posted 09 August 2020 - 03:18 pm
Changed fuel tank cap, hope this keeps rain out....
Tried to swap locks to avoid another key, but internals were different 😐
Now a few kms to reduce fuel level in tank before draining an cleaning filters
#4404 Favs
Posted 13 August 2020 - 09:17 am
Done a couple of hundred miles with recent clutch spring set up, seems ok
39T rear is a little tall and you can tell on on both Mway, A, n back roads. It is OK though and the engine is a lot more relaxed at Mway work.
Stoner T31s seem ok in the damp but I haven't had a real wet test yet as if was too foggy this morning to go fast enough
Edited by Favs, 13 August 2020 - 09:18 am.
#4405 Rallyist
Posted 13 August 2020 - 01:14 pm
Yes found that but at the higher cruising speeds I found less tingles. :rotflmmfao:
#4406 drewpy
  • 1,790 posts
Posted 13 August 2020 - 02:11 pm
changed rear disk as it was hard to use being warped and nearly fell off as it gripped.
Checked bearings in rear wheel while the wheel was off and the sprocket bearing was grinding, prob only done 4k on it and was a SKF bearing too.
New one ordered from simply bearings in leigh
Edited by drewpy, 13 August 2020 - 02:11 pm.
#4407 Navigator1946
Navigator1946
  • 75 posts
Posted 13 August 2020 - 10:03 pm
Rafals crash bars and light brackets fitted today with some LED running lights. Serious protection for the fairing, I think. Also sold the last of the big feet.
#4408 leehenty
  • 5,325 posts
Posted 14 August 2020 - 07:32 am
Those crash bars are great
#4409 leehenty
  • 5,325 posts
Posted 14 August 2020 - 12:25 pm
I thought on very tight steep hills in Lake District the gearing was slightly too tall as standard.
#4410 leehenty
  • 5,325 posts
Posted 16 August 2020 - 11:47 am
Fitted me control box for the oiler and plumbed into existing Scott oiler as still waiting for tank to arrive. Eventually the scottoiler will go and vacuum port blanked off.
#4411 Bjørge
Posted 19 August 2020 - 06:13 am
Removed tank, cleaned it using the nuts'n bolts trick (anyone explained how to get the scrap out afterwards? I needed to use a neodymium magnet taped to a stick...).
Tank full of water and red rust-gunk.
Removed and cleaned float bowls. Hopefully the new fuel cap will stop this from happening....
Tried to lower the needles one notch, as I suspected it to run a tad bit rich. Test ride- seemed like this made it a bit lean - backing off the throttle a few degrees made it pull stronger under heavy load.
So - set clips back to middle notch.
Reset pilots to std 3 turns out, attached my new €12 vaacum gauges and adjusted balance. It was noticably out, ticked over much smoother after adjustment.
As I didn't have my jump leads at hand, I resorted to install battery upside down lying on top of frame to make room for adjustment. Worked a treat
Discovered a couple of new cracks in fairing mounts, so have to deal with them before reassembly.
Phew!!!
Edited by Bjørge, 19 August 2020 - 10:18 am.
#4412 Favs
Posted 19 August 2020 - 08:00 am
:good: Nice work.
I used clay bar on tank after I finished washing (etc.), the car this morning - surprised how rough paint was on both.
#4413 Bjørge
Posted 21 August 2020 - 10:59 am
Fixed cracks in 2 plastic parts, a bit worrying seeing them fall into pieces being 27 years old....
The superglue+powder kit seems to work well !
Took it for a 40km drive, definately runs better after balancing carbs  :)
#4414 Navigator1946
Navigator1946
  • 75 posts
Posted 21 August 2020 - 09:31 pm
First night out in the dark on the 900 last night. The dipped beam would make a good anti aircraft searchlight, and the running lights on the crash bars were looking for worms six feet in front of the bike. I found the downwards adjuster, but it seems to turn many times to get the lights lower. Still a bit high now but better, and the bar lamps will now blind everyone who sees me!
#4415 Bjørge
Posted 25 August 2020 - 05:50 am
Put threaded inserts in fuel tap. Cheapo ones, worked well. Think that's the softest metal I ever drilled...which was good as I could do it holding it with one hand and lines attached 😀
#4416 leehenty
  • 5,325 posts
Posted 26 August 2020 - 06:17 pm
Crashed it in soft grass at less than walking pace. Ran off road into soft mud and it tipped over. Rafals crash bars held it up in the mud and grass. No damage at all not even a scratch.
The ford before was a bit of an oo er moment when it turned out it was deeper than I thought. Air bag vest deployed so that's cost me a new gas cylinder.
Edited by leehenty, 27 August 2020 - 07:06 am.
#4417 Snowbird
  • 1,475 posts
Posted 26 August 2020 - 06:34 pm
I'm not surprised it fell over, the world is the wrong way up.
#4418 leehenty
  • 5,325 posts
Posted 26 August 2020 - 07:06 pm
It's ok on my phone something's gone tits up
#4419 Favs
Posted 26 August 2020 - 07:10 pm
All ok  :good:
#4420 wicklamulla
Posted 27 August 2020 - 12:46 am
Yer still smelling of roses though!
