6039 replies to this topic
#4421 dablik
Posted 27 August 2020 - 07:44 am
Put threaded inserts in fuel tap. Cheapo ones, worked well. Think that's the softest metal I ever drilled...which was good as I could do it holding it with one hand and lines attached
Which kind have you used Bjorge ! i made a couple of spacers for mine and loctite but i think an insert would do the job better.
#4422 Bjørge
Posted 27 August 2020 - 01:10 pm
This kind: https://www.biltema....tser-2000022481 (some £77)
Another local supplier of mine asks ~£60 for the same kit.
#4423 Bjørge
Posted 28 August 2020 - 05:35 am
Heading west today, some 480kms. Nice weather, hoping the old cow stands the test 😎
#4424 wicklamulla
Posted 28 August 2020 - 07:36 am
thas a long run,  good luck and enjoy it.
#4425 dablik
Posted 28 August 2020 - 03:37 pm
A helicoil then, crikey they would need to be small..cheers.
#4426 MickC
MickC
  • 432 posts
  • TDM model: 1995
Posted 29 August 2020 - 08:35 am
Did the same to mine useing these,I paid abbout £20 ish.
https://www.ebay.co....6YAAOSwh8xfP6IH
#4427 Norwegian
Norwegian
  • 162 posts
Posted 29 August 2020 - 11:24 am
Yup, same kit (I have the £60 version Bjørge referred to).They don't ship to Norway, unfortunately. And if they did, P&P plus tax would triple the price. One of the consequences of not being part of the EU ...
Edited by Norwegian, 29 August 2020 - 11:25 am.
#4428 Bjørge
Posted 31 August 2020 - 06:55 am
~600 miles covered this weekend  :P
Bike runs good, suspension is delicious but it is a bit thirsty  :huh:. 53MPG as opposed to 58-65 previously (non-motorway speeds - 60-100 kph).
It seems like there is no gain in mileage from driving calmly, which I have never experienced from a vehicle...
The engine has made 115,000kms, but it runs nicely - I just can't believe the problem is related to poor compression from worn cylinders, pistons or leaky valves.
I overhauled carbs because of an increasing consumption a few years ago. I'm not positive it has ever returned to "normal" (for my driving style, that is) consumption, although I have believed so a couple of times. I have now started to fill gas with bike on main stand, as this seems to result in more concequent filling level. I suspect previous readings were abit accidential.
What's on my list to figure out, then, is:
- Fuel level. Not sure if they're right. New check needed.
- Emulsion tubes. They're Factory pro, and I believe they're like 20,000kms old. I have a new set of brass ones, could swap them and check.
- Choke mechanism (new plungers installed). I added a spring to retract choke once you let the knob go, as it wouldn't return properly due to a worn slider. I have checked it time and again, and it seems to return properly now.
...yes, and fork seals are shot, but that's okay as they're ~12 years old.
#4429 qual
qual
  • 20 posts
Posted 06 September 2020 - 06:00 pm
Well i tried to adjust my chain.. i found the right side chain adjuster bolt didnt want to move and the head seemed to be made of cheese.... ive bolted it all back up now and would like to replace those bolts, any recommendations or are any of the titanium ones on ebay ok as a replacement?
Thanks all :-)
#4430 Studley Ramrod
Posted 06 September 2020 - 06:02 pm
Lee Henty might have some Brass ones, bolts that is. :D  Send him a pm. :good:
#4431 qual
qual
  • 20 posts
Posted 06 September 2020 - 06:35 pm
Cool im hoping to catch him for a service so that may work , are they prone to seize up ?
#4432 dablik
Posted 06 September 2020 - 07:20 pm
The right side is if not maintained, suspected that the left side is kept un-siezed from chain lube fling.
#4433 leehenty
  • 5,325 posts
Posted 08 September 2020 - 09:44 am
Brass ones and 2.0D helicoil if the thread comes out usually fixes it.
#4434 GeneralBozo
GeneralBozo
  • 92 posts
Posted 15 September 2020 - 09:03 pm
Mopped up the oil from inside the grey connector block and connection on the regulator/rectifier. Looks like it's been seeping up from the engine through the inside of one or more of the three cables in the bunch (wtf?!).
#4435 LewisBlackburn
LewisBlackburn
  • 1,748 posts
Posted 16 September 2020 - 01:55 am
Just put it up for sale  :unsure2:
http://www.carpe-tdm...showtopic=37397
#4436 bowie
bowie
  • 10 posts
Posted 20 September 2020 - 05:50 am
I just finished cleaning it kinda!
https://photos.app.g...jzyAyUFM6q4Trr6
It's new to me, so it was enjoyable to take all the bits off and get friendly with it.
The wheels are sh1t, and that's right, they have to be shinned up too.  Can't wait!
#4437 LAURENCEAUX
LAURENCEAUX
  • 233 posts
Posted 27 September 2020 - 09:17 pm
Identifed a potential rust problem. Whilst poking about I saw what looked like rust on the metal pipe connecting the water pump to the elbow on the cylinder head. Poking a small mirror in shows definite corrosion on the side facing the engine.
I thought oh I'll just replace that then. Nearly £12 at Fowlers plus O rings for a bit of squashed steel ! And on back order no stock.
Looking through my box of bits I got an old one more corroded than mine so measured up and made myself one in 316.
I also spotted rust last time I strip serviced my bike. Behind the rad on top of TDM 900. Treated with Kurust and a dollop of Hammerite.
#4438 fixitsan
  • 4,852 posts
Posted 28 September 2020 - 12:35 pm
Thanks all :-)
The head of my RH adjuster snapped off while trying to remove it. I thought if it's seized it can stay in, and a slipped one of these over the top of it, and now it's a stud adjuster :) https://www.ebay.co....67304ab59f3c905
#4439 Favs
Posted 29 September 2020 - 03:31 pm
120 miles round N Yorks - lots of bikes out & lots of camera vans too
#4440 Muppdog
Muppdog
  • 305 posts
Posted 02 October 2020 - 08:14 pm
MOT today! No bother at all.
Afterwards a run down to the Lighthouse on the Mull of Galloway. A friend recommended it and it did not disappoint. Stunning. Good cake as well.
