6039 replies to this topic
#4501 PICARD
  • 1,786 posts
Posted 28 November 2020 - 03:26 pm
There you go.
#4502 fixitsan
  • 4,852 posts
Posted 28 November 2020 - 03:38 pm
There you go.
Looks great with the black scheme
#4503 Jim55
Jim55
  • 41 posts
Posted 28 November 2020 - 06:30 pm
Washed bike for first time and discovered I have one black wheel and one blue !!! Changed cans to black widow ones , realigned wonky rear number plate Hugger back on ,much fettling was done😊
#4504 Favs
Posted 29 November 2020 - 11:28 am
Remembered to put the battery on charge - standard 12v charger on a timer switch gives 3x 10 minutes every day - enough to keep battery fully charged & stop furrycellulitis
#4505 fixitsan
  • 4,852 posts
Posted 02 December 2020 - 08:09 pm
Finished putting my 900 back together with a few new clips, a bit of paint brushed onto the luggage racks, cleaned and lubed the CSM, checked the nuts and bolts for tightness.
Going to try to get an MOT this weekend
#4506 fixitsan
  • 4,852 posts
Posted 03 December 2020 - 10:48 pm
MOT booked for Saturday morning....Central Scotland....December.....snow and ice forecast....5 miles.....it can go one of two ways.... :)
#4507 fixitsan
  • 4,852 posts
Posted 05 December 2020 - 11:34 am
MOT passed for another year.
The tester talked about 'not making them like they used to', when he compared the good condition of my bike with 106,000 miles, and a 2 year old MT-09 with rusty frame.
Looking forward to getting out on it now. I only did 10 miles today but the Samios remap, 15t front sprocket and full bore db killers to replace the old narrow outlet db killers all seem to be working well together :)
#4508 Catteeclan
  • 2,574 posts
Posted 06 December 2020 - 10:01 am
Fills me with confidence. Haven't spotted any rust yet but the front brake is being a right pain.
Had what I thought was a buggered disc. Took it to work and clamped off the end calliper, dropped the bike in the rolling road and could see the a variation in the reading so order a new disc.
Once fitted the brake was still the same. Took the wheel to a machine shop to have the mating surfaces checked with no faults found so now I have the second disc to fit.
Should have looked into it when it was still in warranty but just kept thinking I'd got a bit of polish or something on there.
#4509 fixitsan
  • 4,852 posts
Posted 06 December 2020 - 10:22 am
My 3vd rear wheel was similar. Knowing the previous owner ran it with a seized rear caliper until the disc glowed, I changed the disc and found it was still warped. Actually the wheel was warped due to heat exposure ! (suspect that won't be your fault !)
#4510 fixitsan
  • 4,852 posts
Posted 06 December 2020 - 01:58 pm
Had a decent ride of 70 miles or so. I had forgotten what riding a comfy bike was like, compared to the old KTM with bench seat.
Nice strong pull through all the revs, nice handling even on wet roads. Nice to be back on it again :)
#4511 Jim55
Jim55
  • 41 posts
Posted 09 December 2020 - 07:38 pm
Just fitted crash bungs/ sliders ,I didn't know torque setting so I just done them.up ft and a bit of locktite😎
#4512 Bjørge
Posted 10 December 2020 - 06:41 am
Looked for the reason it only ran on one cyl 2 weeks ago - emptied tank and float bowls. No water whatsoever - which is good as it means the new tank cap keeps water out - but means there is another reason for skipping one cyl...
It might be the tiny rust particles in carb bowls, cleaned them and the jets. It started right up, test drive today
#4513 laurient
laurient
  • 6 posts
Posted 10 December 2020 - 07:05 am
Attached File  DSC01216.JPG   91.61KB   1 downloads
Front tyre ( Pirelli mt60 ) i am a convert to the cable tie method of fitting now  :good:
#4514 fixitsan
  • 4,852 posts
Posted 10 December 2020 - 08:11 am
I had a pair on my KTM 620. I thought they were outstanding in the wet (I heard some supermoto riders use them as their rain tyre)
I got 900 miles on the rear and about 1500 on the front, which I thought was awful, but then again I enjoyed every mile I did
It will be good to see how long it lasts on the heavier TDM
#4515 Studley Ramrod
Posted 10 December 2020 - 02:45 pm
That's the one. 46% vol. And smooth as......struggling to find a Welsh smooth thing for comparison.....but, nice!
Just bought a bottle of Penderyn as a xmas pressy to me from Ma. :)  on offer at Tesco £26, that's the Penderyn, not me Ma.
#4516 Sphere
Sphere
  • 81 posts
Posted 10 December 2020 - 11:24 pm
Ahhhh! Penderyn!  Finest Welsh nectar. I usually have a bottle at Christmas.   Loverly, enjoy!
#4517 PICARD
  • 1,786 posts
Posted 11 December 2020 - 08:00 pm
Ooooooh....on my way!!
#4518 Jim55
Jim55
  • 41 posts
Posted 12 December 2020 - 11:03 am
Fitted aux lights ,ran cables but no time to connect up last night ,also changed wee sidelight bulb to led
#4519 Bjørge
Posted 13 December 2020 - 12:40 pm
No luck, same problem....
It runs semidecently when cold, starts skipping severely after a coupla minutes.
Found out it actually runs good on high rpms, is that an indication I should investigate the coil? And if so, could I spot the fault by attaching a timing lamp? Assuming it fails on one cyl while revved at a standstill, I would maybe see tve failing spark pulse?
Edited by Bjørge, 13 December 2020 - 12:40 pm.
#4520 fixitsan
  • 4,852 posts
Posted 13 December 2020 - 01:13 pm
That's an excellent solution I reckon.
I was shopping in 'The Range' yesterday and found a 7-day timer for my Christmas lights, costing £3.99. A digital version was £6.99.
Rebuilt the front calipers, after the MOT tester noted they might not be releasing fully.
A full set of new seals and steel braided hoses fitted. All good now :)
