6039 replies to this topic
#4741 AliG
Posted 17 May 2021 - 07:49 am
Been a busy boy. New back tyre, rear disc and pads and oil change on the white one. New stator and oil change on the blue one. That has been sitting on the ramp for 9 months but fired up instantly. I must have done something wrong, cos there were no extra bolts left when everything was put back together. Oh and thanks once again to Celticbiker for that stator change write up. I did refer to the pics a couple of tmes,just to makesure that I was re-instating everything correcty. Ready for next weekend now.
#4742 leehenty
  • 5,323 posts
Posted 18 May 2021 - 07:37 pm
Gave it a new set of EBC HH pads all round. Sportsbikeshop are currently offering 30% off so I stocked up.
#4743 JohnnyW
JohnnyW
  • 313 posts
Posted 18 May 2021 - 07:41 pm
Took it on a 60 mile round trip for it's MOT which it passed with flying colours.
#4744 Favs
Posted 19 May 2021 - 01:17 pm
Tested the new rear shock - much faster cornering ;)
#4745 Studley Ramrod
Posted 19 May 2021 - 02:01 pm
Money well spent eh Favs.
#4746 dablik
Posted 19 May 2021 - 03:33 pm
Oh fook off you  :lol: like ya needed to be faster eh  :P
#4747 Favs
Posted 19 May 2021 - 07:07 pm
@SR massive grin today n seems worthwhile.
@ Dablik  :rotflmmfao: I'm the steady away one.
#4748 dablik
Posted 19 May 2021 - 08:44 pm
You obviously have a much thicker throttle grip than me  ;)
#4749 Robbo622
Robbo622
  • 11 posts
Posted 20 May 2021 - 05:38 pm
After getting my TDM 900A to start after adjusting the valve clearances (see "where have they hidden it"), I would like to claim the record for removing and fitting the seat, tank, airbox and fairings in the course of doing one job.
Had to strip it down after test run revealed coolant leak from pipe in cam cover. Then had to strip again after forgetting to re-connect the induction air temp sensor under air box. Then found I'd reconnected the small pipes from the rad the wrong way round, more coolant pissing everywhere...
Then I decided to service the cold start plunger, ordered replacement stainless screws as recommended, but found the steel pin firmly stuck in the half way position. Someone before had had a go at it, mole grip marks on the pin and it looks a bit bent. Best I could do was to tap it out to the fully warm position and give it a bit of throttle when starting from cold. I found the idle screw fully closed to reduce the warm tick over so I'll have to tinker with that....
#4750 leehenty
  • 5,323 posts
Posted 20 May 2021 - 05:46 pm
I made a stainless pin to fix this issue for someone Chris R I think, quite a few years ago. His had been squashed too.
#4751 dablik
Posted 20 May 2021 - 06:00 pm
Sorry Robbo but that record distinctively belongs to me i'm afraid  :lol: although you could claim it for the 900 category.
#4752 Snowbird
  • 1,474 posts
Posted 20 May 2021 - 06:57 pm
Like blue and pink catagories of award? :lol:
#4753 Favs
Posted 20 May 2021 - 07:13 pm
Only if the pink be polka dot
#4754 Robbo622
Robbo622
  • 11 posts
Posted 21 May 2021 - 02:24 pm
I'm happy with pink...Thought I'd have another go at the cold start plunger as I'm still waiting for the rubber bellows to arrive. Applied heat and managed to pop the pin out then spent the morning polishing with wet and dry to clean up the pin and the shaft it protrudes though. Finally got it working freely and started re-assembling the bike again but has to stop to go and have my second covid jab...
#4755 Dickiebig
Dickiebig
  • 180 posts
Posted 21 May 2021 - 04:03 pm
https://photos.app.g...ajEBSb8jhCSmt47
I wasn't happy. So turned the backplate round and reduced the height a bit, just in case.
Might go down the hockey puck route yet!
#4756 dablik
Posted 21 May 2021 - 05:56 pm
Does'nt look so bad, maybe a bigger footprint ie, weld a wider piece or epoxy
#4757 leehenty
  • 5,323 posts
Posted 22 May 2021 - 10:26 am
If you measure the diameter and overall length of pin I can make a stainless one for you in a few minutes. I know there is a 0.5mm lip to stop it falling out.
#4758 Favs
Posted 22 May 2021 - 03:01 pm
Fixed the  excellent Fixitsan DRLs as soom fat fingered fool (smee),  had terminated a terminal while doing another job........fully operational once again
#4759 fixitsan
  • 4,852 posts
Posted 22 May 2021 - 03:43 pm
Nice to hear they're still going :good:
#4760 Favs
Posted 22 May 2021 - 07:24 pm
Yup still fine and now over 3 years sterling service, ta again :good:
