6039 replies to this topic
#4881 drewpy
  • 1,788 posts
Posted 14 August 2021 - 06:00 pm
carb parts from Allens came next day, wow
started stripping carbs down to replace emulsion tubes, needles and main jet
clip was on #1 groove which is the lowest/weakest setting.
do you think i should go for the middle setting?
#4882 Studley Ramrod
Posted 14 August 2021 - 09:09 pm
Are the needles standard ? and on no.1 clip position Drewps ?    I've always used factory settings when working on carbs and adjusted from there if need be.  Never had to adjust needle clip position from factory setting (middle) yet.
#4883 drewpy
  • 1,788 posts
Posted 14 August 2021 - 09:34 pm
the setting I had was the top one when taken off the carbs. I suspect that because of worn needle or emulsion tube, it was moved to lower the needle to compensate for this.
I'm going with the middle this time
using mikuni parts
Edited by drewpy, 14 August 2021 - 09:36 pm.
#4884 Studley Ramrod
Posted 15 August 2021 - 02:04 pm
:good:
#4885 Favs
Posted 15 August 2021 - 03:54 pm
Bought it new rubber today
Bridgestone T32s to replace the excellent in the wet T31s
#4886 drewpy
  • 1,788 posts
Posted 17 August 2021 - 08:52 am
using mikuni parts
damn you PO, the left needle was on the #1 groove and the right in the middle, #2.
I've been running that for 7 years now.
just the float height to set and the rain to stop before fitting to the bike
#4887 Studley Ramrod
Posted 17 August 2021 - 10:13 am
Have you had the chance to try 'em out yet Favs ?
Amazing it ran so good eh.
#4888 Bjørge
Posted 17 August 2021 - 02:05 pm
Bought its successor - a new, red Tracer 7
#4889 leehenty
  • 5,323 posts
Posted 17 August 2021 - 04:28 pm
Using my selection of puller's pushers and pinchers I did both sets of fork seals and bushes. All back together and looking good.
Edited by leehenty, 19 August 2021 - 12:34 pm.
#4890 Favs
Posted 17 August 2021 - 06:09 pm
Busy busy - nope
#4891 Studley Ramrod
Posted 17 August 2021 - 08:14 pm
Like a one legged man stomping out a forest fire busy eh mate. Soon be September buddy. :good:
#4892 drewpy
  • 1,788 posts
Posted 18 August 2021 - 06:53 am
Its ali
Its alive, had a lot of trouble getting the right float height set. it was windy and affected the levels.
balanced the carbs and it pulls really well between 2 - 4k revs.
still have a slight blip at 2.5k revs but nothing major and i'm being picky.
The only thing that is bugging me is I had t raise the tickover right in to get 1200 revs, it won't go any further clockwise.
#4893 Studley Ramrod
Posted 18 August 2021 - 03:53 pm
Try fettling the balance screw, you might get the tickover much higher.
#4894 drewpy
  • 1,788 posts
Posted 18 August 2021 - 09:37 pm
carbs are balanced, i suppose i could fettle the mix screws under the carbs. They are se at 2 full turns out.
it fires right up though and revs really easy
#4895 harvey krumpet
harvey krumpet
  • 2,065 posts
Posted 18 August 2021 - 10:13 pm
I've not ridden the TDM in many months and with better weather just around the corner tried to get the old girl started.
Bat flattery.. So I ordered the last remaining one in NZ, or so it seems. What a palaver trying to find one. That was on Sunday. Tuesday we went into lock down, Auntie Cindy is being very stern again.
Luckily courier drivers are essential employees so the battery turned up while we were having morning coffee and the new dog attacked the courier for his sterling efforts, poor bugger nearly crapped himself but didn't drop the battery.
Charged the battery and fitted it, the bike fired up after a couple of stabs but only on one cylinder. I let it run for a bit on choke and it finally cleared out, running properly on both cylinders. I'm quite amazed after the length of time it's been sat covered in crap, cold and damp.
I had forgotten that ET needs to help with removing and replacing the battery box. Pretty sure it's part of the test to join Mensa in Japan..
On the bright side, when we are allowed out to play I can get it legal (WoF / MoT) and learn to ride again.
#4896 Studley Ramrod
Posted 19 August 2021 - 11:42 am
Could it be a twisted tickover cable ?  Just seems odd having to screw it fully clockwise to get 1200rpm.  That said, if it works ok might as well leave as be.
#4897 drewpy
  • 1,788 posts
Posted 19 August 2021 - 08:21 pm
yes, could be.
#4898 drewpy
  • 1,788 posts
Posted 21 August 2021 - 03:41 pm
took my friend to supervise factory this afternoon to see some bikes as he's just passed the A2.
Jaw on the floor moment he saw this
#4899 dablik
Posted 21 August 2021 - 08:43 pm
Been meaning to pop over for a look see, some pretty awful reviews though...
#4900 leehenty
  • 5,323 posts
Posted 22 August 2021 - 02:57 pm
Rode it 135 miles forks are back to normal, but it rained so now I got to clean it... Again
