6039 replies to this topic
#4961 Studley Ramrod
Posted 18 September 2021 - 05:57 pm
Went for a day out with my grandson, couldn't even get an ice cream at New Brighton, looks like the developers are having a hayday there.
Great to see you out riding with yer grandson Graham. :good:
#4962 drewpy
  • 1,788 posts
Posted 20 September 2021 - 01:56 pm
I had one on a Z650 years ago, I seem to recall the head end of the spindle had a keyway and the nut end had a flat so the concentric adjusters were always aligned.
correct, make sit so easy to adjust the chain
#4963 steve27bha
  • 797 posts
Posted 25 September 2021 - 09:00 pm
Fitted a Pyramid extension to the rear hugger. Saw it on eBay new but cheaper than usual.
I used only the four plastic rivets provided to secure it, without the double-sided sticky pads. I had used aluminium pop rivets on the front one I fitted ages ago but decided to go for the hidden effect here.
It's not particularly long but looks OK, methinks. Not been tried on the road yet.
Attached File  DSC02637.JPG   111.83KB   2 downloads
#4964 leehenty
  • 5,323 posts
Posted 26 September 2021 - 01:44 pm
Rode it to rescue another Niner with flat battery.
#4965 chrisr
Posted 26 September 2021 - 03:01 pm
Just ridden back from Dom’s bike stop in Leominster after a great weekend in the Peak District and Derbyshire Dales with Danny Boy and (briefly) Big Dave, both formerly of this parish but now moved on to lesser machines! Realised that riding in the South East is no longer a pleasure so hopefully will be spending more weekends further afield. Even with the almost blanket 50 mph limit the roads up there are much better to ride. Tdm ran perfectly on E10, E5 or E7.5! Only problem was getting hold of it after the “DON’T PANIC” announcement, even had to fill up on the motorway at £1.60 a litre, only time I’ve seen queues there, luckily the E5 pumps were clear. Also found out I was even further from home at Dom’s than I was at Danny’s, not really “on the way” Enjoyed the ride there and home though. Cheers Danny!
#4966 Favs
Posted 26 September 2021 - 04:41 pm
Took it for a lightweight overnight under canvas.
Grand fire.
N Yorks moors in heavy fog this morning, kamikaze sheep, walkers in drab clothing waiting to be rear-ended (hum ho) and psychotic cyclists- mini pelotons on single track foggy roads ffs.
Still good fun.
#4967 leehenty
  • 5,323 posts
Posted 17 October 2021 - 03:44 pm
Took it for 100 mile test session after changing fork oil to 15 W which seems to suit it better.
#4968 curlylegend
curlylegend
  • 331 posts
Posted 24 October 2021 - 03:40 pm
Just doing my first yearly front fork oil change since replacing springs and fitting a RaceTech Gold Valve kit.   Big improvement right away. No more mushyness and much less dive on braking.                       Definitely felt planted !
So I've got the fork legs dismounted, the top caps and springs removed when I noticed a fair amount of stiction in the left fork leg ?  When I was fitting the Gold Valve kit I replaced the fork bushes and seals and everything was clinically clean at the time. The stanchions are perfect, surface excellent and no bending detected when rolling on a plate glass surface. I didn't want to dismantle the fork any further and almost certainly damage the bushes in the process so I prised out the dust seal and checked for contamination in that area.  Cleaned out the traces of assembly grease and applied a bit of ATF fluid and worked the stanchion up and down wiping of patches of dark contamination. I tipped in 500ml of white spirit, put the cap back on and continued pumping the stanchion up and down. Eventually it freed off and it's now as free as the other leg. With the caps on you can feel the trapped air acting as a spring.
I certainly never noticed this on assembly last year.  I've been using Total Fluidmatic ATX, compatible with just about all ATF fluids as far as I can make out. Never had any problem with the fluid before and it's only one side that's affected.
Maybe I'm being hyper critical but I always thought that these things should be as smooth as a virgin's thigh....whatever that is ?
#4969 Sabresdad
Sabresdad
  • 18 posts
Posted 25 October 2021 - 08:09 pm
Starting has been getting more sluggish despite the bike having been on the Optimate if it didn't catch first time chances are it wouldn't go,so I replaced the cheapo Platinum battery with the correct rated Yuasa battery.
Result instant starting
#4970 Tor
Tor
  • 76 posts
Posted 28 October 2021 - 09:44 am
Fitted a new, 49 cm tall touring screen from a Polish eBay seller. Polish product, happy with the fit and in Dark Smoked it’s an exact match. There’s even a discrete almost-correct logo printed on it.
Purchased a 12 cm clip-on deflector from same that doesn’t need any drilling. Package discount, £130 delivered and taxed to Norway. The weather is horrible so I’m not about to try it out today, though. But I’ll share some before and after pics.
Screen
Deflector
#4971 wicklamulla
Posted 29 October 2021 - 09:22 pm
Screen
Deflector
That TDM logo font was used on the 4TX from 1996-2002
#4972 bondy
bondy
  • 860 posts
Posted 30 October 2021 - 08:15 am
Is that a Lotus in the back ground?
#4973 Tor
Tor
  • 76 posts
Posted 01 November 2021 - 11:05 am
It's a Rover P6, waiting for some steering issues to get sorted. If it ever stops raining AND gusting for an hour or so. Fat chance this year...
Cool, thanks.
#4974 Plat0nius
Plat0nius
  • 14 posts
Posted 05 November 2021 - 05:34 pm
Took the cylinder head off to recheck valves. After swapping the head + cams in the summer, wanted to make sure everything was still within spec. It was.
Also ordered the same windscreen as Tor above, works great. Now the wind is straight to my helmet shield and its clean air most of the time, no buffeting. Did little over 350km with it and I like it. Also testing out extra deflector, to see if I can get the wind above my head, still looking for the correct positioning. Rode 200km yesterday and now got the wind hitting top of the helmet.
Up next is to find new handlebars, mine are little bent and I'm not really fond of them, 2h of riding and my fingers die on the right hand (left side is bent and is fine :D). Probably will get wider and straighter bars. Renthals would be great but ordering them to my country is expensive, will look for similar in local shops. Probably will need raisers as well, depends how high the bars are.
Couldn't figure out how to add pictures directly, so no pics :)
#4975 chrisr
Posted 07 November 2021 - 12:51 pm
Bar risers, renthal 755s and grip puppies will transform it
#4976 Tor
Tor
  • 76 posts
Posted 08 November 2021 - 08:20 am
Interesting that you got the same! My initial verdict on the screen is that it increased noise and turbulence, while the deflector helped a good deal. A little bit of popping/crackling, only. I stupidly bought them both in Dark Smoked, not thinking at all about just how much I ride in the dark this side of summer. Looks pretty good though  :rolleyes:
Attached File  82266984-BDCF-4FAA-B3F1-B3BC62792106.jpeg   355.57KB   1 downloads
#4977 Timbo1866
Timbo1866
  • 224 posts
Posted 08 November 2021 - 07:49 pm
MOT done on Saturday
passed with one advisory and a wink of the testers eye
in other words get a new rear tyre
So got one fitted today
Might not get much riding done until next year now,
but at least if we get some good weather it will be ready.
#4978 Favs
Posted 10 November 2021 - 04:35 pm
Gone camping on it until next Monday.
#4979 dablik
Posted 10 November 2021 - 04:55 pm
Winter woolies on Al  :)
#4980 Favs
Posted 10 November 2021 - 05:09 pm
I'll email pictures 😊
