6039 replies to this topic
#5181 chrisr
Posted 06 April 2022 - 12:09 pm
Come on Lee, it’s been half an hour, must be fitted by now!
#5182 Snowbird
  • 1,474 posts
Posted 06 April 2022 - 02:30 pm
Well the cleaning of the fork seals failed, had a run out sunday and the RH fork tube weewee'd out more that it did before, looks like forks out again and fit new seals this time, gonna go for oem seals and see if they fair better.
#5183 dablik
Posted 06 April 2022 - 04:01 pm
Yea get a move on Lee, could have had an engine out by now  :lol:
Think that's best with oem Dave, lot's of stories on ere of pattern seals being wubbish..
#5184 leehenty
  • 5,323 posts
Posted 06 April 2022 - 04:16 pm
Got the lurgi not covid, so laid up a bit
#5185 Snowbird
  • 1,474 posts
Posted 06 April 2022 - 05:40 pm
Whats the trick for holding the damper rods on a 4TX? Wooden broom handle or is there a hex in there?
#5186 leehenty
  • 5,323 posts
Posted 06 April 2022 - 06:35 pm
If it's a 43 mm fork probably a 29mm hex or 1.1/8"
#5187 Snowbird
  • 1,474 posts
Posted 06 April 2022 - 07:44 pm
Sounds like the same gadget I made for my XT forks then, good stuff!
#5188 Snowbird
  • 1,474 posts
Posted 07 April 2022 - 07:33 pm
OEM fork seals turned up today so after work whipped the forks out and took back into work, stripped, cleaned and left draining so should be able to sort them tomorrow.
Took damper rod bolt out with a nut runner leaving the spring in to stop it spinning and found one had no copper washer (not leaked though), found a couple of copper washers in the shed so no biggie.
#5189 leehenty
  • 5,323 posts
Posted 08 April 2022 - 12:02 pm
Got my front discs fitted so now I'm back on the road
#5190 Snowbird
  • 1,474 posts
Posted 08 April 2022 - 02:38 pm
Forks back in but had a bit of a dopey moment, found a rough edged pit around the seal area of the fork tube that was doing all the leaking so did the old trick of buff the high bits off then clean out and fill the pit with a few dabs of silver nail varnish (always used clear before but she had silver), decided to heat the tube a bit to help the varnish dry hard so blasted a heat gun down the tube, then the voices in my head kicked in "there's a nylon ring in there you moronic muppet!", bugger! nylon ring slightly mis-shapen due to the heat gun... :huh:
Stupid me!!! :istupid: :istupid: :istupid:
So if anyone has a pair of decent 43mm 4tx forks or just tubes for sale I'm probably in the market.
It's rideable but I don't suppose it will help the damping on that side, still safer than brake pads full of fork oil.
#5191 Sabresdad
Sabresdad
  • 18 posts
Posted 09 April 2022 - 02:21 pm
With a bit of heat (read a lot of heat) from the fine propane torch I got the 4 exhaust stud nuts off without snapping a stud.
3 hours later the stainless down pipes and colectors are no longer brown and minging but nice and shiny and everything is back together.
Cleaned the lambda sensor whilst everything was apart
#5192 dablik
Posted 09 April 2022 - 07:36 pm
With the blow torch ?
#5193 fixitsan
  • 4,852 posts
Posted 09 April 2022 - 10:36 pm
What magic did you choose for the downpipes ? I've seen lots of votes for Harpic or a similar product
#5194 dablik
Posted 10 April 2022 - 10:32 am
Harpic worked very well on mine, the black bottle..power plus.
#5195 bondy
bondy
  • 860 posts
Posted 10 April 2022 - 12:16 pm
Boike started, after months, and moved from shed to garage (garage empty after selling me MGB) after a quick shake down up the road. Next get it booked in for an MOT and build a new shed/small work shop for it while I look for something to replace MGB.
Boop.
#5196 Snowbird
  • 1,474 posts
Posted 10 April 2022 - 01:34 pm
Took it for a good hard run along a very bumpy road, so far no leaks from forks and handling nice, loving the road attack 3's, feels so much smoother through the corners and confidence inspiring.
#5197 leehenty
  • 5,323 posts
Posted 10 April 2022 - 04:06 pm
Took mine out to bed in the new brakes for a few miles. All good for a another few years
#5198 Sabresdad
Sabresdad
  • 18 posts
Posted 10 April 2022 - 04:14 pm
Yep
Polishing mop and compound then stainless steel sink cleaner for final shine
#5199 Studley Ramrod
Posted 10 April 2022 - 06:14 pm
:wifgeni:
#5200 hallrob1
hallrob1
  • 1,112 posts
Posted 11 April 2022 - 01:24 pm
Changed the coolant and whilst I was in the area discovered I also need front discs and will soon be following Lee with contoured EBCs.
I also removed the "winter plumage" (handlebar muffs) and put the hand guards back on.
I was going out with my son for his first ride of the year, no doubt with his Ducati Desert Sled, check shirt and trendy beard he would have refused to park next to me if I'd left them on.................
