850 Destruction
892 replies to this topic
#521 dablik
Posted 07 May 2020 - 06:02 pm
:lol: yea i think you do....
#522 Catteeclan
  • 2,574 posts
Posted 08 May 2020 - 09:09 am
Oh I think I got it covered Cliff...
:lol:  :lol:
#523 wicklamulla
Posted 09 May 2020 - 07:30 am
LOL  that is akin to skulking around the newsagents as a teenager and having a quick shifty at the 'top shelf' magazines... :wub:
#524 dablik
Posted 09 May 2020 - 04:59 pm
Broken bolt extracted so clutch bracket holder sorted
Attached File  DSC_0209.JPG   91.48KB   0 downloads
Done a bunch of fook fiddly bits where nowt will bolt in cos i found more powder coat filled thread holes.
Spent the day mincing around with the Remus exhaust, it was a bit tight taking of nephie's mk2 and it's an even tighter fit on the 3vd, tried 3vd foot hangers but they are a tad shorter than mk2's so no help.
Attached File  DSC_0217 (2).JPG   119.64KB   0 downloadsAttached File  DSC_0218 (2).JPG   105.92KB   0 downloads
So back to mk2 hangers and a 10mm hack of the Y-piece to downpipe end which helped a bit to still came up a tad short.
Attached File  DSC_0216.JPG   87.76KB   0 downloadsAttached File  DSC_0215 (2).JPG   105.7KB   0 downloads
Eventually managed to get them fitting but will need to address this down the road, possibly a new Y-piece from MTC
Carbs given a clean up, thermostat also
Attached File  DSC_0212 (2).JPG   115.8KB   0 downloadsAttached File  DSC_0213 (2).JPG   142.59KB   0 downloads and thermostatAttached File  DSC_0214 (2).JPG   68.75KB   0 downloads
Hmm looks like pc's playing up a bit with the photo's being disordered but ya get the drift.
Edited by dablik, 09 May 2020 - 05:01 pm.
#525 dapleb
  • 18,394 posts
Posted 09 May 2020 - 05:03 pm
Getting dare now dabs.
#526 dablik
Posted 09 May 2020 - 05:07 pm
Yup, walked it in gear to prime the oil, can hear a clicky click, could be the chain, i reckon it's foobard, got a ton of stiff links, 2k it had onnit :huh: radiator on next then the carbs..
#527 Studley Ramrod
Posted 09 May 2020 - 06:05 pm
Good job at bolt extraction, doesn't allus work out that way. :good:
My back's aching just thinking about the zorst fettlin. So you've got one zorst on inside of footbracket and the other on the outside for now.  Strange how it doesn't fit properly when it did on the mk2 eh.
Rear brake caliper bracket looks proper shiney, did you file/grind it smooth before polishing it ?  Mines got really bad finish where the bolt goes.
Soon be time to fire her up eh. :)
#528 dablik
Posted 09 May 2020 - 06:42 pm
Think i got lucky with the bolt extraction as i flipped it over so was drilling clockwise ie unscrewing the bolt out (which it did'nt) but i think the heat from drilling helped a lot and the ez out worked a treat..
Yea was back breaking fettling the buggers, good you noticed but cant get them to fit any other way, also the right side is 6cm higher than the left which is as i thought the Y-piece is a bit wobblyish, tried getting it level but that's impossible without the cans on but also lifts the left side exhaust to close to the chain and the can almost touching the swinger, prolly have another bash at some point... think me endless chain will get grinded off an all...
Edited by dablik, 09 May 2020 - 06:43 pm.
#529 Studley Ramrod
Posted 09 May 2020 - 06:49 pm
Chain might just need loosening up ?
Also, me other question above,  regarding rear brake caliper bracket pleeeeease. :)
#530 dablik
Posted 09 May 2020 - 08:09 pm
Oh the rear caliper bracket, it's not polished but painted...however i did clean the footrest hangers up a bit, i used a brillo pad gently initially, then a medium grade scrubbie, brown, then fine, grey and finally polished with a small felt pad on a dremel and Autosol, they look okay, eventually i'll get the mops out for the exhaust but it's messy..
#531 leehenty
  • 5,325 posts
Posted 09 May 2020 - 08:27 pm
That's why they called it my stainless porn at a fettle day
#532 Studley Ramrod
Posted 10 May 2020 - 02:11 pm
They've come up nice. :good: They're quite stylish fer footpeg brackets, as is the rear grabrail.  I was watching wheeler dealers, handy for fettlin' tips, and Edd China reckons to get polishing swirl marks out, rub in some talcum powder.  Worked a treat on a car he'd polished.
#533 dablik
Posted 10 May 2020 - 04:15 pm
Talc eh, got some for me flourescent riding undies, have to give it a try, cheers.
#534 dablik
Posted 11 May 2020 - 06:33 pm
9 quid furra a litre of Prestone Anti freeze fook me and avya seen the price Halfrauds want for Brake fluid....jeebus the great swindle,
nearly a mishap today :D just as i was about to fill the radiator.....phew, i thought hang on should'nt there be a bolt in there, sure ive flushed me waterworks with that open before..
Attached File  Little booger_LI.jpg   255.91KB   0 downloads
#535 leehenty
  • 5,325 posts
Posted 11 May 2020 - 06:55 pm
Just seen a rusty bolt on that thermostat housing, probably M6 just need length, I'll send you some flanged stainless ones.
#536 Studley Ramrod
Posted 11 May 2020 - 07:38 pm
Good save mucka.  Bit late now but Tesco often have deals on stuff like antifreeze.  And Wilko sell motoring liquids too.
Well spotted Lee.  :lol:  Not sure Cliff would want to disturb that though, looks like it's been silicone sealed ?
#537 dablik
Posted 11 May 2020 - 08:11 pm
I've given em a clean up Lee and nail varnished em and sealed the thermostat an all, later on after it's up and running i'll give it a go over for all the little bolts i want to replace..
Oh well never mind, got brake fluid from B&Q furra Fiver, got a Tesco local but no Wilko, to posh round here ya see :)
#538 Medmonic
Medmonic
  • 81 posts
Posted 11 May 2020 - 08:30 pm
nice work there !!
#539 Matlock
Posted 12 May 2020 - 01:36 am
Did you try Waitrose Cliff? For future reference, Opie Oils are very good for fluids, everything in stock, decent pricing and next day delivery. I've been using them for years, no problems
#540 leehenty
  • 5,325 posts
Posted 12 May 2020 - 09:43 am
+1 for Opie Oils.
Chained myself to the lathe today, Dablik wants stainless brake caliper pins for his new steed.
Edited by leehenty, 12 May 2020 - 09:44 am.
