6039 replies to this topic
#5381 ChrisG
Posted 28 September 2022 - 12:49 pm
Which ones did you fit? I've yet to see any I like that fit with std bars, are yours only compatible with the Renthals?
DL 650 guards are a pretty easy fit, I used a dremmel to open out the hole in the outer end to the same diameter as the threaded section of the bar end weight, and then threadlocked the bar end weights in position instead of clamping them up tight.  They've been rock solid for years.
#5382 PeterGriffin
PeterGriffin
  • 56 posts
  • TDM model: 1994
Posted 29 September 2022 - 02:09 pm
New Pirelli tyres...chain and sprockets fitted......spit n polish....all good.........
#5383 chrisr
Posted 29 September 2022 - 05:56 pm
Noticed that it needs a new rear tyre, when I checked found it had done 12,000 miles so cant complain!
Looks like I got my moneys worth out of this one..Attached File  10AA938B-29F0-4EF6-B718-7E808EA0DBB7.jpeg   357.8KB   4 downloads
#5384 steve27bha
  • 797 posts
Posted 29 September 2022 - 09:03 pm
Gave it a wash and a pat after a 1060 mile three day trip over to Skye and then round the top of Scotland. It drizzled all of the second day, and I had the hotgrips on all the time. B&B dried the kit for me.
Found that the bird I hit didn't just strike the radiator area (thump, bang, feathers) but got there via the front of the mudguard, and cracked it. Perhaps I'd have a damaged radiator if it hadn't, so I won't complain - much.
#5385 madmopedracer
madmopedracer
  • 473 posts
Posted 30 September 2022 - 10:58 am
only running on 1 cylinder at low revs cleaned the carbs sorted that now they keep flooding
float heights?
#5386 catsbum
Posted 01 October 2022 - 01:42 pm
Wheel off. Old disc truly pooped.
Going to tidy rear wheel area up whilst it's off too.
Cats
#5387 ChrisG
Posted 01 October 2022 - 03:18 pm
How easy did the bolts come out?
Gave mine an oil change this afternoon, which took longer than anticipated.  Firstly hunting around the house for an allen bit to fit the filter housing bolts (moved house and been doing some DIY so things not always in the most sensible place), then unsuccessfully hunting for a funnel that must have gone missing when we moved house.  Luckily I had a 1 liter can of oil with a nozzle on the top, so decanted in to that from the big can and then squirted it in to the bike.  Than I had to make a funnel out of an old milk carton in order to pour the old oil from the bowl in to the can  :rolleyes:
Brake fluid will have to wait for another day.
#5388 catsbum
Posted 01 October 2022 - 05:20 pm
Not today Chris, As I'm contacting my local mechanic for him to do it. He can have all the fun!
#5389 catsbum
Posted 03 October 2022 - 04:52 pm
Wheel's being collected shortly so while it's gone....
Going to look at the caliper and swing arm tomorrow. Could do with a tidy.
Cats
  • Attached File  cccc.jpg   175.75KB   0 downloads
  • Attached File  ccc.jpg   139.48KB   0 downloads
  • Attached File  cc.jpg   93.86KB   0 downloads
#5390 Studley Ramrod
Posted 03 October 2022 - 07:34 pm
No rain this morning = DRLs fitted and functioning just fine :good:
Good to hear. :good:
#5391 Studley Ramrod
Posted 03 October 2022 - 07:57 pm
Looks like I got my moneys worth out of this one..attachicon.gif 10AA938B-29F0-4EF6-B718-7E808EA0DBB7.jpeg
lol. yep. :good:
float heights?
It could be a spec of crud on the float needle/seat. I'd suggest using some clear tube to check each carb fuel level, might help you narrow down the problem without having to check both carbs internally.
#5392 dablik
Posted 04 October 2022 - 08:27 am
Have had the very same issue out of one, was the very problem Studley mentions, took a few tries though, said crud was minute in size.
#5393 leehenty
  • 5,323 posts
Posted 04 October 2022 - 02:29 pm
I ought to be taken out and hung, but pushed it out to get to the Trumpet, to get some stuff done then pushed it back in plugged in optimate.
#5394 madmopedracer
madmopedracer
  • 473 posts
Posted 04 October 2022 - 05:28 pm
lol. yep. :good:
lol. yep. :good:
going to take the carbs off again before i winterize the bike drain the fuel remove battery etc and then fiddle with the carbs at my leisure before spring
#5395 Studley Ramrod
Posted 04 October 2022 - 08:24 pm
:good:
#5396 Tiagocris
Tiagocris
  • 4 posts
Posted 10 October 2022 - 01:04 pm
Hi every one!
I'm Tiago from Portugal and I'm an owner of a TDM 900A from 2005 with 100K Km. I have been using this forum to answer most of my questions in the last year of ownership. I want to thank you all for the value information regarding maintenance and mods.
I have done the airbox mod last year (disconnect the cable from ECU) to make the bike more usable in the lower revs but still it didn´t compare to a 2 gen sv650 I had in the past.
I found Frits44 list of instructions to change fueling and air intake on the TDM 900;
I bought a used air box and temperature sensor to mod;
I put the temp. sensor under the seat;
I removed the flap actuator;
CO both from 20 to 60; (still finding the sweet spot)
Stock exhaust with CATs;
The difference is staggering. The bike can run in second gear without throttle input.
I'm still running the TPS at 17 which I consider to be the last point that needs to be addressed.
I was so excited when doing the mods that I didn´t took pictures. Next time the tank comes up I will post the changes!
Even the sound of the bike changed. Before the mods the bike sounded harsh at idle, wasn´t  reeving freely and under acceleration it sounded like bogging.
I was looking for an air leak but never found one.
Now the idle is almost to quiet is revs freely and under acceleration it makes a growling sound.
The fuel consumption is higher dude to the hooligan effect but a highway test at constant speed is in order.
I would love to hear your thoughts on why the TDM 900 have a tendency to lean with time! or was like this when new?
To add to the this last point I change the air filter and cleaned the fuel pump.
I most also add that after the mods I found forgotten feelings and immediately started looking for throatier exhausts.
Edited by Tiagocris, 10 October 2022 - 01:05 pm.
#5397 Snowbird
  • 1,474 posts
Posted 10 October 2022 - 01:36 pm
Welcome Tiago. :welcome:
#5398 Tor
Tor
  • 76 posts
Posted 11 October 2022 - 11:31 am
Continuing to break in my Road 6s and bought these on Megazip:
Cover, Side 1, Yamaha
5PS-21711-00-00 US $8.61 1 pc. US $8.61
Cover, Side 2, Yamaha
5PS-21721-00-00 US $8.61 1 pc. US $8.61
#5399 Favs
Posted 11 October 2022 - 04:56 pm
Had a nice N Yorks back roads bimble
#5400 drewpy
  • 1,788 posts
Posted 13 October 2022 - 01:49 pm
ordered 3 champion oil filters from Louis, cheaper than Halfords where they want £11 for 1, got 3 for £17
