6039 replies to this topic
#5461 leehenty
  • 5,323 posts
Posted 05 March 2023 - 01:51 pm
Pulling the dog bone needle bearings out of the swing arm and the alloy link needs the right tool to draw them out and put them back.
#5462 Catteeclan
  • 2,572 posts
Posted 05 March 2023 - 02:41 pm
Got mine in the conservatory at the mo. Wanted to sort some electrical gremlins and have a check over for the MOT later in March.
Only prob so far is the full tank leaking a little fuel when stood upright, stunk the house out. :lol:
#5463 leehenty
  • 5,323 posts
Posted 05 March 2023 - 02:42 pm
Swmbo will ll be after your hide
#5464 leehenty
  • 5,323 posts
Posted 07 March 2023 - 01:59 pm
Gave plastics good clean and polish, serviced and greased bottom link, topped up battery put her back under the woolly blanket but brought in the Garmin to update mapping
#5465 fixitsan
  • 4,852 posts
Posted 08 March 2023 - 05:09 pm
Took it to the MOT test for a clean pass.
Happy Days
#5466 Catteeclan
  • 2,572 posts
Posted 08 March 2023 - 06:57 pm
Bit doing a bit of MOT prep on mine. Like Trev I've got a little play on the rear suspension. Gave up trying to find it.
It hasn't been far this last year but still nice to get a look over.
#5467 PICARD
  • 1,786 posts
Posted 09 March 2023 - 05:55 am
Well worth a peep at the swinger pivot. I put an endless chain on last time, and remember thinking that the same guy as who grease's the steering head bearings was let loose on there.
#5468 fixitsan
  • 4,852 posts
Posted 09 March 2023 - 09:02 am
For last year's MOT I pulled the pivot shaft out to find the bearings were gubbed and the shaft was too worn to reuse.
I looked at getting the bearing/seal kit and new shaft, but found a secondhand swingarm with almost new bearings on ebay for £40.
There seems to be a lot of used cheap spares surfacing now
Edited by fixitsan, 09 March 2023 - 09:09 am.
#5469 Catteeclan
  • 2,572 posts
Posted 09 March 2023 - 01:48 pm
:good: I had it to bits last year and apart from a few light marks here and there I couldn't see any real probs. I re-greased and put it back together again.
Edited by Catteeclan, 09 March 2023 - 01:48 pm.
#5470 hallrob1
hallrob1
  • 1,112 posts
Posted 15 March 2023 - 05:00 pm
Took it out for it's first ride after fitting new tyres, bearings and discs to the newly powder coated wheels and putting the old lasers back on.
I still love riding this bike........
It was also the first trip since a valet and ceramic coating so I was hoping to avoid water and mud but was unsuccessful- let's see how easy it is to clean now!
#5471 chrisr
Posted 18 March 2023 - 12:16 am
And?
#5472 ramo
ramo
  • 1,190 posts
Posted 18 March 2023 - 11:01 am
Well Rob I think I was more unsuccessful at avoiding mud and water, this is mine last night,
I cleaned it in the dark, couldn't put it away like this,
I was hoping to give it a second clean today, but is pissing down so it will have to wait lol
Attached File  IMG_20230317_182411552.jpg   210.25KB   2 downloads
Attached File  IMG_20230317_182418572.jpg   287.77KB   2 downloads
#5473 dablik
Posted 18 March 2023 - 11:37 am
Steve, prolly the angle of the dangle but, that oiler looks to be placed low with a short run to the sprocket, maybe not !?
#5474 ramo
ramo
  • 1,190 posts
Posted 18 March 2023 - 04:28 pm
Cliff
the oil feed pipe goes from the oil reservoir to the rear sprocket, via the swing arm pivot point, (takes up any movement needed)
where it dispenses at about 7 o'clock on the sprocket
this type of oiler does not need much gravity head as such to work,  the oil is displaced and drips out when you turn the feed,
3rd bike I've fitted like this no issues, works perfect, you can see in the pic the chain still looks good  :good:
a lot neater than fitting on the res on the bars and running the oil pipe all over the bike etc, to the rear sprocket, in my humble opinion  :unsure2:
#5475 James
James
  • 572 posts
Posted 18 March 2023 - 07:23 pm
Cliff
What kit is it Steve?
84 Honda XL600R  :)
04 TDM900  :good:
21 KTM 790 Adventure  ;)
#5476 ramo
ramo
  • 1,190 posts
Posted 18 March 2023 - 09:59 pm
James mine is one of these
https://www.ebay.co....:Bk9SR-aLx-veYQ
its a copy of one of these, but less expensive
https://www.cobrra.co.uk/online-shop/
#5477 dablik
Posted 18 March 2023 - 11:35 pm
I've got one also Steve. mounted a little higher than yours though with oil pipe run the same way  :good:
#5478 hallrob1
hallrob1
  • 1,112 posts
Posted 19 March 2023 - 09:23 am
And?
Sorry, hadn't meant to leave you in suspense - I've nothing else to add!
#5479 ramo
ramo
  • 1,190 posts
Posted 19 March 2023 - 09:25 am
You know it makes sense  :good:
do yo have an oiler on the Himi Cliff ?
#5480 ramo
ramo
  • 1,190 posts
