6039 replies to this topic
#5701 fixitsan
  • 4,852 posts
Posted 29 January 2024 - 09:14 am
first trial fitting of new forks
They look good, what bike are they from ?
#5702 fixitsan
  • 4,852 posts
Posted 29 January 2024 - 09:22 am
Started it up to analyse the source of the faint smoke which comes now and then. Decided a strip down is due.
Took one look at the corroded cylinder head exhaust manifold studs/nuts and think due to the 115,000 miles of corossion it might be time to trade this in, or just get another engine !
#5703 thong
thong
  • 72 posts
Posted 29 January 2024 - 09:28 am
triumph 1050
#5704 leehenty
  • 5,323 posts
Posted 29 January 2024 - 09:28 pm
Ooh nice
#5705 Catteeclan
  • 2,572 posts
Posted 04 February 2024 - 09:11 am
Rode it for the first time in what seems like ages. Had to nip to Norwich, it had more fuel in the tank than the Dominator, and it was the last day of the road tax.
I've SORN it for a couple of months to make better use of it in the warmer weather.
#5706 trevini
trevini
  • 1,891 posts
Posted 04 February 2024 - 01:58 pm
Rode and got it filthy.. 140ish miles today.
#5707 PICARD
  • 1,786 posts
Posted 06 February 2024 - 05:07 pm
Booked MOT for Monday, so bound to be wettest day since records began....
#5708 harvey krumpet
harvey krumpet
  • 2,065 posts
Posted 06 February 2024 - 08:56 pm
I spent yesterday wrastling with the seized pistoons in the rear brake. The last couple of rides have been sans rear stoppage.
On investigation the brake fluid looked like cold, milky, tea and after much wriggling, twiddling and inventive language to remove the caliper I found the pistons to be fossilised in position.
The rear brake pad pins are held by R clips, don't be a Harvey and end up with a D clip and an R clip..
Initially I was going to strip it down, clean the pistoons and rebuild it but chickened out knowing I would knacker the seals. I will do it properly when I have new ones.
Anyhoo, after spraying it with stuff which claims to free up anything for 6 hours the pistons did indeed start to move, out, happy days. Getting them back in so I could push them out again required mensa level thinking, two wee clamps with the top of the foot ground off and a wee steel plate so I didn't squeeze the pistons wonky as I gorilla'd them back in. Repeat until bored. Clean re-assemble, dis-assemble to check the pads were in the right way, arrows pointing in rotation, re-assemble, flush through with new brake fluid and ta da, I can do skiddies again. That's probably due to all the spray that hit the rear tyre, though.
Dunno what I'm going to do about all the gouges on the caliper face where the wee pins in the clamp cups attacked it. Hindsight is a wonderful thing, so is heavy duty inner tube rubber glued to clamp cups to stop outbreaks of caliper gouging.
Edited by harvey krumpet, 06 February 2024 - 08:57 pm.
#5709 fixitsan
  • 4,852 posts
Posted 11 February 2024 - 03:18 pm
Decided to take the 900 out, as the MOT/tax/insurance is due in a few weeks.
Had a great run down to Peebles, lunch at Greggs and a run back in time to see the rugby at home
The previous smoke from the right side exhaust seems much reduced on the run, even when idling, so on the way home I thought I should check the oil level on the stand when I get home.
I left it idling on the stand, and turned off the engine, dipped the oil immediately and it was about 40mm up the dipstick *above* the high level mark. After 5 minutes it was still the same. Has my smoke been due simply to a previous overfilling ?
That would be nice, if that's all it is because I was dreading getting the exhaust studs out to do any engine work, after 113,000 miles
While letting it idle on the stand, suddenly watered started to dribble out of the bottom, around the water pump, so I guess the seal has given up the ghost.
So what issues surround pulling the water pump out ? I've read here there's a little washer or shim within the engine that can fall inside ?
If I fix this leak and stop the smoke by draining oil I think the bike will manage an Ireland trip later in the year :)
#5710 MArk2
MArk2
  • 73 posts
Posted 12 February 2024 - 05:01 am
Water Pump Mechanical Seal Kit For Yamaha Replaces 11H-12438-10-00 11H-12438-00    marksport2015     This is available on E bay. and does fit. The washer you refer to often sticks to the nylon drive so you get the chance to block it from falling into the sump, i missed my chance  :hide:    Best Mark.
#5711 fixitsan
  • 4,852 posts
Posted 14 February 2024 - 10:27 pm
Cheers Mark
So I should have a piece of card or plastic ready, to put in the hole that the pump came out of to go under the gear, or isn't it needed ?
I'll definitely lean it as far over as I can !
Edited by fixitsan, 14 February 2024 - 11:04 pm.
#5712 MArk2
MArk2
  • 73 posts
Posted 15 February 2024 - 04:22 am
I think a bit of cloth would be my choice. And am not sure leaning it over is  going to be helpful. Also in my case i did not change the ceramic washer. Was bothered i might break it.   Best mark.
#5713 fixitsan
  • 4,852 posts
Posted 15 February 2024 - 08:55 am
:good:
#5714 leehenty
  • 5,323 posts
Posted 15 February 2024 - 10:46 am
In my experience of replacing the ceramic seal, a push tool to press only the metal rim of the ceramic seal is essential. I used a rod in my drill press to get it in square, the force needed is not high.
Edited by leehenty, 15 February 2024 - 10:46 am.
#5715 MArk2
MArk2
  • 73 posts
Posted 15 February 2024 - 05:08 pm
you may need this to OIL SEAL - Metric R23/TC Lip Arrangement Rotary Shaft Seal - 12x21x4mm  Mark.
#5716 fixitsan
  • 4,852 posts
Posted 15 February 2024 - 06:20 pm
Sounds like fun and games !
It arrives Monday, I'll take the old one off over the weekend and work out a plan
#5717 leehenty
  • 5,323 posts
Posted 15 February 2024 - 06:24 pm
There is a little circlip in there you have to compress seal spring to re fit
#5718 fixitsan
  • 4,852 posts
Posted 15 February 2024 - 06:31 pm
Sounds like stuff i do at work. Roughly translating into 'better get a couple of spares'...ping !
#5719 leehenty
  • 5,323 posts
Posted 15 February 2024 - 06:49 pm
Ping Phukets usually into the darkest corner of the workshop.
Edited by leehenty, 15 February 2024 - 06:49 pm.
#5720 fixitsan
  • 4,852 posts
Posted 15 February 2024 - 07:03 pm
:lol: :lol:
