6039 replies to this topic
#5761 Catteeclan
  • 2,572 posts
Posted 19 March 2024 - 06:07 pm
Noticed oil on the left side fork leg which is a bit alarming as it's hardly been anywhere and the side (I think) I fitted a new stanchion a couple of years ago.
Cleaned after running the seal scraper round and will keep an eye.
Made these alloy infill discs with a centre threaded connector rod for a guy on here. They fit the swing arm ports on the frame to tidy it up. The gel decals are genuine Yamaha.
Nice one Lee, what a good idea.
#5762 leehenty
  • 5,323 posts
Posted 19 March 2024 - 06:08 pm
Seals probably gone hard. Rubber bits dont seem to last as long these days
#5763 trevini
trevini
  • 1,891 posts
Posted 19 March 2024 - 08:46 pm
I know what you mean. I had to change a fork seal on mine a couple of months ago after 19 years and 60k miles.  :)
#5764 Catteeclan
  • 2,572 posts
Posted 20 March 2024 - 06:44 am
You're not wrong. I fitted some single skin petrol pipe to a Suzuki GT125 in September last year. Had the tank off last week and it's gone hard and split near the fuel tap.
#5765 leehenty
  • 5,323 posts
Posted 20 March 2024 - 05:35 pm
Thats the ethanol in the fuel
#5766 trevini
trevini
  • 1,891 posts
Posted 20 March 2024 - 06:54 pm
Five counties run today and clocked up another 271 miles. Even managed to find some nice dry twisty bits in Hertfordshire.  :)
#5767 Favs
Posted 20 March 2024 - 07:44 pm
Shoved the 9er out of the way to mop up the 5 litres of Adblue I'd kicked over, tra la laa la la.
Did make me tidy up a bit too - ready for my new bike lift -  it's red n drybolic.
Going to do some ruthless shelf sorting tomorrow, the MK1 stuff will not be binned.
#5768 drewpy
  • 1,788 posts
Posted 21 March 2024 - 11:12 pm
booked the old girl in for MOT next Tuesday
#5769 Snowbird
  • 1,473 posts
Posted 22 March 2024 - 08:16 pm
Mot'd and taxed it, no advisories.
#5770 Gdogg
Gdogg
  • 1,204 posts
Posted 23 March 2024 - 09:00 am
http://www.carpe-tdm..._299_205780.jpg
Did the same thing when I rebuilt WinalotPrime 👍
#5771 Tor
Tor
  • 76 posts
Posted 26 March 2024 - 12:00 pm
Fitted a belly pan to it. Quite happy about the new look. Cant upload images though 🥺
eBay item no. 253056279991
Edited by Tor, 26 March 2024 - 12:01 pm.
#5772 leehenty
  • 5,323 posts
Posted 26 March 2024 - 05:46 pm
Pushed the niner out of the way to take the Bonneville for mot, I could hear it softly crying.
#5773 jpe70
jpe70
  • 21 posts
Posted 26 March 2024 - 08:16 pm
Put it back in one piece again after most of winter unintentionally without carbs. Even think I got the leaky bits fixed so it's a runner.
TDM 850: my stop gap replacement.
#5774 drewpy
  • 1,788 posts
Posted 29 March 2024 - 09:00 am
passed the MOT with 2 advisories;
brake pads low ( I knew but they will last till end of year)
mist from left fork leg, bike not ridden since June last year. tester said its probably dust in the wipers. I went round with plastic cut from milk bottle to see if that cures it as I refuse to believe seal failed by sitting for 9 months.
#5775 jpe70
jpe70
  • 21 posts
Posted 01 April 2024 - 11:42 am
Ordered it some new rubbers. Cheapest decent one's I could find, so nothing modern.
#5776 Favs
Posted 02 April 2024 - 04:08 pm
MOT today - no issues n a dry day to boot :good:
Only did 3500 miles last year - was a busy busy work year 2023, 2024 looks the same.....
#5777 dablik
Posted 03 April 2024 - 07:28 am
Thought you were meant to be out to grass mucka  :)
#5778 Favs
Posted 04 April 2024 - 08:36 pm
Keeps ringing meatey...Are you busy? N I can't say yes too busy. So now busy for the next few months...off to Luxembourg n Metz on Monday tra la la.
Matey not meaty that's just 9er.
#5779 steve27bha
  • 797 posts
Posted 04 April 2024 - 10:05 pm
Finished the major service and buttoned it all up.
Q. How do spark plugs get to be different colours on opposite sides of the nose? Here's mine one side and then flipped round; both much the same.
Attached File  DSC03419.JPG   66.79KB   0 downloads  Attached File  DSC03420.JPG   70.75KB   0 downloads
I decided to put in a new battery - there had been the occasional sign of distress. I've read the warnings of difficulty removing it from a 900, but mine had a gaffa tape handle added so "no problem" methinks. Wrong! The tape tore - old age? Now what? - it's in real tight. Luckily I switched on my brain just in time to not bolt a strip of metal to the posts as a handle! My zip tie stock produced a type with an eye for screwing to a wall, and M6 bolts secured one to each battery post. Pulled out a dream. Getting the new one in was a fight tho', even with the sides lubricated with vaseline and the tray eased with a screwdriver..
Attached File  DSC03451.JPG   126.39KB   0 downloads
I only needed to change two exhaust shims, and one of those swapped into the other so I needed to buy just one. I knew what was already in there from the previous shim work. My tip for the gap measurement is to use imperial Go / No go gauges. The gaps are as good as 7 thou and 10 thou both +/- 1 thou so can quickly be checked. If out of spec then go in with the metric gauges for the accurate measure to calculate the shim - I used JBX's calculator spreadsheet. My Go/Nogo gauges are by Sykes-Pickavant No. 016300 The blades are made to imperial from 0.004/0.006" up to 0.025/0.027" with metric values shown. 22 blades in the set but I've put the smallest 10 in a separate holder for ease of use. When I bought them I could not find equivalent metric gauges, even in France.
Attached File  DSC03454.JPG   117.32KB   0 downloads
Just need some dry weather for a test ride - rain and snow forecast for up here!
#5780 dablik
Posted 05 April 2024 - 08:46 am
Keep you out of trouble eh, enjoy your travels...
