6042 replies to this topic
#561 Studley Ramrod
Posted 28 March 2015 - 03:36 pm
Fixing the leaking thermostat housing.......success ! :)
Fixing the spluttering at very low revs.....no success ! :(  Stripped the carbs and cleaned all the bits, re-built and still getting the exact same problem.  Soooo, looks like it might be a blockage or air is getting in there somewhere.
Fixing the spluttering part 2............success !  :)  Running reeeeally smooth at low revs now.  Took me ages to find the problem as it was well hidden. I'd removed the carbs, again, cleaned and tweaked 'em, again and fitted 'em bacon the bike, again.  I was about to disconnect the vac pipe on the fuel pump side where it connects to the engine inlet stub but decided to disconnect it at the fuel pump end this time.  Pulled the pipe off and discovered a t connector for the scottoiler.  Then discovered the other end of the scottoiler pipe wasn't connected to the oiler. :rolleyes:  Decided to blank it off with a screw. :D
Will connect it to the other vac pipe then I won't get any problems with the fuel pump.
#562 krispa
krispa
  • 38 posts
  • TDM model: 1994
Posted 28 March 2015 - 07:59 pm
MOTed after fitting new rear tyre and doing fork seals and bushes (what pita job)
Had very similar issue with crack in the t connector lossing vac intermittently
#563 erank
erank
  • 55 posts
Posted 29 March 2015 - 05:30 pm
My new Purchase (2002 900) is having some work done:
Steering head bearings
Front fork oil change & oil seals
Oil & Oil filter change
Spark plugs change
Air filter (putting a BMC)
Brake fluid change
Also decided to have the wheels powder coated so bearings and seals will be replaced as well
#564 Timbo1866
Timbo1866
  • 224 posts
Posted 29 March 2015 - 05:39 pm
Fitted and connected new mirrors with indicators look good will see how they perform also adjusted my Tom tom bracket hope to be able to see the screen now
Attached File  image.jpg   120.67KB   0 downloadsAttached File  image.jpg   119.82KB   0 downloadsAttached File  image.jpg   240.04KB   0 downloads
#565 PassTheBuck
PassTheBuck
  • 539 posts
Posted 29 March 2015 - 08:32 pm
Took her for MOT yesterday and she passed with no advisories , well chuffed :good:  :good:  :good:
#566 erank
erank
  • 55 posts
Posted 30 March 2015 - 01:13 pm
Today my bike is getting new wheel bearings all over + seals + new tires: Bridgestone Battlax T30
#567 alunl
alunl
  • 356 posts
Posted 30 March 2015 - 07:15 pm
Fitted Datatool heated grips to my 9er.
Apart from having to file off the plastic tags inside, they were really easy.
The fundamental cause of trouble in the world today is that the stupid are cocksure while the intelligent are full of doubt.
~ Bertrand Russell 1950
#568 Yamasaki
Yamasaki
  • 53 posts
Posted 31 March 2015 - 12:31 pm
Replaced oil / dust seals to forks and new oil (15w) made a difference ( perceived or otherwise) seems a bit firmer but not tried it out in anger yet.  A big thanks to all you on here and especially those on KB you have helped me in confidence and saving money ( to spend on shiny bits ;-0  )
Tom
If it aint broke, I havent fixed it!
#569 GeneralBozo
GeneralBozo
  • 92 posts
Posted 31 March 2015 - 05:16 pm
I got annoyed the wind blew over what was my totally unmarked mint TDM, even though it was partially sheltered from said bastard wind. Must have been turbulence in the gusts.
I had the steering lock to the right and it must have blown the bike up off the stand, leant onto a rail on the bike's right hand side, then slowly slid backwards and onto the ground (should've left it in gear...). So luckily no impact, just a gentle lie down!
Very minor mark to silencer, minor but not as minor mark to front mudguard but the massive tiger screen split in half. Grrrr. I think this is irreplaceable unless anyone knows of any others around.
#570 TDMick
Posted 03 April 2015 - 12:16 am
Got some Scotchlite reflective strip off Amazon.
Attached File  20150402_191043.jpg   116.86KB   0 downloads
Attached File  20150402_191105.jpg   72.14KB   0 downloads
Attached File  20150402_191119.jpg   144.25KB   0 downloads
#571 shuggie
shuggie
  • 13 posts
Posted 03 April 2015 - 12:19 pm
Bought a wingrack for it, missed out on a fitting kit for it and cant find one anywhere for it :sorry:
decided to put the rear indicators back to there original positions because the brackets some previous owner had made for them looked crap. :huh:
gave it a full once over cleaning and checking everything is ready for tomorrows egg run with the Dundee bikers forum :clapping:
#572 Guest_davet_*
Guest_davet_*
Posted 03 April 2015 - 01:02 pm
DRL fitted great safety feature for only a few quid.
#573 Catteeclan
  • 2,575 posts
Posted 03 April 2015 - 05:29 pm
I've been stubbying and fitting a pair of cans.
Had a short road test, glad they came with baffles.
#574 Deauman
Deauman
  • 109 posts
Posted 03 April 2015 - 06:05 pm
Fitted some of these
Attached File  DSCF1745.JPG   163.88KB   5 downloads
and one of these
Attached File  DSCF1747.JPG   44.74KB   4 downloads          Attached File  DSCF1750.JPG   80.21KB   3 downloads
Its a speed camera warning device which I came across for less than £20 which is a whole lot cheaper than a ticket. I got caught last year when I saw the camera but hadn't seen the change of speed limit sign as I was busy overtaking a large lorry! It's just a gps device that has a database of fixed cameras and popular locations for mobile cameras. Shows red when you are approaching a camera and flashes red if you're over the limit. I'm sure all you sat nav users don't need a thing like this but for an old fashioned map man like me it seemed worth a try.
Edited by Deauman, 03 April 2015 - 06:06 pm.
#575 erank
erank
  • 55 posts
Posted 04 April 2015 - 06:53 am
#576 arthurbikemad
arthurbikemad
  • 573 posts
Posted 05 April 2015 - 08:42 pm
Some great goings on in here!
Washed it, saw some rust on it, rode it...
#577 TDMick
Posted 05 April 2015 - 09:13 pm
Went cafe hunting, went to the Jailhouse cafe in Crawley.............it was closed! :rant:
So I went to Boxhill instead.
Attached File  DSC_7707.JPG   160.33KB   0 downloads
Attached File  DSC_7702.JPG   192.29KB   0 downloads
Attached File  DSC_7746.JPG   198.51KB   0 downloads
Attached File  DSC_7718.JPG   192.34KB   0 downloads
Edited by TDMick, 05 April 2015 - 09:14 pm.
#578 TDMTAM
Posted 05 April 2015 - 10:41 pm
Just back from 3 days away on the TDM around the north of Scotland
Tam
Don't ask me how or why the pictures are like that
Edited by TDMTAM, 05 April 2015 - 10:42 pm.
#579 arthurbikemad
arthurbikemad
  • 573 posts
Posted 06 April 2015 - 05:34 pm
Went for a pleasure ride :) down to Loomies Cafe, 1 hour and 15 min wait for a burger and cold chips, 10 quid! plus a free insult! third time foods been cold and an age to get, was not even that busy at the time. :(
#580 Gasman
Gasman
  • 483 posts
Posted 06 April 2015 - 06:01 pm
and one of these
Where did you get the contraption from?
Sorry just found it on eBay.
New question. Does it work OK?
Edited by Gasman, 06 April 2015 - 06:09 pm.
