6039 replies to this topic
#5861 Studley Ramrod
Posted 15 June 2024 - 03:00 pm
#5862 fixitsan
  • 4,852 posts
Posted 21 June 2024 - 04:08 pm
Attached File  20240621_165644.jpg   78.03KB   0 downloads
I picked up the rebuild today :)
New body, top bushing, piston ring, o-rings throughout, shims replaced.
Can't wait to fit it and test
#5863 leehenty
  • 5,323 posts
Posted 22 June 2024 - 02:25 pm
Sorted out no dipped beam, green crud in connector under airbox. Gave her a clean, booked its mot
Edited by leehenty, 23 June 2024 - 06:57 am.
#5864 CaptainSlow
CaptainSlow
  • 716 posts
Posted 22 June 2024 - 05:07 pm
Had some shiny new Battlax T32s fitted by the irrepressible Trevini. Damp roads on the way home, but initial indications suggest they'll help my confidence no end.
1996 TDM850 in Yellow, Motad Nexxus, MK1 bashplate, Acerbis handguards, K&N, Xenons, Aux lamps, Bluespot calipers, Renthal 755 bars, DIY panniers, JBX-inspired gear indicator.  (Sold 2025.)
#5865 fixitsan
  • 4,852 posts
Posted 23 June 2024 - 09:47 am
Put the Ohlins to the test yesterday.
For a while I was a smiley happy person.....not like the GSXR rider I overtook.
#5866 curlylegend
curlylegend
  • 331 posts
Posted 29 June 2024 - 11:06 am
This is another good point about an early TDM 850, there are very few electronics. Recently, I'd started to notice a slight hesitance for the starter motor to engage when I pressed the starter switch.
So, better to attend to this while it's at home in the workshop. Stripping out the starter/cut-out switch was easy, two screws, no more. And the contacts inside were easy to dismantle and clean the surfaces.
No solid state sealed components to be seen !
A pleasure to work on !
And I fitted a set of Gel-filled Pro Grips while I was at it.
Attached File  DSC01455.JPG   82.95KB   0 downloads
#5867 leehenty
  • 5,323 posts
Posted 29 June 2024 - 04:07 pm
Waiting until 1st ti tax it, then its hello old friend, lets go !
#5868 leehenty
  • 5,323 posts
Posted 02 July 2024 - 11:30 am
Polishing the alloy rings of the auxiliary lights on my old TDM. This polishing obsession needs reining in.
Flushed with success, then treated it to a spray gun application of ACF50.
Edited by leehenty, 02 July 2024 - 06:38 pm.
#5869 Favs
Posted 02 July 2024 - 05:53 pm
Ahem  ...  Reining ;)
#5870 dablik
Posted 03 July 2024 - 08:20 am
Ahem  ...  Reining ;)
:lol:  yea come on Lee, thought you were proper heducated.
#5871 fixitsan
  • 4,852 posts
Posted 03 July 2024 - 11:55 am
Ahem, I laughed too....then I googled it ...
Cambridge Dictionary
rein something in
phrasal verb with rein verb
uk
/reɪn/ us
/reɪn/
(HORSE)
to make a horse go more slowly or stop by pulling on its reins
Merriam Webster
SMART Vocabulary: related words and phrases
When something is out of control—be it a government's spending or your toddler's tantrum—you might feel the need to talk about reining that out-of-control thing in—or would that be reigning it in?
The quick answer is this: the phrase you want is rein in. It's an equestrian allusion—if you rein in a horse, you pull the reins of the horse—the straps fastened to the bit of a bridle and used by a rider or driver to guide and control the horse—tight so that you control where the horse goes and how fast.
#5872 leehenty
  • 5,323 posts
Posted 03 July 2024 - 01:07 pm
The problem is the phone picking words for you
#5873 James
James
  • 572 posts
Posted 06 July 2024 - 06:28 pm
Today I fitted a USB charging lead and extracted a deceased, desiccated robin from between the engine and radiator. No idea how long it’d been there!
84 Honda XL600R  :)
04 TDM900  :good:
21 KTM 790 Adventure  ;)
#5874 fixitsan
  • 4,852 posts
Posted 18 July 2024 - 11:03 pm
Proud new owner of a late model lower front cranked yoke.
Will it make a difference to how the front feels, on my flat yoked early model ? (Not that it feels loose now)
Might swap it over on Saturday when I do the fork oil change
#5875 leehenty
  • 5,323 posts
Posted 19 July 2024 - 09:36 am
Best get that out of the kitchen, before swmbo catches you 😁
#5876 fixitsan
  • 4,852 posts
Posted 19 July 2024 - 12:57 pm
:rotflmmfao:
#5877 fixitsan
  • 4,852 posts
Posted 20 July 2024 - 05:13 pm
I cleaned the forks, in and out, and refilled them with fresh oil. 30W oil in the right fork, ATF in the left.
Turning my attention to the yoke swap I realised the yoke I bought had ball bearings, but the bike has taper roller....
I've ordered another taper bearing, and cleaned up the front end in the meantime
Edited by fixitsan, 20 July 2024 - 05:14 pm.
#5878 leehenty
  • 5,323 posts
Posted 20 July 2024 - 05:53 pm
This different fluids on each fork, whats the theory behind that ?
#5879 fixitsan
  • 4,852 posts
Posted 20 July 2024 - 09:19 pm
I have never felt there was enough rebound damping. I have the early-model years stronger springs, and longer spacer. Generally it's a firmer ride than later bikes.
So on rebound, I suspect,  the stronger springs are overcoming the limitations of rebound control.
But I also think this is linked to my body weight too, after heavy braking the forks compress greatly, after releasing the brakes the 'bounce' back up seemed to be too unsettling, like it was a bit uncontrolled.
So, it's about a year or more since I first tried it on my old 900. I put overweight oil in one fork leg and it helped a great deal, but because it was only in one leg the overall ride still felt a bit plush, not like if I had put 30W in both legs.
One of the damping functions of the fork relies on the size of the damper holes, on the damper rod, at the bottom of the fork leg. It can only be adjusted by playing with oil viscosity. If memory serves, damper rod holes control compression. So adding thicker oil resists the front end dive more by increasing compression damping
I have to remember which leg has which oil, because the top fork adjustment screw on the 'heavy' leg has a bigger effect. Overall, the adjustment range feels more useful to me, I can set it 'too much' and back it off, and retain some fine adjustment on the 'softer'  leg.
When I took my Ohlins shock to be rebuilt, I asked the expert there about it. He didn't laugh and said 'it probably works'.
I used to have reservations about inequalities in fork leg functions between both sides, but then I rode a KTM with the front end compression-only adjustment on one fork leg, and rebound-only adjustment on the other. In thiat case, they're both almost always imbalanced in terms of the forces being applied. Under braking the compression leg is taking more load.
The TDM900 has a nice thick front wheel centre axle, strongly clamped either side bridging both fork legs and keeping them both at the same distance from the yoke pretty well. After riding like that for a year or so I feel there's been no negative impact.
Edited by fixitsan, 20 July 2024 - 09:22 pm.
#5880 leehenty
  • 5,323 posts
Posted 21 July 2024 - 07:43 am
Thanks for that Ill try it
