6039 replies to this topic
#5881 trevini
trevini
  • 1,891 posts
Posted 21 July 2024 - 08:35 am
My Guzzi has independent forks for compression and rebound. Works just fine and handles very well.
The biggest difference to the forks on my 900 was fitting the emulators. Ok, it’s a faff to adjust both compression and rebound now, having to remove the springs to make an adjustment, but once set up correctly, the difference is night and day. Having the ability to adjust high speed compression and set the low speed independently means I can have a flush ride that’s fully controlled. The issue with just using heavier oil is that is affects the adjustment range on the rebound too. Necessary without emulators and with heavier springs fitted though.
#5882 fixitsan
  • 4,852 posts
Posted 21 July 2024 - 10:42 am
I have been tempted by emulators. The suspension guy recommended Andriani cartridges in fact !
I find that just using heavy weight on one leg improves the compression damping, but I can set it's rebound to the minimum setting and get away without it being too effective. The adjuster on the other leg works as normal
#5883 Bjørge
Posted 21 July 2024 - 11:55 am
Racetech emulators took the front suspension to another level on my 9er (although noticeably less capable than my Mk1 with gold valves - the best forks I've experienced so far)
#5884 fixitsan
  • 4,852 posts
Posted 22 July 2024 - 08:03 am
Thanks for that Ill try it
30W feels quite heavy on slow bumpy streets, but on high speed rollers it smooths everything out. :)
25W might be worth a try.
Having said that, and knowing that the viscosity of one manufacturers 10W is like another manufacturers 15W, there's going to be an element of playing around involved
Edited by fixitsan, 22 July 2024 - 08:04 am.
#5885 fixitsan
  • 4,852 posts
Posted 24 July 2024 - 02:53 pm
The new steering head bearing arrived, so I swapped over the original lower yoke/clamp, for the later model version and went for a ride.
The crank is obvious when you compare them side by side
Attached File  20240724_140218.jpg   283.07KB   0 downloads
The lowest clamping point on the fork leg is moved down by 30mm
Attached File  20240724_140443.jpg   143.26KB   0 downloads
The clamping boss on the later model is 40mm wide, while on the early version it's only 35mm
It's easy to say that Yamaha must have thought this was a worthwhile mod to make, because it uses more metal and needed new dies to be made, but I wasn't sure if I would feel a difference
On my favourite fast sweepers of the A70 I believe I can feel a more settled stance, especially when riding more up on the edge of the tyre than on the centre. It also feels less disturbed by undulations and hitting catseyes.
I don't know if I would suggest changing it as a matter of course, but I've only had 30 minutes of testing so far, but if you had a reason to change the 900 lower yoke I think the newer version is the right one to go for.
And a special note about the Zyliss bench vice. I bought this just because of it's wide opening, but it's a lightweight alloy, so I didn't think it was going to be strong. But, it's Swiss made, and if all you have room for is a temporary vice, it's probably worth a look !
Attached File  20240724_134241.jpg   278.87KB   0 downloads
Edited by fixitsan, 24 July 2024 - 02:54 pm.
#5886 leehenty
  • 5,323 posts
Posted 24 July 2024 - 06:22 pm
Got AliG s bike in for a bit of a fettle, one corroded exhaust stud sheared just below the surface.🤬
Time to dig out the drilling jig that was originally developed to help Moose out.
#5887 Snowbird
  • 1,473 posts
Posted 24 July 2024 - 11:15 pm
At work we get lots of sheared studs out by drilling then placing an unplated nut over and tig welding on, as the weld cools the thread contracts and loses its bite on the aluminium, admittedly we can get better access at better angles.
#5888 leehenty
  • 5,323 posts
Posted 27 July 2024 - 05:47 pm
Gave her a good clean and a polish, tomorrow is a day out for some TDM R&R
#5889 Tor
Tor
  • 76 posts
Posted 05 August 2024 - 11:11 am
Did some black-out detailing with Polytrol and fitted new 38x46x38mm graphite sleeve gaskets to my Remus link pipes (from an XJR1300) and torqued the clamps hard so they're no longer blowing. Some fjord riding scheduled for this p.m.
#5890 leehenty
  • 5,323 posts
Posted 05 August 2024 - 10:11 pm
Took the AliG bike to the annual tyre kicking session passed mot ok.
#5891 Tor
Tor
  • 76 posts
Posted 07 August 2024 - 01:36 pm
Scored a Top Sellerie saddle with gel for a princely £40 from a car(!) breaker, along with a Hyperpro 460 for £200. All looking pretty great if dusty. Treating myself to some ramen in celebration.
#5892 ramo
ramo
  • 1,190 posts
Posted 07 August 2024 - 06:45 pm
Now buy a lottery ticket  :good:
#5893 Tor
Tor
  • 76 posts
Posted 08 August 2024 - 07:39 am
Now, there's a thought!
#5894 leehenty
  • 5,323 posts
Posted 08 August 2024 - 07:42 am
Well done, a bargain. Gave my panniers a bit of a refurbish and clean ready for holiday tour in september
Edited by leehenty, 08 August 2024 - 12:35 pm.
#5895 fixitsan
  • 4,852 posts
Posted 02 September 2024 - 06:25 pm
Started to investigate the feasibility of making an engine braking control device, by (hopefully) defeating the fuel cut on overrun which is coded into the ECU
I want to make it a universal fit device, not just for TDM's. Hopefully any bike with low side switched fuel injectors, and, 3 wire stator/generators can be catered for.
Step 1 has been to create a reliable digital RPM signal from one of the phases of the stator.. Not as easy as I thought it would be but I've got it to work today.
The idea is to make it easy to install, and negate all the difficulty created by different types of crank position and cam position sensors available on different bikes
The next hard bit is going to be to make it self learning. What it should be able to do is monitor the injection system and capture the injector opening times at each RPM at minimum load, and then when decelerating generate replacement injection signals, hopefully with a 3 stage control, of full engine braking (as standard), 'some' engine braking, and 'minimum' engine braking. The minimum setting ought to emulate a carburetted bike, and eliminate choppiness at small throttle openings.
Watch this space !
#5896 Catteeclan
  • 2,572 posts
Posted 02 September 2024 - 06:51 pm
Watch this space !
Clever stuff, maybe a bit of exhaust crackle off throttle too
#5897 Snowbird
  • 1,473 posts
Posted 02 September 2024 - 09:44 pm
You mean like fitting carbs?
#5898 fixitsan
  • 4,852 posts
Posted 02 September 2024 - 10:11 pm
That's a possibility too
Well, yeah,  I mean injection is still superior to carbs but carbs had some redeeming features :badgerrock:
#5899 chrisbee
chrisbee
  • 412 posts
Posted 04 September 2024 - 05:13 pm
Just got my TDM Motd 👍👍👍
#5900 curlylegend
curlylegend
  • 331 posts
Posted 04 September 2024 - 09:33 pm
Me too. in France.  Got it's very first Controle Technique. Nothing to report apart from the not unexpected chain slack comment. Only a passing comment, and it's for 5 years not the normal 3years because it's registered as a "Vehicule de Collection".
