6039 replies to this topic
#5921 Snowbird
  • 1,473 posts
Posted 25 September 2024 - 09:38 am
Good stuff fixit!
What is doing the processing? I'm sure it was mentioned but I forgot.
This project could do with its own thread.
#5922 fixitsan
  • 4,852 posts
Posted 25 September 2024 - 09:42 am
You clever bloke. Be interesting hearing how the full on road test goes.
I'm curious too. My second 9er which I'll be fitting it to also has a Power Commander. I think I need to install my pulser after the PC, otherwise the PC might start to alter the fueling on deceleration !  I'll just disconnect the PC from the injectors at first for the initial tests.
#5923 fixitsan
  • 4,852 posts
Posted 25 September 2024 - 10:06 am
Good stuff fixit!
I'll put a new thread up :)
#5924 leehenty
  • 5,323 posts
Posted 29 September 2024 - 04:38 pm
Took it for a run out to the Super Sausage at Potterbury.  The Full Monty breakfast was possibly a step too far, but I made a heroic effort.
Edited by leehenty, 29 September 2024 - 04:39 pm.
#5925 Studley Ramrod
Posted 30 September 2024 - 06:24 am
#5926 fixitsan
  • 4,852 posts
Posted 30 September 2024 - 10:58 am
Clever stuff, maybe a bit of exhaust crackle off throttle too
Yes it does, well, not so much crackling in my Fuel cans, but burbling happens and sounds good !
#5927 Catteeclan
  • 2,572 posts
Posted 30 September 2024 - 12:01 pm
Liking this more and more. :lol:
#5928 Favs
Posted 03 October 2024 - 02:09 pm
Today - Clothes off ready for valve clearances & aux wiring tidy-up
Attached File  stripped.jpg   194.12KB   1 downloads
#5929 Favs
Posted 03 October 2024 - 02:14 pm
Modern petrol is just as tasty as the old stuff :rolleyes:
#5930 leehenty
  • 5,323 posts
Posted 03 October 2024 - 04:09 pm
Give those dangly wires a tidy up whilst you are in there Favs. Looks different from mine so I suspect its the abs variant.
Edited by leehenty, 03 October 2024 - 04:11 pm.
#5931 Studley Ramrod
Posted 03 October 2024 - 07:21 pm
#5932 leehenty
  • 5,323 posts
Posted 08 October 2024 - 06:09 pm
Fairings off, tank up for the yearly ACF50 beauty treatmen
#5933 TDrummer
TDrummer
  • 198 posts
Posted 09 October 2024 - 03:30 pm
I thought I needed steering head bearings.
Disassembled fairing and gauges - forks were bent.
Ooops!
Found new fork tubes made in Germany, shipped out of Manchester England.
Replaced lower fork clamp, tubes, seals, steering head bearings, new fork oil.
Several years ago a custom suspension shop built a very nice rear shock.
Now front and rear are better than new (Race Tech fork springs).
Handles and rides better than new.
The top end rebuild has 10,000 miles on it.
The bike is like a 32 year old new bike.
I love it.
#5934 leehenty
  • 5,323 posts
Posted 17 October 2024 - 05:53 pm
Greased all my suspension bushes, a yearly chore
#5935 fixitsan
  • 4,852 posts
Posted 24 October 2024 - 07:09 pm
I've added a brake light relay to switch the neutral wire at the ECU between high and low, as the brake light comes on and goes off
By doing that I get engine braking and fuel cutting whenever the brakes are used, but not when I'm just lifting off the throttle.
It should save a bit of fuel and restore braking to maximum when it's needed the most
Edited by fixitsan, 24 October 2024 - 07:15 pm.
#5936 Catteeclan
  • 2,572 posts
Posted 25 October 2024 - 06:40 am
That's a good idea. :good:
#5937 Studley Ramrod
Posted 25 October 2024 - 07:52 am
Ooops!
I love it.
#5938 leehenty
  • 5,323 posts
Posted 25 October 2024 - 12:12 pm
Caliper off front and rear, the rear dust seal had gone a bit so fitted new genuine seals. Rear stainless piston was fitted 15 years ago its and still perfect.
This bike has lasted well.
Edited by leehenty, 25 October 2024 - 12:13 pm.
#5939 fixitsan
  • 4,852 posts
Posted 26 October 2024 - 10:29 pm
I dodged enough rain to get up to the Green Welly at Tyndrum.
I was the only bike in the bike park ! I went in to get my usual bowl of Skull and Kink soup only to find a huge queue, so I just turned around and headed home.
It gave me a chance to really check the fuel cut idea I've been working on, and it really helped me in the sections of sweeping bends where you need to ride the throttle to balance the bike through the corners.
On overrun it burbles a bit and then when you use the brake to bring the brakelight on , after a 0.5 second delay , the note of the engine changes as all fuel is cut and there's a tad more braking.
Probably the most enjoyable part was that somehow I improved my right hand turns, which have never been as strong as my lefts, I just needed to trust in the tyres a bit more..
Attached File  Welly.jpg   201KB   2 downloadsAttached File  Welly.jpg   201KB   2 downloads
#5940 laughin in a windstorm
  • 866 posts
Posted 29 October 2024 - 04:26 am
well it is rather quiet in here compared to how it was many years ago so I thought I'd write something, I haven't done anything to my bike yet as I haven't actually got it yet but I have ordered a second hand top yoke for it, it has holes in it where forks and bolts can fit and everything  :lol:
Attached File  DSCN1000.JPG   153.97KB   1 downloads
sorry just trying out picture adding, this is its current colour, I painted it this colour on my son's request, the nose cone is fitted as the twin light set up got smashed
Edited by laughin in a windstorm, 29 October 2024 - 04:29 am.
