Service On A 9er
59 replies to this topic
#41 Alimete
Alimete
  • 1 posts
Posted 28 September 2010 - 07:24 pm
QUOTE(TonyDevil @ Tue 31st Aug 2010, 07:20 AM) <{POST_SNAPBACK}>
It's great pictures and knowledges. I changed plugs and coolant throught this datas. To take plugs out was so difficult without rubber inserted plug spanner. I use magnet for this job. (If had mistakes I'm sorry for my English)
#42 FrDougal
FrDougal
  • 28 posts
Posted 29 September 2010 - 04:19 pm
Hi, Thanks for the details. I have just followed the steps on my recently acquired nine.
Two questions....
1. There was no little tube in the front of the filter housing, I was very careful, using an old towel underneath to make sure I didn't lose anything but there was no tube? I assume I am okay to run the bike without this as there was none there anyway?
2. Where do we re-fil the oil? Is there a filler cap or do I fill through the dipstick tube?
Cheers,
Fergie.
EDIT: I filled it through the Dipstick tube, stuck a short length of garden hose on the end of a funnel and filled it easy. Also checked the seep nut up inside the left hand side of frame and the oil is seeping out okay.
Edited by FrDougal, 29 September 2010 - 04:54 pm.
#43 Guest_Kelpie_*
Guest_Kelpie_*
Posted 29 September 2010 - 04:52 pm
QUOTE(FrDougal @ Wed 29th Sep 2010, 05:19 PM) <{POST_SNAPBACK}>
EDIT: I filled it through the Dipstick tube, stuch a short length of garden hose on the end of a funnel and filled it easy. .
#44 FrDougal
FrDougal
  • 28 posts
Posted 29 September 2010 - 04:54 pm
QUOTE(Kelpie @ Wed 29th Sep 2010, 05:52 PM) <{POST_SNAPBACK}>
#45 Guest_Kelpie_*
Guest_Kelpie_*
Posted 29 September 2010 - 04:55 pm
QUOTE(FrDougal @ Wed 29th Sep 2010, 05:54 PM) <{POST_SNAPBACK}>
#46 td or sv? That is the question.
  • 111 posts
Posted 30 April 2011 - 05:05 pm
With the help of my mechanic brother (thanks, Bob!), I've just serviced my 900 - many thanks to CB for the write-up and photos, it made the job a breeze.
#47 TDMTAM
Posted 18 July 2011 - 06:09 pm
18,000 mile service coming up. Well the telly is crap tonight.
#48 jonniefartbox
jonniefartbox
  • 83 posts
Posted 30 August 2012 - 06:25 pm
great write up just done mine today oil & filters , them screws are a bugger if you dont look where they come from . unsure.gif
must admit i did a cock up & removed 2 other bolts further back & not on housing -- but i replaced them straight away .
all seams ok give it a test ride in the morning & a good clean for mot on monday .
just gotta sort out why the oil warning light is staying on .
Edited by jonniefartbox, 31 August 2012 - 10:29 pm.
#49 keithrzv500r
keithrzv500r
  • 42 posts
Posted 30 December 2013 - 12:55 pm
EDIT: Post edited to remove unnecessary quote. SR.
Celticbiker, just asking did you do a write up on synchronizing the throttle bodies??
thanks again
regards   keith
#50 gilly
gilly
  • 61 posts
Posted 15 June 2014 - 09:49 pm
Just changed spark plugs and wouldnt have been able to do it without this guide
Fantastic
cheers
gilly
ps only had the tdm a month wish i'd bought one years ago
A shin is a device for finding furniture in a dark room
A sure cure for seasickness is to sit under a tree
#51 TDMick
Posted 16 June 2014 - 06:57 am
Fantastic
cheers
gilly
Welcome to house of fun.
#52 tediumwannabe
tediumwannabe
  • 198 posts
Posted 21 January 2015 - 08:46 pm
Just spotted this service guide. My weekend is sorted........
FAB-U-LOSO!!!! :badgerrock:
#53 Jim850O
Jim850O
  • 9 posts
Posted 26 October 2015 - 02:29 pm
Thanks for the great photos of the oil change procedure.  I have never before (in 47 years of riding) had a bike with such a convoluted oil change routine.  Still, I love the '92 TDM.  What frustrates me most is the worsening oil leak I have been experiencing at the oil filter housing - even getting oil sprayed onto the right side of the rear tire - most disconcerting!  Having bought an "experienced" TDM in 2008 I was gifted with case threads that had already been partially stripped so that even after replacing some of the bolts it is impossible to get the proper torque on them.  Any suggestions?  I am nearly ready to try heli-coils, but one friend suggested tapping out the case threads to the next larger size.  Thanks!
#54 Studley Ramrod
Posted 26 October 2015 - 02:44 pm
I'd go for helicoils Jim, no more worries about stripping out threads then.  Make sure you're using the correct length bolts in the filter housing as they're different lengths and it's easy to put the wrong length bolt in and strip the thread.
#55 Pict
Posted 27 October 2015 - 08:32 am
.. , them screws are a bugger if.....
How very true, even after all the years..
#56 Jim850O
Jim850O
  • 9 posts
Posted 27 October 2015 - 02:43 pm
Thanks - I will go for the heli-coils - it doesn't look like a DIY job though.  I think I have the bolts in correctly by length, but who knows if they were right when I bought the bike.  I will check the manual and take the filter off again to make sure.  After another, closer examination of the tightness of them it seems that there is only one bolt that is not cinching down properly, so I will target that for the first heli-coil.  Your help is certainly appreciated. :)
#57 HighTower
HighTower
  • 4 posts
Posted 07 August 2017 - 03:06 pm
Hi all!
Sorry for the noob question but I cant see the pics?
Something abou Photobucket account?
Btw the original post (2009) is written better than iFixit procedure! Excellent post!
Thx and sorry once again for nagging form get go (I've been following the carpe for years but belive this is my first or second post...)
Brgds
HighTower
#58 Studley Ramrod
Posted 07 August 2017 - 03:24 pm
Yeah, it's photobucket that's messed it all up.  I think they want to charge members for hosting photos and members probably don't want to pay.
#59 TDM4ever
TDM4ever
  • 302 posts
Posted 07 August 2017 - 04:29 pm
Hi all!
Brgds
HighTower
It is indeed a good write up (even without the pictures).
Just note that you do not need to undo the oil galley bolt mentioned (when changing oil).
It is only needed on a totally dry engine (e.g. after a rebuild). No need to undo it when doing regular oil changes.
Edited by TDM4ever, 07 August 2017 - 04:31 pm.
#60 HighTower
HighTower
  • 4 posts
Posted 07 August 2017 - 04:34 pm
Thx for speedy replies!
Good to know about galley bolt, that means that only carter and oil filter bolts are enough. Than I can do without the pics!
brdgs
HT
