Stator Removal / Replacement Write Up
69 replies to this topic
#41 dablik
Posted 18 September 2013 - 08:22 pm
Sounds possible, i think, but did'nt Ali's bugger up on tour !!
#42 celticbiker
celticbiker
  • 1,726 posts
Posted 18 September 2013 - 08:43 pm
Good point that man.
One of mine did go about a week after an oil change but I've had one go in between too.
#43 MarkyMark
MarkyMark
  • 981 posts
Posted 19 September 2013 - 08:13 am
Sure - its anecdotal evidence.
The area at the top of the stator appears to be is insufficiently cooled - mine has flaking paint on the to of the stator cover. I think the potential restriction in oil flow rate could exacerbate an existing hot spot and just tip it over the edge. If I recall correctly, Ali had performed a service prior to his touring incident; as had I prior to the Monshau RTT this year.
With a decent battery on the bike, the failure could take some tome to manifest itself. I got all the way home from the Monschau RTT without a generator on a single battery.
XT1200Z - Big and bouncy
GTR1400 - Chaufer the wife.
XT660Z - Fun and commute.
TDM900 - Yellow.
#44 Rallyist
Posted 19 September 2013 - 08:28 am
Yes mine that failed earlier this year was during the first ride after a service and showed evidence of overheating at the top where all the tails are connected ;)
#45 dapleb
  • 18,399 posts
Posted 19 September 2013 - 08:41 am
Well done bhoyos you moight be on to zummat there.
I am not sure that pre-soakin yer filter will make mush difference but identifrying the problem is alot of the battle.
At some point oil git me 9'er wan rewound and we can have a core for emergency distribution.
#46 Studley Ramrod
  • 19,372 posts
Posted 19 September 2013 - 09:13 am
It's certainly explain why a lot of 9'ers have flaking paint on the stator cover.  Could be onto summat there Mark.
#47 dmmsta
dmmsta
  • 3,627 posts
Posted 19 September 2013 - 09:43 am
Can't remember how soon after the last service mind died.
All I know is that it happened within days of getting stuck in a snow storm, and had made the journey home from work at about 5mph most of the way, which I put down to the failure.  Headlights on, heated grips on (MAX), and very little charge going back in.
#48 dablik
Posted 19 September 2013 - 09:53 am
Hmm sounds like a good possibility,, Markymark you shall be for ever known as Sherlock if ya right  :)
#49 MarkyMark
MarkyMark
  • 981 posts
Posted 01 November 2013 - 02:50 pm
OK - so 4,00 miles later and its gone again - well and truly burnt out - again all across the top.
This time I am going to investigate the oil route into the area. The manual describes holes in the shaft which provide oil to the area. I may well poke these with a wire or summat and see if there is any crud in them.
TDM900 - Yellow.
#50 dapleb
  • 18,399 posts
Posted 01 November 2013 - 02:58 pm
Will be interestin to know what ewe find MM.
#51 Studley Ramrod
  • 19,372 posts
Posted 01 November 2013 - 03:07 pm
Not 100% sure but I think the rotor also has owil oles.
#52 Rallyist
Posted 01 November 2013 - 04:12 pm
Was that a rewound one Mark or a used item??? also why do 850's not appear to do this???
#53 MarkyMark
MarkyMark
  • 981 posts
Posted 01 November 2013 - 05:18 pm
Studly - Thanks - will look closely when I get the rotor off. - just taking my time - not sure how I know he rotor position - I have to maintain the TDC mark in the correct position. But the 3 allen bolts look equidistant. Is this where the woodruff key comes into its own?
Yes it was a rewind from the guy in Torquay. I have a spare from him which is going in.soon as I figure out how to do the loom bits. He rewound both for me last time and gave me enough wire to get to the connector.
TDM900 - Yellow.
#54 MarkyMark
MarkyMark
  • 981 posts
Posted 01 November 2013 - 05:32 pm
Loom dimensions
Edited by MarkyMark, 01 November 2013 - 05:33 pm.
TDM900 - Yellow.
#55 Studley Ramrod
  • 19,372 posts
Posted 01 November 2013 - 09:05 pm
The woodruff key lines up with an arrowhead mark on the casing on the 8fiddly. :)
Here's a pic of my rotor showing the oil holes around the edge of the rim.  Dunno if yours is the same or not.
#56 dapleb
  • 18,399 posts
Posted 01 November 2013 - 09:47 pm
Ears an udder view of the badger (on a mkI):
Attached File  rotor_oilways.JPG   85.6KB   16 downloads
And ears ya rough-wood key arrow:
Attached File  rough_wood.jpg   65.89KB   15 downloads
#57 celticbiker
celticbiker
  • 1,726 posts
Posted 01 November 2013 - 10:50 pm
How many miles is that Mark?
4, 400, 4000 or 40000
#58 MarkyMark
MarkyMark
  • 981 posts
Posted 02 November 2013 - 05:33 pm
That was 4,000 miles - replaced following failure on the 2013 RTT.
I have found a guy in Swindon who is a motorcycle wire/electrics specialist.
When I explained what was happening, he said he did not feel it was a cooling issue. He said it would take a massive earth to burn it out as badly as mine was. He wants the bike, when I have fitted the new stator, to do some diagnostic measurements through the R/R.
I fitted a voltmeter to my dash this afternoon. Will fit new Stator next Saturday morning and update this thread with info.
TDM900 - Yellow.
#59 Pantboy
Pantboy
  • 900 posts
Posted 02 November 2013 - 08:28 pm
had to have my 850 stator rewound at around 31000 miles
#60 dapleb
  • 18,399 posts
Posted 02 November 2013 - 09:19 pm
Are all the peeps with failures are also running loads of doo-dads on their boikes? Heated toe nails or sat nav radio FM camera HID side horns?
