1991 Tdm 850 Mk1 Project By Margus
177 replies to this topic
#41 Margus
Margus
  • 133 posts
Posted 25 December 2011 - 06:43 pm
Engine was really easy to remove: Just disconnect all the wires and hoses. Place a wood bock unber the engine. Unscrew all the bolts and lift the frame from the engine.
And by the way, frame didn't had a crack on the inside.
Work on my bike hasn't ended jet!
#42 dapleb
  • 18,385 posts
Posted 25 December 2011 - 07:41 pm
QUOTE(Margus @ Sun 25th Dec 2011, 06:43 PM) <{POST_SNAPBACK}>
#43 3vd
Posted 27 December 2011 - 06:22 pm
#44 Margus
Margus
  • 133 posts
Posted 28 December 2011 - 05:18 pm
And I've got a naked frame:
I'm gonna sandblast it and repaint it black.
#45 Margus
Margus
  • 133 posts
Posted 29 December 2011 - 05:50 pm
Today I spent a whole day cleaning frame, swingarm, engine and rims from oil and other sh*t.
Edited by Margus, 29 December 2011 - 05:51 pm.
#46 Margus
Margus
  • 133 posts
Posted 01 January 2012 - 07:52 pm
Today was a failure. I tried whole day to get rid of the bolt witch I broke while removing the engine. I tried heat, heat + rostoff ICE, then I drilled the bolt through and tried a special tool for unscrewing broken bolts. I broke this tool and a half of it staid in my engine. Fuck Fuck Fuck.....
How the hell will I get it out of there?
#47 Studley Ramrod
Posted 01 January 2012 - 10:23 pm
Could you weld a rod onto the broken part and then turn it out ? Or file a couple of flat sides and use a spanner unsure.gif
#48 3vd
Posted 01 January 2012 - 10:38 pm
Spark erosion?
#49 Margus
Margus
  • 133 posts
Posted 02 January 2012 - 09:33 am
QUOTE(Studley Ramrod @ Mon 2nd Jan 2012, 12:23 AM) <{POST_SNAPBACK}>
I've thought on that. It's worth a try.
QUOTE(maximuspetrolhead @ Mon 2nd Jan 2012, 12:38 AM) <{POST_SNAPBACK}>
Spark erosion?
I do not have acess to this technology
#50 Studley Ramrod
Posted 02 January 2012 - 10:13 am
Or maybe press it out with some kinda G clamp/ bearing press doohickey, not much room for manouvering tho.
Fingers crossed for ya !
#51 Rallyist
Posted 02 January 2012 - 01:02 pm
The lucky part of this is it is a tapered bit that is still in the engine.
#52 LewisBlackburn
LewisBlackburn
  • 1,748 posts
Posted 02 January 2012 - 03:03 pm
Could you drill it out and tap it out larger,
So when refitting the engine you'd just use a larger bolt?
#53 dapleb
  • 18,385 posts
Posted 02 January 2012 - 03:06 pm
Easyout is made of very hard and brittle stuff so drilling will be a painful option. Swearing it out didn't work.
At least you can still reach the end of it and it didn't snap flush. Gives you a few options at least.
#54 Margus
Margus
  • 133 posts
Posted 02 January 2012 - 08:00 pm
Tried welding method. It didn't work as this tools metal is not weldable. Welding just snaps off.
Edited by Margus, 04 January 2012 - 09:37 pm.
#55 MikC
MikC
  • 159 posts
Posted 02 January 2012 - 08:47 pm
QUOTE(maximuspetrolhead @ Sun 1st Jan 2012, 10:38 PM) <{POST_SNAPBACK}>
Spark erosion?
Yep. Spark erosion.. Done it. Have to remove engine though. Try to much on your own and it will get worse..............
Mik
''Work'' The horrible four letter word
#56 Margus
Margus
  • 133 posts
Posted 04 January 2012 - 08:55 pm
Frame and swingarm are sandblasted and primered. Gonna paint them tomorrow (hopefully).
I got my engine mount OK now. There is a M14 thread now.
Hope to upload pictures in this evening
#57 Margus
Margus
  • 133 posts
Posted 04 January 2012 - 09:45 pm
Partly sandblasted frame:
Primed: I used a marine grade primer. It's just the best!
I got my engine monut OK now. Used this tool to cut "around" the bolt.
M14 bolt: I know it's fucking big, but it was the olny way.
Edited by Margus, 04 January 2012 - 09:45 pm.
#58 aircooled68
Posted 04 January 2012 - 10:47 pm
#59 wicklamulla
Posted 04 January 2012 - 11:37 pm
good work marine.
#60 Studley Ramrod
Posted 05 January 2012 - 09:39 am
