Global Positioning System
136 replies to this topic
#41 trevini
trevini
  • 1,885 posts
Posted 20 February 2012 - 08:37 pm
.gdp I think. Try them. They'll either load up and work, or they won't!
#42 dapleb
  • 18,373 posts
Posted 20 February 2012 - 09:51 pm
QUOTE(dapleb @ Mon 20th Feb 2012, 07:03 PM) <{POST_SNAPBACK}>
Ahaaaaaaaaaaaaaaaaaaaaaaaaa. http://opencyclemap.org/ kerblammoooo. badgrock.gif
And from a Trev linky dink tis posisble to downloadify the cycle specific maps for noubt!
Premade: http://wiki.openstre...Garmin/Download
Build Yer'sen http://wiki.openstre...armin/Cycle_map
#43 wicklamulla
Posted 21 February 2012 - 06:38 am
krist this is invaluable research, well done chappers.
#44 dapleb
  • 18,373 posts
Posted 26 February 2012 - 02:28 pm
Bought me'sen an E-Trex 20 (thanks for the suggestion Chris). Very happy with it, very powerful and I am struggling to work out the basics at the mo but getting there very slowly.
ETrex don't come with half the stuff Trevs had. In the box: Unit, USB cable...thats it! Have bought, screenprotectors, 2GB Micro SD card, RAM mount (after reading very bad reviews about poo Garmin plastic strip/cable tie mount for £14!!!).
Have managed to get software on PC (Garmin BaseCamp), Setup directories and files on SD card so software is tricked into thinking its the actual GPS unit. Downloaded GB treader maps onto the SD card but when installing the SD Card into the GPS it don't find the maps!!?!?!? Progress will be slower now Carpe working. unsure.gif
Have also been out on treader track plotting so have to figure out how to save tracks and view on PC.
Your loaner should be in the post tomato Trev. Thank you very m,uch for the borrow, t'was a huge help. good.gif
#45 trevini
trevini
  • 1,885 posts
Posted 26 February 2012 - 05:27 pm
Welcome anytime Dappers, but no rush to get it back. It would be interesting to know how the two units compare for ease of use etc. There was an extra £200ish worth of extras (maps, mounts etc) when I bought mine, so don't feel too bad about having to buy stuff.
I've not used basecamp, but I would think the unit will have something in the options menu to swap mapsets. As for saving tracks, that will be found in the setup menu to just toggle on/off and probably a separate icon for saved tracks.
#46 Rallyist
Posted 26 February 2012 - 05:46 pm
QUOTE(trevini @ Sun 26th Feb 2012, 05:27 PM) <{POST_SNAPBACK}>
Garmin have now released a number of tutorials for Base Camp
HERE
Edited by Rallyist, 26 February 2012 - 05:46 pm.
#47 dapleb
  • 18,373 posts
Posted 26 February 2012 - 06:04 pm
Ta Trev, now have the maps on ok and can select or deselect on the GPS. Thanks for tacks info, that worked great. Todays track saved.
Rally I tried looking at them vids but didnt find em particularly enlightening and on very slow interweb so gave up trying to load the vids and worked it out with some Google searches and the Wiki attached to the excellent openstreetmap website.
Have now got the UK Velo maps working badgrock.gif , the attached .bat file was erroring and not creating the .IMG file so used BaseCamp to make selections rather than copying whole map and all is good, just need to rename the created .img file every time to not overwrite previous map, then all required maps can be selected and overlayed (or not) and stored on the same SD card. Now downloading France. smile.gif
Next step is trying to create a route huh.gif and then trying to download a route I want to use and somehow attaching all that to a map.
#48 Studley Ramrod
Posted 26 February 2012 - 10:14 pm
#49 dapleb
  • 18,373 posts
Posted 04 March 2012 - 01:09 pm
Did my first test run of a PC planned route yesterday on the treader. So now I know the unit is waterproof. rolleyes.gif
Several things that were unexpected. My route planning though only over a short distance had 100's of route markers as it was on tiny tracks and thats how I planned it on the PC. Didn't realise the unit was gonna "BONG" "BONG" "BONG" "BONG" at every marker. laugh.gif also I missed a marker and it got very upset, would no longer "BONG" and for the rest of the trip tried to make me return to that point. It also would not keep my position central and move the map, so I had to keep on scrolling to find my pointer, think I have that sorted now.
Is there an easy way to make these things forget a marker and carry on? On the road without the 57 page A4 manual I couldn't sort it...and then on return discovered the info isnt in there anyways. Have read suggestions on web about deleting the marker but no idea how to tell which one of the 100's it was. smile.gif
#50 ChrisG
Posted 04 March 2012 - 01:14 pm
Does it let you edit the route once you've loaded it? On my tomtom you go to the itinerary, select the way point and mark it as visited, visited ones are greyed out so it's easy to spot the next one in the list.
Can your phone handle PDF documents? I tend to stick manuals on mine so I can look them up wherever I am
Edited by ChrisG, 04 March 2012 - 01:15 pm.
#51 trevini
trevini
  • 1,885 posts
Posted 04 March 2012 - 01:19 pm
I think you can turn the warning sounds off, or at least alter the volume/tone used to something more or less annoying according to taste.
I usually number the waypoints in a simple numerical order rather than perhaps place names. Personal preference really and finding what works best for you. It appears that you need to be very careful with the positioning of the waypoints if it's that sensitive to missing one. Maybe try keeping the waypints to a minimum and only place them just past junctions to force it to turn you in the right direction rather than think for itself. Sounds like you are on the right track (pun intended).
#52 dapleb
  • 18,373 posts
Posted 04 March 2012 - 01:22 pm
Yeah when I got back I found a way to list all of the points on the GPS and edit but there were literally 100's of them so no idea how I would find the relevent one. Would have thought there was some "ignore" type option once you have missed it but apparently not. More tinkering required and less points settings if possible.
No my phone could hold the doc on SD card (as does the GPS) but not clever enough to access it.
#53 dapleb
  • 18,373 posts
Posted 04 March 2012 - 01:34 pm
QUOTE(trevini @ Sun 4th Mar 2012, 01:19 PM) <{POST_SNAPBACK}>
Yeah I found the option to turn the "BONG" into a "BING" and also off. It is quite useful to have it...just not every 10metres. User error there as I didn't realise when plotting the route that every time I built a new section it was going to mark them as points. Will have to have a look again at how I can zoom in so as to avoid wayward marker but select a big enough section ferret not to BONG every 5 seconds. The missed point I noticed was because I had zoomed out to avoid all of these points when plotting on PC and a glitch on the map made a 10M venture off the track into the hedge. I left it there when planning on PC as I was interested to see what the unit would do.
The freebie cycle maps are ace, cycled a canal section and it then took me down a railway cyclepath I have passed many times but didn't even know existed. Very very neat. The weakest link is defintely me here so alot more trial and no doubt error is required before the Tour De Treader.
Remembered whilst on route that I may have put your unit on the "Cycle" profile rather than car/van and forgot to set back Trev. sorry.gif
#54 Rallyist
Posted 04 March 2012 - 01:38 pm
QUOTE(dapleb @ Sun 4th Mar 2012, 01:09 PM) <{POST_SNAPBACK}>
That's the trouble with a myriad of vias GPS likes you to hit every one or will try to take you back and abort the rest till you do.
#55 trevini
trevini
  • 1,885 posts
Posted 04 March 2012 - 03:14 pm
Don't sweat it Dappers. It could be intresting if I was in the Rangie, though. rotflmmfao.gif
#56 stu
stu
  • 2,060 posts
Posted 05 March 2012 - 03:00 pm
QUOTE(dapleb @ Sun 4th Mar 2012, 01:34 PM) <{POST_SNAPBACK}>
That's the best excuse ever - worth saving that for when you need it laugh.gif
#57 dapleb
  • 18,373 posts
Posted 05 March 2012 - 03:05 pm
#58 Studley Ramrod
Posted 05 March 2012 - 07:25 pm
Gonna be a lorra BONGS before ya get to Spain innit ! blink.gif Or are ya getting the ferry to Santander ?
#59 dapleb
  • 18,373 posts
Posted 05 March 2012 - 07:51 pm
Yeah bongtastic. Wanted ride doon (South is downhill right?) and ferret back but cous of ferret availability its Ferret doon roide ooop. All booked now so its time to suss this GPS enough so oi dunt get annoyed and chuck it in El Hedgio.
Re-plotted my first trip with about 100 less BONG points so am gonna have a rerun at some point. Found an excellent GPS tutorial, written by a normal user for incompetents loike me'sen and it really really made sense. He has broken it down into sections, so you can master one stage before conffuzzlin the shebooniegons oot of yersen with the next. I can get less Bongpoints and an easier to plot route using waypoints rather that direct routing (what I have been doing) but routing using waypoints seems more suitable to road use than tracks and railways and tings.
#60 Studley Ramrod
Posted 05 March 2012 - 09:41 pm
You seem to be making good progress with the learning bit smile.gif Think I'd have launchio'd the unit way before now.
