Wet Weather Rough Running: Coils and Leads
116 replies to this topic
#41 BN2TDM
BN2TDM
  • 384 posts
Posted 04 May 2008 - 04:27 pm
Well I got bored earlier so I decided to attack the coil for the last time.
I did notice though that if you look at the gap inbetween the top of the tank and the bottom of the top headrace, there is a channel in the top of the frame. I did a little test with a syringe of water, and the water runs down this channel... and drops straight onto the l/h mounting post of the coil where the earth connector is, and also hits the connector on the coil that sparks!
There's also a strip of sponge around the front edge of the tank that I suppose is there to stop vibrations. I made that wet (as would happen if the bike stood in the rain all day). Once the sponge became waterlogged, the water was draining down that channel - and onto the connector and earth connection!!
So I removed the coil and took all the melted amalgamating tape off (it melted cos I sprayed it with damp-start last time ranting.gif ) and taped it up again PROPERLY. I also covered up the offending connector itself and once the coil was attached back onto the frame I covered the l/h post too. So now all that is visible is the positive connector; I say positive cos the wire is red unsure.gif Having re-connected all the battery connections, I started her up and squirted water all over the covered connection and the bike didn't stutter once. good.gif
Just before putting the airbox back on, I emptied an ice cream tub (raspberry ripple with bits of cake in it...yummy munching_out.gif ) and cut a strip (about 5 inches wide) ot of the bottom of it. I taped this plastic to the front of the airbox up under the sponge with gaffa tape so that when the airbox was replaced it hung down in front of the coil like a shield. Tested it with the syringe and the water ran down the plastic and didn't go near the coil wifgeni.gif
Hopefully this is the end of the problems. I dread to thing what a mechanic would think if he saw it. It's a definite bodge job, but just maybe its one of mine that actually works!!!!
Who on earth made me get a ZX9R???? I'll get 'em....
#42 Guest_Pantboy_*
Guest_Pantboy_*
Posted 04 May 2008 - 04:55 pm
you will have to report back on this once you have been out in the rain next time (shouldn't take too long) cos if this works mine will be coming apart to get the same treatment, although i would probably use a tub of neopolitan ice cream.
#43 BN2TDM
BN2TDM
  • 384 posts
Posted 04 May 2008 - 04:56 pm
QUOTE(Pantboy @ Sun 4th May 2008, 05:40 PM) <{POST_SNAPBACK}>
Should have done some pics; if I can get hold of a camera I will whip the tank off and take some.
#44 wicklamulla
Posted 07 May 2008 - 08:49 pm
QUOTE(brightonTDM @ Sun 4th May 2008, 05:12 PM) <{POST_SNAPBACK}>
well done that man !!!! i now remember reading about 4 years back that a TDM owner removed the sponge and used a strip of gaffa tape on each side of the fuel tank/frame spar interface and this fixed their wet weather running !!! BrightonTDM oil look at doin something similar as i had wet weather running probs. a few weeks back despite using self amalgamating tape and silicone etc, etc. good work.
#45 contractor
contractor
  • 2 posts
Posted 12 May 2008 - 08:02 pm
Just got back from a weekend trip to Scotland - it was a long way to find the only rain in the UK! My new 900 played the bucking bronco thing around Glasgow. Lots of talk of self amal'gum'ating tape so i've just bought some - not fitted it yet. Doesn't somebody make some top quality HT leads that arn't affected by a bit of H20 ?
#46 wicklamulla
Posted 12 May 2008 - 10:45 pm
QUOTE(contractor @ Mon 12th May 2008, 08:47 PM) <{POST_SNAPBACK}>
how ya contractor, yer HT leads might be arching against the frame spars.
#47 contractor
contractor
  • 2 posts
Posted 13 May 2008 - 11:34 am
QUOTE(wicklamulla @ Tue 13th May 2008, 12:30 AM) <{POST_SNAPBACK}>
Yup i'm going to check that as well when I can get round to taking all the plastic off (again).
Would any HT lead do the same or is that Mr Yamaha has skimped a bit with the quality of his original fitment leads?
#48 BN2TDM
BN2TDM
  • 384 posts
Posted 15 May 2008 - 04:59 pm
Touch wood, but it sees to have worked!!!
Just as I left for work this morning, the heavens opened. And I mean opened.
The bike ran fine. No massive drops in revs or misfires (it does idle a bit rough anyway - carbs need doing). I didn't approach traffic lights with the "Oh sh*t I'm don't want to stop 'cos it will conk out again" feeling I usually get in the wet.
Then it sat out in the rain all afternoon. Ran fine on the way home (although it wasn't raining by home time and the roads were dry).
I should have a cam at the weekend, so in the afternoon I will do some pics.
#49 BN2TDM
BN2TDM
  • 384 posts
Posted 24 May 2008 - 01:15 pm
Some pictures as promised.... sorry the quality isn't that great, but the camera on my phone is pants!!!!! ranting.gif
#50 wicklamulla
Posted 24 May 2008 - 11:10 pm
good lad but we can't read that blurred red print on some of yer pics. i get the general idea though.
#51 Chatty
Chatty
  • 30 posts
Posted 27 May 2008 - 11:39 am
This post has made some good lunch time reading, unfortunately I am sat at work, TDM is outside, it's raining and I haven't done the waterproof mod yet. Fortunately the previous owner has fitted a fender extender so it may save me this time. I also have some glue type heatshrink on it's way so will combine this with some of the other great suggestions. BTW my XTZ never had any problems whatsoever, even whilst fording!!
ATB
Chatty
1999 TDM 850, Micron 2-1, Scottoiler, fender extender, Givi top box mounted on rear grab rail,
#52 TonyDevil
Posted 27 May 2008 - 11:51 am
QUOTE(Chatty @ Tue 27th May 2008, 12:24 PM) <{POST_SNAPBACK}>
dont worry, not all TDMs have the wet weather problems
mine is still on the original coils/leads etc and they havent been touched......
#53 Guest_Pantboy_*
Guest_Pantboy_*
Posted 28 May 2008 - 04:09 pm
QUOTE(brightonTDM @ Thu 15th May 2008, 05:44 PM) <{POST_SNAPBACK}>
Nick, i owe you a pint, took my bike apart on sunday and copied your plastic shield idea (no ice cream tubs though so i used an empty screen wash bottle)
came home from work today in an absolute deluge, and not a hiccup or splutter from the engine, was even confident enough to filter on the motorway which i would never dare do in the rain before just in case it surged.
the bike is even running better in the dry which i am putting down to the HT leads, when i removed the coils and leads to apply yet more self amalgamating tape the leads were loose at the coil and plug cap end. ohmy.gif so i tightened them up and hey presto better performance in the dry too.
ps. have you changed your name cos your thinking of getting a 900. tongue.gif
#54 BN2TDM
BN2TDM
  • 384 posts
Posted 28 May 2008 - 06:52 pm
QUOTE(Pantboy @ Wed 28th May 2008, 04:54 PM) <{POST_SNAPBACK}>
Nick, i owe you a pint pint of milk yes, I don't drink..., took my bike apart on sunday and copied your plastic shield idea (no ice cream tubs though so i used an empty screen wash bottle)
the bike is even running better in the dry which i am putting down to the HT leads, when i removed the coils and leads to apply yet more self amalgamating tape the leads were loose at the coil and plug cap end. ohmy.gif so i tightened them up and hey presto better performance in the dry too. That's spooky cos I did the same
ps. have you changed your name cos your thinking of getting a 900. tongue.gif You must be joking - now my TDM is cured the love of it has been rekindled. I was ready to chop it in and buy my mates R6!!!
I could probably do away with all the amalgamating tape on the coil now, but as it's there I'll leave it for now.
Edited by BN2TDM, 28 May 2008 - 07:05 pm.
#55 wicklamulla
Posted 28 May 2008 - 10:04 pm
Nick does that shield protect both coils ???
#56 BN2TDM
BN2TDM
  • 384 posts
Posted 29 May 2008 - 05:30 am
I'll have a look on Saturday
The left hand one on my bike is buried under the wiring loom and IIRC the connectors point INTO the middle of the bike.
Will report back.
#57 Guest_Pantboy_*
Guest_Pantboy_*
Posted 29 May 2008 - 08:10 am
wicky, when i did mine at the weekend i made it wider than Nick's, but offset it so it shielded both coils, (the left hand coil was more corroded than the right hand one on mine) i also made it longer and cut/shaped it to go around the various frame mounts.
#58 wicklamulla
Posted 31 May 2008 - 01:37 pm
QUOTE(Pantboy @ Thu 29th May 2008, 08:55 AM) <{POST_SNAPBACK}>
thas what i'm gonna do on both me TDM's. it always seems to be the LHS coil that suffers the most.
#59 wicklamulla
Posted 15 June 2008 - 01:45 am
ok i sorted me udder TDM's coils and HT leads d'udder day. I used a section of old plastic milk carton and cable ties to shroud the lhs coil but used an old mountain bike inner tube and cable ties to do a neater/better job on the rhs coil, basically i managed to cover up / protect the electrical connectors relating to each coil too as these get wet and corrode. I also decided to remove the grey sponge from the airbox as it holds alot of water when wet and probably add to 'the problem'. Sliding the inner tube over the coil was difficult so i used WD40 to help ease it on without tearing the rubber.... as you can see from the pics. i also used self amalgamating tape and black silicone to waterproof the HT leads and plug caps aswell as helping to prevent the leads from partially unwinding over time.
Edited by wicklamulla, 15 June 2008 - 01:57 am.
#60 wicklamulla
Posted 21 June 2008 - 04:34 pm
so maybe it's back to the 'drawing bored' huh.... laugh.gif biggrin.gif wacko.gif
http://www.carpe-tdm...amp;#entry88120
