Top box advice........
61 replies to this topic
#41 mr sat nav
mr sat nav
  • 159 posts
Posted 03 January 2007 - 08:44 pm
Nice one! Still looking forward to seeing them as I haven't made a final decision yet, still tempted to have a bid on the grab rail plates on ebay though, you never know!!
IPB Image
#42 Pict
Posted 03 January 2007 - 08:47 pm
QUOTE(amarko5 @ Wed 3rd Jan 2007, 08:00 PM) <{POST_SNAPBACK}>
My appologies to both yourself and mr sat nav, I did promise some piccies of my installation.
well been on 12 hour nights last 3 days so not seen daylight at all.
however armed with a torch i shall go see if i can get some pictures now in the shed rolleyes.gif be back soon smile.gif
Hold on Amarko, don't go crawling bleary-eyed into a dark shed looking for a black bike. it can wait...... too late?? blink.gif
#43 Hartside Man
Posted 03 January 2007 - 08:55 pm
QUOTE(mr sat nav @ Sat 30th Dec 2006, 04:29 PM) <{POST_SNAPBACK}>
I think for the amount of time I am looking at using the top-box, really for trips away, the cheaper option that attaches to the grab rail looks best. If I was going to use it all the time I would probably go for the more expensive luggage rack + a box.
The seller on ebay has a shop so is unlikely to sell out of box's, I would like to see a picture of what yours looks like amarko5 before I buy one.
right here goes, this is the plastic plate provided with the top box (with the plastic trim cover removed)
here you can see the placement of the plate on the rack, note how the slot at the rear of the rack falls above the two grabrail mounting screw (important). I removed the bike rack to do this and at first made the mistake of not dropping the mounting bolts for the rack into their holes and after fitting the plate (doh) realised i had to remove it again to drop the bolts in.
you will see that the position if the provided clamps means the box cannot move side to side as it the clamps are positioned so as to stop this. the two clamps at the rear then stop rearward movement as well.
look through the pictures and you will probably grasp what i am saying easier than explaining it in text. you will see if you look closely rolleyes.gif the quadruple folded anti slip blanket between the plate and the rack.
the other clamps can be seen here
and here
this works with the monolock system with a provided plastic plate, i cannot speak for a monokey system or even the alloy plates. and the installation was carried out using only the supplied bits from the plate mount kit (apart from the matting)
EDIT: BTW this fitting does not involve drilling the existing rack and as such can go back to standard at anytime with little effort. and if you protect the existing rack with the matting it should be good as new when removed wink.gif
Edited by amarko5, 03 January 2007 - 11:19 pm.
#44 Pict
Posted 03 January 2007 - 09:04 pm
Another one for the knowledge base, Admin?
Edited by Pict, 03 January 2007 - 09:06 pm.
#45 Hartside Man
Posted 03 January 2007 - 09:09 pm
QUOTE(Pict @ Wed 3rd Jan 2007, 08:49 PM) <{POST_SNAPBACK}>
BTW in this position the box is just in the right place for a pillion backrest good.gif any further forward on the bike would make it uncomfortable
#46 mr sat nav
mr sat nav
  • 159 posts
Posted 04 January 2007 - 08:44 am
Hi amarko5 thanks for popping on the pictures and braving the dark shed!
Just to confirm this is the top box and base that you gave me a link to earlier in this thread?
IPB Image
#47 twinrider
twinrider
  • 246 posts
Posted 04 January 2007 - 12:57 pm
Just my $0.02 but if Givi thought the TDM stock rack could handle the weight of a loaded top box over an extended period of time they probably wouldn't have bothered to make the TDM's steel-bar monorack. It's strong, helps keep side bags away from the paint and provides great bungee points banana.gif
#48 Hartside Man
Posted 04 January 2007 - 03:03 pm
QUOTE(mr sat nav @ Thu 4th Jan 2007, 08:29 AM) <{POST_SNAPBACK}>
QUOTE(twinrider @ Thu 4th Jan 2007, 12:42 PM) <{POST_SNAPBACK}>
Yamama use the stock rack to mount a box on, so they feel its strong enough (albeit they charge you another 75 quid for a rac kto fit on the rack) givi only rate the rack you speak of to 5kg and like yamaha can generate more revenue by selling racks.
i have no doubt its a good bit of kit good.gif but for my usage the way i have it fitted has sufficed so far.
P.S. is that not the type that broke on Dandy's latest tour ?
#49 Doc
Doc
  • 231 posts
Posted 04 January 2007 - 10:02 pm
I agree - I used a Givi rack on my son's GPZ, but just fixed a Givi universal plate straight to the grabrail on my TDM using the supplied brackets. Mine feels more solid. good.gif The Givi racks are quite convenient and available for most bikes, but I don't think they're necessary, particularly for the smaller boxes.
QUOTE(Pict @ Wed 3rd Jan 2007, 10:49 PM) <{POST_SNAPBACK}>
#50 Pict
Posted 04 January 2007 - 11:02 pm
QUOTE(Doc @ Thu 4th Jan 2007, 09:47 PM) <{POST_SNAPBACK}>
No, it's a lesser-known quote from Mae West, in one of her rare "play it safe" moods. tongue.gif cool.gif
#51 twinrider
twinrider
  • 246 posts
Posted 05 January 2007 - 03:26 am
QUOTE(amarko5 @ Thu 4th Jan 2007, 03:48 PM) <{POST_SNAPBACK}>
Hotdiggety damn banana.gif I might have a monorack for sale soon if my sidebags on order work well without the Givi bar.
Am going to order these Ortlieb Drybag Saddlebags from Aerostich. Everyone who uses 'em raves about 'em.
Good review of them from this Duc owner.
#52 Pict
Posted 05 January 2007 - 07:23 am
In the soft / semisoft luggage domain, has anyone else tried Speed Packs? Don't know if they're still available. I got one off eBay a couple of years ago - good capacity and flexibilty (also sits clear of raised cans) and very well made, if a bit pricey new. Think they may have changed name - was only able to Google via this US site, though they're a German.item.
Edited by Pict, 05 January 2007 - 06:39 pm.
#53 Landy
Landy
  • 1,387 posts
Posted 05 January 2007 - 09:32 am
I've seen what looked like your speedpacks on a web site recently but blowed if I can remember where. Leave it with me for a while.
OK here it is. The company is German and called Bags-Connection they have two web sites English and German (the English server is playing silly buggers and will not load properly at the moment).
They also do a smaller Racepack as well.
These calamander.co.uk have UK prices for the full range but a poor webs site. Motohaus also has them.
Edited by Andy K, 05 January 2007 - 10:04 am.
#54 Pict
Posted 05 January 2007 - 05:19 pm
They ARE quite expensive at full price (but see below), but are totally weatherproof (inner bags have tape-sealed seams) and have reviewed well. (Good expedition kit.) I guess the main merits are that the weight is carried fairly high but (because of the shape and stiffening) stably even at speed - I seem to recall their having been track-tested - and you don't commit the bike to any sort of scaffolding. The pannier sections have side access via hooded zips for access en route.
Edited by Pict, 05 January 2007 - 06:44 pm.
#55 Cavey
Cavey
  • 572 posts
Posted 05 January 2007 - 05:31 pm
These are on offer at M and P for £50, instead of £150 at the mo.... good.gif
B Bag
It's not having what you want, it's wanting what you've got.
#56 Pict
Posted 05 January 2007 - 05:37 pm
Well spotted Cavey. good.gif That's a bargain - less, even, than I paid S/H! sad.gif The RRP was/is well above £150 - nearer 200 as I recall.
(Later) Just got an e-mail from M&P about their luggage sale, focused on these packs. Spooky - I must be psychic or something blink.gif
Here's a photo of the Speedpack bits (not the ally platform!!). They all strap solidly together and to the bike
Edited by Pict, 07 January 2007 - 10:38 pm.
#57 DKM AUTOS
DKM AUTOS
  • 509 posts
Posted 25 February 2008 - 11:49 am
So hartside man, have you got the E350 givi top box? And is it double skinned?
Sorry i have probably missed this!
I have been offered a kappa E460 in black with your exact plate and fixings for £120 new - good deal?
2009 BMW R 1200 GS Adventure - ABS / TCS / TPS / ESA / ASC ' The Beast!'
1986 BMW K 100 RT - For sale!!
WWW.BIKETEC-MOTORCYCLE-TRAINING.CO.UK
#58 Guinness
Guinness
  • 1,657 posts
Posted 25 February 2008 - 04:21 pm
Givi all the way here. totally worth it.
ok, the wingrack isnt esthetically appealing, but it is strong.
quality, strong, long lasting, if something goes bellyup you can buy every little piece. good warranty.
its been dropped on the cases, collided with a car while filtereing, one arm of the side rack broke and the case slid 10meters over the tarmac and ended up in the ditch. ducktaped the broken piece, hooked up the case (minor scratches) and we continued the journey.
i have had these cases since 1992 with the fullwingrack. i always have the topbox on. have replaced the lockslide and the topplate, the ancorpoints wear out. just have to add some padding between the topplate and the box to reduce vibrating coz after 100.000km the lockslide might otherwise wear out.
plus you can take your rack and put it on another bike mitst buying a few new pieces. i transferred my rack from teh 850 to the 9.
dont put heavy stuff in the topbox! its more for rainjackets, maps, extra gloves, stuff like that.
if you want to carry "luggage" best put it in sidecases and the heaviest stuff in a tankbag.
get them here
#59 Baron
Baron
  • 1,076 posts
Posted 25 February 2008 - 10:01 pm
QUOTE(Guinness @ Mon 25th Feb 2008, 04:06 PM) <{POST_SNAPBACK}>
#60 Guinness
Guinness
  • 1,657 posts
Posted 25 February 2008 - 10:27 pm
QUOTE(Baron @ Mon 25th Feb 2008, 10:46 PM) <{POST_SNAPBACK}>
get them here
