Won't Start But Can't See Why ###solved###
54 replies to this topic
#41 Bjørge
  • 1,894 posts
Posted 01 June 2016 - 06:16 am
last week every time I started the bike in the morning, the clock/trips reset, battery was holding 12.7V, but dropped to 9.6v when I tried to start, so I replaced the battery.
Did it help ?
Edited by Bjørge, 01 June 2016 - 06:21 am.
#42 ramo
ramo
  • 1,189 posts
Posted 01 June 2016 - 09:01 am
Did it help ?
I do not know, as it will not start, as per my previous post,
the engine is turning over fine,
and the clocks are not resetting, lots of battery life , but its not starting, thats another issue
Edited by ramo, 01 June 2016 - 09:03 am.
#43 Bjørge
  • 1,894 posts
Posted 01 June 2016 - 09:48 am
Okay, this probably means voltage no longer drops that much.
Did you check the lean angle sensor (DIAG 8#) ? https://www.youtube....h?v=rdx1cOEWDB4
#44 ramo
ramo
  • 1,189 posts
Posted 01 June 2016 - 09:59 am
thanks for the link :good:
but my bike is showing no error codes, in the link his bike fires then stops,
my bike does not fire at all, it just turns the engine over,
I will check tilt sensor out at the weekend
thanks steve
#45 fixitsan
  • 4,851 posts
Posted 01 June 2016 - 10:09 am
Is the LCD speedo screen blank ? If so check the ECU plug under the left side panel. With the ECU disconnected it is still possible to crank the engine on the starter....I found that out at the weekend !
#46 Studley Ramrod
Posted 01 June 2016 - 10:17 am
Is the fuel pump priming ?  Also, have you checked for a spark at the plug ?  And finally :)  tried the key wiggle thingy ?
#47 Bjørge
  • 1,894 posts
Posted 01 June 2016 - 10:44 am
thanks steve
Didn't your post say "I've got the same issue, error code 30 and 19, its done me nut in the last couple days" ?
#48 ramo
ramo
  • 1,189 posts
Posted 01 June 2016 - 10:56 am
I have no error codes, even when I try and start it, no codes show,
sorry I was not clear
studs
tried everything you mentioned apart from spark as yet
yep I found the same, but no the speedo is all normal, displays everything
Edited by ramo, 01 August 2017 - 09:47 am.
#49 ramo
ramo
  • 1,189 posts
Posted 01 June 2016 - 12:44 pm
I have now disconnected and reconnected the lean angle sensor, that seems to be working,
Edited by ramo, 01 August 2017 - 09:48 am.
#50 dmmsta
dmmsta
  • 3,627 posts
Posted 19 January 2017 - 02:18 pm
The manual is only on my pc/phone/pad, don't keep a hard copy.
You ar closer than you think with that relay.
It's a broken red wire on the relay that's causing the problem.
I cleaned out the connector block hole and there is nothing left of the spade.
To test that this was the only problem I striped the wire back pushed it up into the hole to make contact with the pin an presto, fired first time.
The question now is how to affect a permanent fix.
Had another look at the wiring diagram, the red wire is a permanent live from the fuel injection system fuse to the relay, when energised it connects it to the red/blue that runs to the fuel pump, simples.
I've just diagnosed the exact same fault (down to the same wire!!)
Similar temp fix pending a bit more time to affect a permanent solution.
One to watch out for as it looks like a weak spot in the build.
@Celtic - did you ever get to a permanent fix for this...I assume that the mini pins in the adapter can be found separately, but it's knowning what type to get!
Edited by dmmsta, 19 January 2017 - 02:19 pm.
#51 celticbiker
celticbiker
  • 1,726 posts
Posted 19 January 2017 - 07:03 pm
Never got round to it.
I have a spare loom and have cut the wires about 10 inches long and will replace the whole onyx with the new one in the summer.
Trouble is that it packed up all together now.
Pump is running but it just died and won't start, that's why I bought the fazer.
Could be down to the same plug but a different wire, I'll find out later.
#52 dmmsta
dmmsta
  • 3,627 posts
Posted 19 January 2017 - 09:35 pm
Spare loom sounds like a plan...
The extra length will make access easier, and also potentially allow for some sort of cover to reduce the risk...
#53 celticbiker
celticbiker
  • 1,726 posts
Posted 19 January 2017 - 10:24 pm
If you look from underneath, you can see where the water can spray up right onto the plug.
#54 dmmsta
dmmsta
  • 3,627 posts
Posted 20 January 2017 - 07:03 am
Yeah its almost funnelled straight onto the connector isn't it :(
#55 celticbiker
celticbiker
  • 1,726 posts
Posted 20 January 2017 - 09:03 am
I know, but strangely I never had this problem on my other one
