Three Bike Man
#41
Posted 30 April 2021 - 08:39 am
I have two late 60' neighbours who seem to live round here, if I'm doing bike engineering. They even bring their own folding chairs.
#42
Posted 01 May 2021 - 08:59 am
#43
Posted 01 May 2021 - 02:03 pm
If you need any chunky stainless for any bike projects Lee I have some lengths of 3" tube with 1/4" wall and some flat plates about 10mm thick, came from a "jersey keel" I took off my boat a few years back, I'm loathed to just weigh it in, not as if I'm a million miles from you.
This lot was so it could sit on a drying mooring without sitting on the props and shafts.
IMG_20161002_132624.jpg 495.17KB
0 downloads
#44
Posted 02 May 2021 - 08:08 am
#45
Posted 02 May 2021 - 05:38 pm
There's meant to be a push for parts provision and easy repairs to white goods, all part of acting sustainably and throwing less stuff on the dump. Mayhaps they need to do the same to cars and bikes. They must make the real money from servicing and parts. That said, with PCP you can get a new vehicle every 3yrs and ya don't need to worry about balancing TB's and the like.
#46
Posted 02 May 2021 - 06:00 pm
I found out the tool locks itself to the ECU code so if you want to do other bikes you need more codes at £40 a pop. It's a money spinner for sure. TDM it's all done from dash. Later bikes with stepper motor fly by wire are more difficult. We are slowly being locked into dealer only work.
Same with cars.I have a fault on my diesel Merc. It needed Adblue so I put some in.The warning on the screen went away for a few minutes, then came back.Then the shut-off warning came on saying I had 473 miles before engine wouldn't start. My local garage put it on their diagnostic system, cleared the faults, but then a general fault came up saying that there was an error with the adblue, but not what it was. They told me that I would have to take it to Mercedes to get fixed and that it is probably a software issue. At least they didn't charge me. Oh, today the warning to put adblue changed to say I have 400 miles before engine won't start.
#47
Posted 02 May 2021 - 08:15 pm
Because of this effort to get you to the main stealers comes clever people to alter the software so your car becomes a polluting piece of crap. You save money, cheater makes a packet. What a bloody mess.
Posted 03 May 2021 - 02:00 pm
@Ali
Did you fill the AdBlue tank completely? There is a minimum amount required before the system resets.
On the Audi I run, the minimum AdBlue to add, once the warning is given, is 13L ,Grrr, but at least the first warning is at 1500miles remaining.
Hope it is this simple for you. ![]()
Posted 03 May 2021 - 02:25 pm
HBOL very helpfully gives some dimensions of this tool. Quite how Triumph get away charging £55 for these is beyond me.
#50
Posted 03 May 2021 - 03:14 pm
Another old cold chisel bites the dust?
Posted 03 May 2021 - 04:44 pm
@Ali
Yes. I put 10 litres in and when that didn't work, I put in some more. Apparently I overfilled it and my local guy took some out. It is just not recognizing that, but the sensor that is supposed to read that doesn't say that is the fault. The garage gave me the diagnostic report and there are 2 and a half A4 pages of sensors in the car.
#52
Posted 03 May 2021 - 08:01 pm
no, I started with virgin 10 mm hex 303 stainless bar. You can't cut up tools that's bodging, not allowed in this workshop.
Edited by leehenty, 05 May 2021 - 07:42 am.
#53
Posted 20 May 2021 - 03:30 pm
Edited by leehenty, 20 May 2021 - 06:23 pm.
#54
Posted 20 May 2021 - 06:18 pm
That bike will be unrecognisable as Trumph before long Lee, a fortune to be made in bike blingey bits ya know.
Sorted and on the Road Mick
#55
Posted 20 May 2021 - 07:02 pm
That's a pretty good finish for a machined ball. ![]()
#56
Posted 20 May 2021 - 09:16 pm
This is my first attempt to at ball turning on this lathe, centre height and getting the axis of the ball turner dead centre is critical or you end up egg shaped.
#57
Posted 21 May 2021 - 07:14 am
As long as the carbide tip is sharp and you take a fine slow finish cut, it polishes up well.
Impressive! Is it a CNC machine or are you doing it manually?
#58
Posted 21 May 2021 - 09:35 am
#59
Posted 21 May 2021 - 10:11 am
There's some proper skill on display there Lee. Top job!
2004 Galaxy Blue. Owned since 486 miles.Renthal 755 bars, Bagster tank cover, Oxford heated grips, DL650 hand guards, Double Bubble screen, Scorpion Rad guard, Gel pad insert, HLD undertray, Angry Badger tailtidy, Roadsmart 4s, Givi E21s, E46 topbox, Ohlins shock and YSS cartridge emulators Currently not fitted - PC3, Remus Revolutions.
#60
Posted 21 May 2021 - 10:14 am
What shiny balls you have Lee!
Proper bling. ![]()
