850 Destruction
892 replies to this topic
#581 leehenty
  • 5,325 posts
Posted 18 May 2020 - 06:13 pm
It's like when I rebuilt the RE, started up nervously watching for signs of oil leak.Take plugs out spin on starter to circulate oil first.
#582 dablik
Posted 18 May 2020 - 07:05 pm
Will do, she's been cranked over today on the car battery from the starter cable..
#583 Studley Ramrod
Posted 18 May 2020 - 08:06 pm
Just run it and check for leaks/unusual noises etc. Then when happy ride it. I know there is lots of info about how to run on start up...often different.
I would not thrash it but more importantly don't labour it. Somewhere inbetweeen dare. Use the gearbox rather than straining tut enjun.
Behold the joys of graphogen. It will get you through these nervous times. :0)
From memory, same here really.  Think I limited my rev limit at around 5000rpm for a while, but I did use the gears a lot so often going up n down in revs.  That said I only really changed the gearbox and did a top end refurb, didn't do the bottom end at all.
#584 dablik
Posted 18 May 2020 - 09:18 pm
Lots of info out in interweb land and it's a matter of sorting the shoite from the good, when it goes out i'll be careful but once i know it's running okay it can have a few beans up to about the same, 5k, your's ran fine after that brake in method..
#585 Catteeclan
  • 2,574 posts
Posted 19 May 2020 - 08:09 am
If is any help, I've rebuilt a few cars and bike engines over the years and always had good results after being told what to do by a pro engine builder. (With the exception of one of my dominator engines, oil burner from day one).
Avoid high revs and load up though the gears.
The prob here is you need to be easy on the crank etc but want that extra compression push those rings out to bed asap.
Machining is so much better now and when to see them thrashing a new bike on the end of the production line on the dyno, I still cringe but you can bet them rings are sweet afterwards.
Edited by Catteeclan, 19 May 2020 - 08:10 am.
#586 leehenty
  • 5,325 posts
Posted 19 May 2020 - 09:05 am
Use a cheaper mineral oil to break in the rings,modern synthetic oils are so good the rings won't knock the high spots off the bores. At least mineral is cheap as you will change it after a few hundred miles anyway.
#587 drewpy
  • 1,790 posts
Posted 19 May 2020 - 09:19 am
I agree Lee, who makes running in oil nowadays ?
#588 leehenty
  • 5,325 posts
Posted 19 May 2020 - 11:27 am
Miller's still do it.
https://www.opieoils...engine-oil.aspx
#589 dandywarhol
Posted 19 May 2020 - 11:59 am
Good advice. KTM still break in their engines with mineral for 1000 km then change to fully synth 10W/60
#590 PICARD
  • 1,786 posts
Posted 19 May 2020 - 02:16 pm
Miller's still do it.https://www.opieoils...engine-oil.aspx
Used to work for company who sold oil additive packages to millers. Good quality generally.
#591 Studley Ramrod
I heard on Gas Monkey Garage, that running in oils have a lot more zinc content.  They know that as they used ordinary oil to run in a non-run in new engine and it started making horrible grinding noises. :lol:
#592 leehenty
  • 5,325 posts
Posted 19 May 2020 - 02:20 pm
Lots of zinc is an anti seize compound
#593 Studley Ramrod
Posted 19 May 2020 - 02:44 pm
That's exactly what the Gas Monkey Garage mechanics found out. lol
#594 dablik
Posted 19 May 2020 - 07:18 pm
i've got running in oil in the bike, Westway lubricants..
Was hopeful of a start up today but carbs decided to overflow, left bowl so took bowls off and floats out for a look see, nice and springy, back in but swapped the float bowls over, much easier access to the overflow bolts now
still leaking left side (different bowl) from the actual joint overflow, off again and a muck about but no joy, gently pumped a little air thinking maybe the floats were a bit sticky, nowt happening
Attached File  DSC_0263 (2).JPG   150.42KB   0 downloadsAttached File  DSC_0264 (2).JPG   234.91KB   0 downloads
So took em off, to much hassle to check fuel heights on the bike with me poor old back so bench tested
Attached File  DSC_0267 (3).JPG   184.44KB   0 downloads
Left side okay, right side was a bit low initially till i tapped it a bit and now it's showing level and no leaks :rolleyes: :rolleyes: fernickety fookers
Attached File  DSC_0268 (2).JPG   116.26KB   0 downloadsAttached File  DSC_0269 (3).JPG   97.64KB   0 downloads
and the bowl overflow hoses are to short so here's one i made earlier
Attached File  DSC_0270 (2).JPG   159.59KB   0 downloads
#595 Studley Ramrod
Posted 19 May 2020 - 09:23 pm
Another day spent fettlin' eh Cliff.  Pain innit ?
#596 dablik
Posted 20 May 2020 - 06:20 am
It's a pain alright, unbelievable amount of work and this is what i mean by one step forward and two back, never mind eh, getting closer all the time, i put the tiniest amount of silicone grease on the float bowl orings just to ease em in and i reckon it stuck them good..
#597 dapleb
  • 18,394 posts
Posted 20 May 2020 - 06:44 am
Imagine how it is possible to do a rebuild commercially to any level of care and attention and make any money!
Has come a long way dabbers.
#598 wicklamulla
Posted 20 May 2020 - 06:49 am
ja tink the fuel will wash that sillycone grease out and all will be golden (loike a shower)?
#599 MickC
MickC
  • 432 posts
  • TDM model: 1995
Posted 20 May 2020 - 08:28 am
When I rebuilt my MK2 SEP refubed the crank,I put new rings in /hone, when started I let it tick over for about 5secs to listen to it and then started to blip it on the throttle for about a minute to put some pressure ot the rings,then got me gear on and went out on it,3 thou limit in the lower gears and 3 1/2 in top.Accellerate quicky up to the rev limit and also shut the throttle when at max revs as I understand you will put as much pressure on the rings decellerating as acellerating (dont do this if someones behind you)
Dont use synthetic oil as too slippery for run in basic mineral as Lee has said,changed it after 130 miles,new filter and full synth went in revs up to 4 and 4 1/2 in top and as the miles went up just increased the rev limit.
Changed the oil at 500ish miles and baisicaly that was it for running in just ride normally and give it some welly at times for a brief few seconds.
Bike burns no oil at all and runs ok.
Before starting I had turned it over to flow oil through.
#600 PICARD
  • 1,786 posts
Posted 20 May 2020 - 08:36 am
80x25kg bags of zinc oxide powder into the reactor via manway.....it's all coming back to me.....(I was much younger then!!)
