6039 replies to this topic
#5981 trevini
trevini
  • 1,891 posts
Posted 14 April 2025 - 11:03 am
Just booked mine in for mot next week. Waiting on a couple of bits and then I can crack on with the service. Seem to be racking the miles up quite quickly; it only seems ;like last week I did the last one.
#5982 thong
thong
  • 72 posts
Posted 15 April 2025 - 09:21 am
sorry no pictures but doubled the amount of holes in the clutch basket to allow more oil to the plates,
also fitted shorter lighter springs in the clutch to make it much easier to pull the clutch lever (no slip)
#5983 laughin in a windstorm
  • 866 posts
Posted 16 April 2025 - 04:03 am
what part did you drill, I drilled holes into a part many years ago to try and stop clutch squeal, it worked while the plates were new, it did it again last time I rode it but there has been many years since I did it (recently got bike back)
#5984 thong
thong
  • 72 posts
Posted 16 April 2025 - 08:28 am
I drilled the hub part of the basket to let more oil in, and drilled the outer part of the basket to let more oil to the plates, hope that makes sense
#5985 trevini
trevini
  • 1,891 posts
Posted 23 April 2025 - 10:00 am
MOT. Another fully clean sheet. The tester even forgot to mention the chain slack, so he must be getting educated. He did say the headlamp was a tiny bit low, which to be fair, is down to me as I wound a turn off the front preload and raised the forks 3mm. Happy bunny for 72k miles.
#5986 Studley Ramrod
Posted 25 April 2025 - 07:13 am
#5987 Kucyk
Kucyk
  • 3 posts
Posted 28 April 2025 - 03:07 pm
Front wheel 19"....
#5988 JMC
JMC
  • 265 posts
Posted 02 May 2025 - 03:54 am
Fitted an AliExpress front and rear camera unit, quality is ok, will see how long it lasts :)
Hunter S. Thompson.
#5989 laughin in a windstorm
  • 866 posts
Posted 05 May 2025 - 04:12 am
ordered a new rear disc as the bike had advisories for a scored rear disc on the last 2 mot's, the wheels are coming off for painting anyway, almost time to start  :banana:
#5990 drewpy
  • 1,788 posts
Posted 06 May 2025 - 04:38 pm
Hi Y'all
been a while, the reason is, my TDM had a short somewhere and left me stranded in Buxton. Smoke pouring from under the tank.
anyhoo, I've found the critter, a tiny rub on the ignition wire. I had take out the loom to find it, gave the connections a soak in salt and white vinegar then Bicarb to neutralise the acid.
most of the connectors have some up really bright, just need to work on a few that are full of green gunge.
Given a few more weeks and I'll be back out riding again after the MOT
#5991 dablik
Posted 09 May 2025 - 07:10 am
Ultrasonic cleaned my old connectors up a treat drewps...
#5992 fixitsan
  • 4,852 posts
Posted 10 May 2025 - 08:32 am
A nice 60 mile run around the Borders region, keeping the bike alive after spending lots of time on the FJR, I can appreciate how much lighter the TDM is !
#5993 drewpy
  • 1,788 posts
Posted 10 May 2025 - 06:31 pm
nice, i'd seen some on youtube doing that but I don't have one. the vinegar method worked well though.
#5994 drewpy
  • 1,788 posts
Posted 11 May 2025 - 12:52 pm
test fitted the loom before i wrap permanently.
good job i did as i needed to make a few adjustments
#5995 leehenty
  • 5,323 posts
Posted 12 May 2025 - 07:16 am
Bike is overdue a shim check 48,000 miles rolled over yesterday, but I’m still on the road in Spain.
#5996 laughin in a windstorm
  • 866 posts
Posted 13 May 2025 - 03:17 am
it was my intention to wash the bike and take it out to dry it it off now that we have super dry weather, I needed it to go and help my wife lifting stuff at the allotment (she used the car to get there), it had gathered so much dust from our on going garden project (pond), so it needs to be clean to make a start,
it bo******** rained, now back to no where,
still it was interesting to ride with the fast idle stuck on, every time I released the brakes the bike accelerated, thought it was going to blow up while waiting at traffic lights that take two days to change so had to turn it off,
the best laid plans are often best buried
#5997 leehenty
  • 5,323 posts
Posted 17 May 2025 - 08:21 pm
Gave it a shim check at 49,000, nothing moved but I had noted that the cam chain was stretched as the marks didnt exactly line up. Treated it to a new genuine cam chain, everything lines up perfectly now. Buttoned it all back up ready for another 24,000.
#5998 laughin in a windstorm
  • 866 posts
Posted 18 May 2025 - 03:12 am
can you fit an endless chain without engine disassembly or was it a 'soft rivet' split chain
#5999 leehenty
  • 5,323 posts
Posted 18 May 2025 - 07:48 am
In the TDM the endless chain can be easily fitted, just remove both oil pumps. It helps to have both oil pump gaskets to hand as they are thin and easily torn. Tie a bit of wire to old chain to pull new one up the tunnel. As Both cams have to come out, its best to do this at shim time.
Edited by leehenty, 18 May 2025 - 07:50 am.
#6000 laughin in a windstorm
  • 866 posts
Posted 26 May 2025 - 02:27 am
well I managed to wash it again and take it for a short ride to blow most of the water off, bike constantly revving at 2500rpm except with the engine cutting out each time I de-throttle before starting again at 2500rpm made me aware of what it must be like to be a kangaroo
