6039 replies to this topic
#6001 fixitsan
  • 4,852 posts
Posted 17 July 2025 - 08:49 am
MOT passed, no advisories and no money spent since the last test ! (tax, fuel and insurance excepted)
She keeps rolling on :)
#6002 trevini
trevini
  • 1,891 posts
Posted 21 July 2025 - 09:25 pm
 Treated the bike to a little love as it’s just clocked up 75k miles. Striped and rebuilt the forks. They were due an oil change having covered an out 13k since the last one (last July) and I wanted to adjust the compression a little just to soften it up a bit.
New bushes, new seals, new Motul 10w fork oil, down to 1 turn of preload on the emulators and raised 8mm through the yokes with 5 turns of spring preload. Back to the really sweet, plush, neutral handling again and definitely feeling more grippy on the front.
Nearly time to get the rear shock rebuilt, so that’ll be next.
#6003 leehenty
  • 5,323 posts
Posted 22 July 2025 - 07:27 am
75K ? Its just run in
#6004 trevini
trevini
  • 1,891 posts
Posted 22 July 2025 - 11:45 am
Indeed it is Lee and all the better for it. 75k of mostly trouble free miles. Outside of consumables, it's had two headlamp bulbs, one tailight bulb and a couple of fork seals. I suppose the bulbs could be classed as consumables too. I'd class discs and bearings as normal service items, but it has had every bearing replaced, but only one due to failure (hub carrier bearing last year as it developed some play), the rest being preventative maintenance. Brilliant bikes, but we all know that!
#6005 Studley Ramrod
Posted 28 July 2025 - 05:54 pm
:cool:
#6006 trevini
trevini
  • 1,891 posts
Posted 10 September 2025 - 03:33 pm
77K miles is starting to take its toll a little on the old niner.
 A month or so back, I noticed I was missing a few up changes and started to fear the worst that the gearbox may need some attention. In reality, nothing to worry about. On further inspection, the left footrest was a bit wobbly and droopy.
I've never worn out a footrest hanger before!
And the end of the footrest to go with it.
Attached File  IMG_4533.JPG   175.03KB   4 downloads
All good now. Initially I made a plate up to go between the foot rest and hanger, which also compensated for the now oval (due to wear) clevis pin holes in the hanger. That was one;y intended as a temporary fix while I sourced a decent used hanger. No such luck there as most were quite heavily corroded. Got a brand new one from Fowlers eBay arm for a bargain £75, so all back to normal again now.
Edited by trevini, 10 September 2025 - 03:35 pm.
#6007 leehenty
  • 5,323 posts
Posted 10 September 2025 - 04:22 pm
Point of order wont you need a new one the other side so they both match ?
#6008 trevini
trevini
  • 1,891 posts
Posted 10 September 2025 - 04:57 pm
Nah, Ill just polish the new one so its as shiney as the original on the other side. 🙂
#6009 laughin in a windstorm
  • 866 posts
Posted 11 September 2025 - 03:16 am
wow, I've never seen a footrest mount worn like that, glad you had a simple fix for your gear changes
#6010 trevini
trevini
  • 1,891 posts
Posted 11 September 2025 - 05:24 am
Me neither. The front pin hole had gone oval, so I’m assuming that allowed enough movement for irregular, firmer contact causing the wear points in the pic. The footrest itself had been replaced around 2008/9. I’ve had the bike more or less from new (6 months old when I bought it), so it’s all down to me.
#6011 leehenty
  • 5,323 posts
Posted 11 September 2025 - 08:37 am
What I did was get mine powder coated, saved me no end of polishing
#6012 Kucyk
Kucyk
  • 3 posts
Posted 28 October 2025 - 05:19 pm
My TDM 850 1996.⁸
#6013 Timbo1866
Timbo1866
  • 224 posts
Posted 16 December 2025 - 11:04 pm
Not posted for ages
Finally got her MOT’d have done a massive 206 miles in the last year
had far to much on this year hopefully back to weekends away on the old girl next year
Just need to give her a tidy up hopefully before the summer
#6014 drewpy
  • 1,788 posts
Posted 18 December 2025 - 05:12 pm
My TDM 850 1996.⁸
nice, where did you get the upside down forks from and were they a straight fit?
#6015 trevini
trevini
  • 1,891 posts
Posted 19 December 2025 - 06:58 pm
Bought another set of RoadSmart 4s. The front is down to just over 2mm now after just shy of 15k miles and the rear on 3mm after almost 9k miles. I’ll probably get a couple more months out of them yet, but at least they’re here ready to fit when I do need them. Plan is to repaint the wheels while the tyres are off too.
Best tyres I’ve had on the niner by a country mile. Really even wear and no cupping. Much better than the Michelin Road 5s I had previously, which didn’t wear particularly evenly on the rear and had a ridge between the compound change after 10300 miles on the rear. The front squared off a bit too by the time it was changed. Grip wise, about the same between the two and both excellent in the rain.
#6016 leehenty
  • 5,323 posts
Posted 20 December 2025 - 11:04 am
Put it on the battery charger for its monthly charge and left it crying gently under its cover as I went off on the Honda
#6017 trevini
trevini
  • 1,891 posts
Posted 20 December 2025 - 12:36 pm
How are you finding the Pan Lee?
#6018 leehenty
  • 5,323 posts
Posted 20 December 2025 - 01:48 pm
Smooth, fast, heavier than the TDM obviously but once underway that all disappears. My TDM is staying in tbe stable though.
#6019 leehenty
  • 5,323 posts
Posted 20 December 2025 - 09:02 pm
Fuel economy nearly the same, but thats because I ride like a granny. Give the Pan the beans it gets scary very fast
#6020 fixitsan
  • 4,852 posts
Posted 01 February 2026 - 01:47 pm
Took a ride for a couple of hours into  the borders :lol:
