850 Destruction
892 replies to this topic
#641 leehenty
  • 5,325 posts
Posted 29 May 2020 - 08:53 am
Take your time bud, no sense in flogging yourself. Plus you got that bike to finish.
#642 wicklamulla
Posted 29 May 2020 - 09:38 am
yep i advise a steady return to duties as your age demographic dictates so...   can ya get them anti bodies to help with the boike reassembly?
#643 dablik
Posted 29 May 2020 - 08:53 pm
Thanks gentleman, if only Ken...
#644 leehenty
  • 5,325 posts
Posted 30 May 2020 - 07:37 am
Weather is fine, rig up a sunshade and get to it, I expect it on the road no later than 1st July.
#645 Catteeclan
  • 2,574 posts
Posted 30 May 2020 - 09:44 am
Good news for all, well done Cliff.
#646 dablik
Posted 30 May 2020 - 07:59 pm
Thanks Dave
Well looks like i've sprung a little leak, found a very small amount of oil under the downpipes bout the size of me hand palm, on inspection looks like it may be coming from the sump gasket right between the down pipes, all the sump bolts tightened up a small noggin but when i rechecked looks like it's from me home made gasket, nowt higher up and nothing below it...fook, another job, wonder if this heat and thin running in oil helps much !! better now than later though eh..
So new gasket or wotigot, Blue Hylomar.
#647 Studley Ramrod
Posted 30 May 2020 - 08:16 pm
Daaang. I guess there could be worse places to get an oil leak from eh. I'd prolly go for a new gasket.
#648 dablik
Posted 30 May 2020 - 08:27 pm
Aye, need to make doubly sure it's from the sump. cant really be anywhere else though, why now though seems strange dunnit..
#649 Studley Ramrod
Posted 30 May 2020 - 08:38 pm
Could try that trick that Ivan did with the talc. Dried up the leaky oil then talced it.  Might have taken a while to show esp. if you've only run the engine for a few mins eh.
#650 dablik
Posted 31 May 2020 - 06:22 am
Could be, talc sounds good though :good:
Edit.. left a piece of tissue under it last night and it's not even the size of a 20p, maybe missed a bit drying up, another piece of tissue and talced as well so will keep an eye onnit, maybe the little tighten up of the bolts sorted it..
Edited by dablik, 31 May 2020 - 06:49 am.
#651 Favs
Posted 31 May 2020 - 08:15 am
Fitting an oil warning for peace of mind ?
Dunno what's on the MK1 other than the it's too late now lamp
#652 leehenty
  • 5,325 posts
Posted 31 May 2020 - 09:04 am
Have I sent you a pressure switch cliff ?
#653 dablik
Posted 31 May 2020 - 06:32 pm
Yes Lee, it's fitted and working, goes out right away :good:
Panic over me thinks re the leak, talced it up this am and have about 1/2 a small finger nails worth of oil, the home made gasket is sitting a little proud and that's where oil is collecting, so i'll keep an eye for now and if it's good till i change oil,check valves and retighten bolts i'll wup a new one on then.
#654 butcher650
butcher650
  • 619 posts
Posted 01 June 2020 - 06:13 am
Interested to know where you run the main fuel lines from the tank to tap, as I've replaced my lines, and seem to have a fueling issue when the level in the tank goes below a certain level. I think its because I haven't routed the gravity lines properly, but I didn't take out the metal battery tray bracket to get them out, and and it seems I need to go get them back in so they flow down properly. They had been off the bike so long I couldn't remember exactly where they went.
#655 Snowbird
  • 1,475 posts
Posted 01 June 2020 - 07:03 am
On my mk2a I fitted a fuel tap from a mk2 and new pipes and had a fuel issue flat out, changed back and no problems, I recon the thicker wall pipe kinks too easily for the bends needed, maybe your issue.
#656 butcher650
butcher650
  • 619 posts
Posted 01 June 2020 - 07:34 am
I did note the new lines being a nadge thicker than the old ones. I'm going to re-route them and see if it makes a difference. I'll also make sure the pump is working properly.
#657 dablik
Posted 01 June 2020 - 03:45 pm
Have you mixed up Reserve and Fuel line, you need to know which spigot under the tank is Reserve and Fuel, the bottom pipe on the petcock is Fuel to the pump then out from the pump to carbs..
Bollock's leaking a bit more, i'm going in boy's.......gasket ordered, also oem gasket is 0.50mm and i've used 1mm, user error again,duh..
#658 Studley Ramrod
Posted 01 June 2020 - 06:54 pm
Least the bike will be lighter with the thinner gasket. :D  It's all part of the experience eh.  God knows I've had my share of f**k ups.  Cardboard inside the engine was prolly my biggest gaff. :lol:  That and trashing 3 sets of carbs.  :huh:
#659 Norwegian
Norwegian
  • 162 posts
Posted 01 June 2020 - 06:59 pm
3 sets? :intrigued:
#660 Studley Ramrod
Posted 01 June 2020 - 07:13 pm
Trashed the carb bodies trying to drill the float bowl screws out on 2 sets and snapped the carb body on the 3rd set. I was a bit hamfisted back then. :lol:
