850 Destruction
892 replies to this topic
#681 Favs
Posted 12 June 2020 - 11:58 am
I hope you recover much faster bud. :good:
#682 dablik
Posted 12 June 2020 - 04:57 pm
Cheers pudding, New gasket sorted now, took it off and of course started pissing down :rolleyes: had to done me oilskins and put the big sun brolly over the bike to re-install and typically as i write this the Sun is shining, as i had to take the headers off i also managed to square the exhausts up but the headers are a bit tight fit for my liking, dont appears perfect so that'll most likely go to MTC to be sorted, bleed nipples arrived today but still no brake lines..
Edited by dablik, 12 June 2020 - 04:57 pm.
#683 Favs
Posted 12 June 2020 - 05:33 pm
Them nipples get on everyone's ti.......
#684 leehenty
  • 5,325 posts
Posted 12 June 2020 - 05:49 pm
You're fitting stainless ones I hope.
#685 dablik
Posted 12 June 2020 - 06:03 pm
Oh no not stainless, you is the king of bling, will be enough as it is on all the cases...
#686 dablik
Posted 13 June 2020 - 12:51 pm
Right i'm ready to burn the bleeding bike, brake light is on constantly and it's the rear brake switch, cant seem to find where the switch spring sits, thought it went on the pivot but that's causing it to be constantly on and i've adjusted the plastic nut on the switch itself, pic or idea anyone, taking far to much time up now, i'll order a banjo furrit but fook knows when that will arrive..
Down tools, adenuf, it can wait...
Edited by dablik, 13 June 2020 - 01:31 pm.
#687 Snowbird
  • 1,475 posts
Posted 13 June 2020 - 01:53 pm
MK2a but probably similar.
Attached File  20200613_144851.jpg   156.23KB   0 downloads
Attached File  20200613_144905.jpg   160.12KB   0 downloads
Attached File  20200613_144932.jpg   138.46KB   0 downloads
#688 dandywarhol
Posted 13 June 2020 - 03:00 pm
Sticky plunger?
#689 dablik
Posted 13 June 2020 - 03:03 pm
Dave cheers matey, hope you didi'nt have to get down and dirty for the photo's but they help, although i used that pivot point for the switch spring and would'nt work, however the bottom spring on mine could be on wrong which would change things, i'll get back on the tools and see,brilliant thank you xx
Sticky plunger?
Na cleaned it up and had it apart again and moving freely, think me pivots is set up wrong...
#690 dablik
Posted 13 June 2020 - 05:15 pm
Okay sorted now, piccies were very helpful, it's a case of not seeing the wood for the trees, switch was seated incorrectly, thought it was odd initially as it looked like it should fit in with the nut on top, could'nt get it in though and eventually got frustrated, ya gotta take of the exhaust and rear brake lever, take off the foothanger then the rear MC to get at the bloody switch as access is diabolical, bit more powder coat filed away :rolleyes: and got the switch to fit properly which solved all my woes with the springs in correct places, woop woop...
Jeez it's getting to me again taking over me life this bike and a whole bunch of bolts i cleaned up are showing a bit of rust again, when will it be over :huh: soon,soon, soon, please..
#691 Studley Ramrod
Posted 13 June 2020 - 05:52 pm
Oh I dunno, 691 posts up to now, be a shame not to reach 1000. :lol:
TBH there's fook all else to do at the mo really.
#692 leehenty
  • 5,325 posts
Posted 13 June 2020 - 05:53 pm
Paint em in ACF50
#693 dapleb
  • 18,394 posts
Posted 13 June 2020 - 06:09 pm
I don't think feeling less than 100% well helps either dabbers. Cut yourself some slack. There isn't/shouldn't be a massive hurry. Ewe will get it done.
#694 leehenty
  • 5,325 posts
Posted 13 June 2020 - 06:23 pm
Take is slow and steady fella, there is no great hurry.
#695 dablik
Posted 13 June 2020 - 07:45 pm
No your right it does'nt matter when it gets finished, i've always maintained that but, it needs to get done now as it just takes all my spare time when the weather is good and i'll still be fettling small stuff once it's had an mot, then i wont mind so much as i did the same with me other bikes, was hoping to get the fuel lines in today, tank de-rusted next, think i'll stick a litre of oil in it once dry to prevent flash rusting, and a recheck over all main bolts, oh front mudguard, this is really the bane of me life, painted it twice already, now sanded back, gotta to find somewhere to paint it or get another..
That reminds me to ask, which side does the tank overflow pipe reside, to the left or the right..
Cheers boy's just a little frustration set in, 1 step forward 3 steps back kinda thing..
#696 leehenty
  • 5,325 posts
Posted 13 June 2020 - 08:09 pm
You are doing a fantastic job, frustrating at times I know, but you will win in the end.
#697 Favs
Posted 13 June 2020 - 09:01 pm
:rotflmmfao:
#698 Studley Ramrod
Posted 14 June 2020 - 12:42 pm
:lol:  I'll tell you how its hanging Cliff.  Slightly to the left. :)  Well, I think it does, it exits from behind the sprocket cover to the right of the gear lever.  I think there might be a wire loop on the frame.  Need to check mine at some point as it looks like its dropped lower for some reason.
#699 dablik
Posted 14 June 2020 - 03:51 pm
Nice, was just in there today routing the carb overflow pipes, hm may have to slap those the other side, 2 metal bendy clips to hold the fuel overflow...
#700 Studley Ramrod
Posted 14 June 2020 - 05:01 pm
Yep, deffo got mine routed down behind the sprock cover, as you say 2 bendy clips holding it and another toob in place. Obviously I can't be 100% sure its correct, it's how I found it.  Nothing in Haynes ?
