6036 replies to this topic
#701 chrisr
Posted 26 May 2015 - 04:38 pm
Thanks for your concern chaps, we're both a bit battered and bruised but nothing time and money won't heal!Attached File  image.jpg   79.62KB   0 downloads
#702 Rallyist
Posted 26 May 2015 - 04:57 pm
Thanks for your concern chaps, we're both a bit battered and bruised but nothing time and money won't heal!attachicon.gifimage.jpg
Nice colours, glad you are OK what crash bungs were fitted to your machine Chris as I want to steer clear of them ones.
#703 chrisr
Posted 27 May 2015 - 05:54 am
R & G, damage mostly superficial and no cracks or bent levers, so I think bungs and handguards did help. Bruises still spreading!
#704 arthurbikemad
arthurbikemad
  • 573 posts
Posted 27 May 2015 - 03:12 pm
MOT'd, then made a mini log burner, like you do haha
Ordered up some +20mm HEL lines for the SW Motec UP/BACK+25mm I ordered too to save my elbow :(
Edited by arthurbikemad, 27 May 2015 - 03:13 pm.
#705 leehenty
  • 5,318 posts
Posted 27 May 2015 - 03:18 pm
That will be you banned from trips for a while when swmbo find out. 😞
#706 TDMTAM
Posted 27 May 2015 - 10:01 pm
Cool ;-)
Here's one I made earlier
#707 g650xtdm
g650xtdm
  • 295 posts
Posted 27 May 2015 - 10:35 pm
What are you guys making those out of?  Sort of look likes old propane tanks.
Edit:  I guess I should have just Googled "mini log stove" - all sorts of ideas.  Although I can't say I'm too keen on cutting into an old propane tank.
Edited by g650xtdm, 27 May 2015 - 10:41 pm.
#708 g650xtdm
g650xtdm
  • 295 posts
Posted 27 May 2015 - 10:44 pm
So, does anybody notice anything unusual about my new seat cover??  I'll give you a hint:  it is easy to figure out when trying to check the oil :rotflmmfao:
#709 TDMick
Posted 27 May 2015 - 10:46 pm
OOOps
Edited by TDMick, 27 May 2015 - 10:46 pm.
#710 g650xtdm
g650xtdm
  • 295 posts
Posted 27 May 2015 - 11:01 pm
I left a message for they guy but he hasn't returned my call yet.  I'd just fix it myself, but he has the plastic bezel that goes around the keyhole.  I was relieved to learn they are still available from boats.net if it comes to that.
#711 arthurbikemad
arthurbikemad
  • 573 posts
Posted 28 May 2015 - 08:07 pm
Fitted my up and back SWM risers, had to pull some slack up for the cables but all ok now and have new custom Hel brake lines tomorrow not that the brake is over tight but hay best do it right, puts the switch gear up agains my small SWM tank bag on full lock slightly, I was ready to scrap the idea but looks like I will have to poke up with the slightly strange look as now it's much better for my arms, needed to get in a more up right position to relive the stress on my sick elbow after a few hours ride, I am super happy with the position now!
#712 Phil McLaughlin
Phil McLaughlin
  • 164 posts
Posted 29 May 2015 - 11:08 am
Put her in for her first MOT - its only 6 months late  (oops) and a new rear tyre at the same time
Waiting with bated breath....
#713 dmmsta
dmmsta
  • 3,627 posts
Posted 29 May 2015 - 11:43 am
I'm obviously not 850 minded, as I don't get it... :hide:
Oh hang on - I see... :punishment:
Edited by dmmsta, 29 May 2015 - 11:44 am.
#714 Phil McLaughlin
Phil McLaughlin
  • 164 posts
Posted 29 May 2015 - 03:29 pm
And she passed :-)
And has a tyre without a fecking nail in it
And I have a pressure gauge with a BIG dial on so I can tell the difference between 4 and 40 without glasses :-(
#715 Favs
Posted 29 May 2015 - 05:26 pm
 As raining today.........
Fabricated some mountings which were then used to fit a Givi Monokey topbox plate to complement the Yamaha panniers
Painted the mountings too.
Converted dip beam to a 55w HID H7R then discovered that high beam is very yellow.
#716 schmo9
schmo9
  • 197 posts
Posted 29 May 2015 - 08:47 pm
Fitted black Renntec engine bars, supplied by Studley Ramrod.... cheers again mate, well chuffed :)
#717 g650xtdm
g650xtdm
  • 295 posts
Posted 29 May 2015 - 09:11 pm
The upholsterer can't locate the lock cover.  He offered to fix it, but he's 40 miles away in a direction I'm not usually headed.  Since I was ordering a new cover ($15) anyway, I figured I might as well order a couple OEM Majesty mirrors ($100 pair) while I was at it.  My seat cover is getting expensive! :rolleyes:
#718 dmmsta
dmmsta
  • 3,627 posts
Posted 30 May 2015 - 07:07 am
I;m sure that Celtic posted up about mixing HID & Normal, and issues with beam patterns.
Think it came down to both normal or both HID, otherwise you'll never get a good beam pattern on the road...
FOUND IT: http://www.carpe-tdm...=30520&p=302823
#719 arthurbikemad
arthurbikemad
  • 573 posts
Posted 30 May 2015 - 08:18 am
Here is a good solution to HI beam and LOW (tested on a blade OK but not in the TDM), but you will need to tuck the heat sink braided cable away.
http://www.ebay.co.u...=item4d2acbac72
Beam pattern is not ideal imo hence why I use H7® in my low beam also, I also have H7® HI beam, you can buy quick start HID kits not normally known as quick start as such but check the spec as kits do exist that fire up to full lumens in a second or so unlike most that take 10-15secs.
I am very happy with my HID kits, however I did buy some Charley wannabe lights (GIVI LED DRL's) and tbh they are amazing!  As big of an upgrade again as the HIDs were..
Edited by arthurbikemad, 30 May 2015 - 08:19 am.
#720 arthurbikemad
arthurbikemad
  • 573 posts
Posted 30 May 2015 - 08:41 am
Few pics, SWM barback risers fitted.
Defo helps my arm (torn tendons on elbow and a plate on my collar bone :( )
Now to fit some Hel lines (+20mm) for the risers:)
