What About This Method For Changing Oil Seals ?
66 replies to this topic
#61 Studley Ramrod
Posted 12 July 2021 - 06:11 pm
Cheers guys. Fortunately for me, my bro has taken up welding again, so naturally I wanted to help him get his skills up to spec, hence the frame. :D
Thought you would of pulled them apart with ya bare hands Studs  :)
I defy anyone to do that with mk1 forks. :lol:
Found quite a bit of crud on the big washers below the seals.  :huh:
Now, what paint to use ?  I'm thinking of a light sanding then a primer/builder followed by paint and a clear lacquer.
#62 dapleb
  • 18,376 posts
Posted 12 July 2021 - 06:27 pm
I rebuilt a set in 2012 due to the imminent failure of my existing forks.
I think I used itching powder ...err no wait etching primer and then paint and then thin lacquer layer. Then I covered in helicopter tape to try and protect it......can't tell you if it worked as my imminent failing forks what ride over bubbles of rust are still not leaking and work fine!
#63 Studley Ramrod
Posted 12 July 2021 - 06:42 pm
Etching primer.  Might end up using that stuff actually.  Some chips on the forks are down to the metal so might well remove all the paint and start from scratch.
#64 Studley Ramrod
Posted 12 July 2021 - 07:00 pm
Another option would be to use Symoniz engine paint as it goes straight on to alloy but the colour choice is limited.  Finish with a clear coat.
#65 leehenty
  • 5,316 posts
Posted 12 July 2021 - 07:19 pm
Nice jig SR
#66 dablik
  • 10,892 posts
Posted 13 July 2021 - 07:53 am
Pulled mine out by hand mucka  :P
#67 wicklamulla
Posted 13 July 2021 - 08:03 am
Your comment above shud be in a 900 thread...  :rotflmmfao:
